| UnspeedySam |
 UnspeedySam World Chat Champion
| SillyMe |
 SillyMe Trackday Trickster
 Posted: 19:08 - 16 Oct 2010 Post subject: |
This chap had a similar issue, may well be worth a ganda's.
https://www.bikechatforums.com/viewtopic.php?t=207074 ____________________ Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between) |
| UnspeedySam |
| Carvel |
 Carvel World Chat Champion
| UnspeedySam |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:46 - 17 Oct 2010 Post subject: |
Have you got a wiring diagram / Haynes manual?
If its the 'old' 6v system, then its possible that its the 'lighting direct' magneto system they used on the older air-cooled singles.
Basically generator has coil for the ignition, another to charge the battery, and another for the head-lamp & tail light, as they are the 'high-load' devices.
If the headlamp doesn't light up (side-light only) without the engine running, then its pretty likely.
I think that there is a small zenner diode in the circuit to prevent over-voltage, which may have broken down, but you'll need to check the wiring diagram.
Other thing is the bulb wattage.
6v lamps are pretty dire, so common to fit higher rated bulbs than standard.
These burn hotter, so are more prone to blowing due to vibration and or over-volts.
Other thing is bad earths.
Old bikes, connections corrode. corrosion causes a resistance between contacts, that puts extra load on the circuit drawing more amps, becouse the resistance is in series with the bulb though, it burns dimmer, but still sees higher amps, and that can be enough to make it pop. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| UnspeedySam |
 Posted: 16:56 - 17 Oct 2010 Post subject: |
The bulbs I've had issues with are the ones from wemoto which are 45/40 bulbs https://www.wemoto.com/bikes/Yamaha/RXS_100/86-94/picture/Bulb_Headlight/
The low beam filament has definitely gone, as replacing the bulb or using high beam works. This has happened a couple of times in two weeks now.
I have some understanding of electronics, but I don't have time to try and decipher the wiring diagram in my haynes manual at the moment...
Maybe just running 35w bulbs would fix the problem.
Without the engine running, only the indicators and the brake light work as far as I know.
When I have more time I'll check out everything with a multimeter. ____________________ Riding: BMW R1150RT `02 bought mildly crashed
Gone: ZZR600 '00, TRX850 '97, RXS100 '93, JS125-6B '07, BMW R1100RS '93, Kawasaki ZX-6R-J2 '01, Honda Bros NT400 NC25 '88 |
The last post was made 15 years, 342 days ago. Instead of replying here, would creating a new thread be more useful? |
