| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 03:16 - 18 Oct 2010 Post subject: Removing Exhaust Header Bolts?? |
Do I put WD40/penetrating oil on a hot, warm or cold engine
and before or after running the engine??
...or is it just a matter of "all of the above"??
Basically I'm making preparations to replace the connector pipe on the exhaust collector box, but when I take the exhaust off I'm also going to be replacing the existing header bolts with better quality stainless ones.
Well, I made a tentative attempt to loosen one or two of the header bolts yesterday, but absolutely NO movement from them.
If possible I'd obviously like to avoid having to drill and re-tap them, so I'm going to be giving them an intermittant dose of WD40 or similar over the next few days ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| dodgydog |
 dodgydog World Chat Champion
| neil. |
 neil. World Chat Champion
 Posted: 07:08 - 18 Oct 2010 Post subject: |
I did this recently on my YBR. The screws looked pretty rusty and the bike had covered 2 and a half winters and 31'000 miles.
I started my penetrating oil routine a week before attempting to remove the bolts. The stuff I used is called 3-in-1 penetrating spray. When I got in from work, I immediately sprayed it all over the screws whilst the engine was hot (but turned off!). It smoked a lot but don't worry about that. The heat draws the stuff into the threads aparantly. Before bed, when the engine had cooled, I gave them another dousing so that more spray could have the chance to seep in overnight.
I carried on with this for 5 days and then, using a proper hex head socket, NOT an allen key, I tapped it in with a small hammer, in hope that the shock would help loosen things up and centre the socket bit in to the screw properly. Then I carefully used my breaker bar and slowly applied pressure until the screw cracked loose. After that, I sprayed it with more penetrating spray, gave it a moment and turned it a bit more, then turned it clockwise 1/4 turn and repeated the process until the screw became easy to unscrew. Then repeated with the other one and then removed both. Whatever happened I did not in any way, shape or form want the head being rounded out or, even worse, snapping off leaving a stud in the engine block! The key is patience.
Also, with penetrating oil you can make up a plastacine 'well' around the screws and effectively submerse them. I didn't do this but it sounds like a good tip IMO, especially if the screws face downwards.
+1 for not using WD40, use a proper penetrating oil. Also when you put it all back together, use loads of copper grease on the exhaust gasket as well as the new screws and a torque wrench because they are easy to overtighten and chances of stripping the soft threads of the alloy engine casing are high. ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Bezzer |
 Bezzer World Chat Champion
 Posted: 13:47 - 18 Oct 2010 Post subject: |
Take it this is for the infamous Bandit collector rot
Use Plusgas for a few days or any other penetrating spray, anything is better than WD40.
When you have a go at removing them give the allen socket a good whack as this can help to shock the corrosion apart, if they haven't been done for a while you will round off a few of them.
The best method then is to get a 12mm multipoint socket and hammer it over the allen head, stick a ratchet on and it should undo. This method usually works, if it doesn't and the bolt breaks then it was beyond redemption anyway. ____________________ I used to be indecisive but now I'm not quite so sure. |
| Dazbo666 |
The last post was made 16 years, 4 days ago. Instead of replying here, would creating a new thread be more useful? |
