TV's running at different times
Black Knight
PostPosted: 09:17 - 18 Oct 2010    Post subject: TV's running at different times Reply with quote
Noticed it in shops before and just noticed it now. TV is on upstairs and running a good 2 seconds faster than the same program downstairs.
Confused
Anyone know why?
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
doggone
PostPosted: 09:44 - 18 Oct 2010    Post subject: Reply with quote
Space-Time continum is ruptured just by your bathroom door.
Extreme caution advised when entering Thumbs Up
Mr.Everready
PostPosted: 09:52 - 18 Oct 2010    Post subject: Reply with quote
What channels are you on ? Sky can run a bit out if you're on multiroom. HD channels also run differently.
Charlie
PostPosted: 10:15 - 18 Oct 2010    Post subject: Reply with quote
Freeview and terrestrial are also out of sync. I'd be more inclined to believe that terrestrial was the correct time and everything else is out of sync with that. The digital processing required for digital signals takes a bit of time to perform.
PsychoHippy
Jammy Git
PostPosted: 10:55 - 18 Oct 2010    Post subject: Reply with quote
Could be caused by one being watched on terrestrial signal and one on satellite.
However if they are from the same source I would go with doggone's explanation!
I spend all my money on bikes and beer, the rest I simply waste!
Hetzer
PostPosted: 13:00 - 18 Oct 2010    Post subject: Reply with quote
Pretty obvious that you must have turned one of the TVs on two seconds earlier than the other. Rolling Eyes
map
Mr Calendar
PostPosted: 13:17 - 18 Oct 2010    Post subject: Reply with quote
Quite handy when on the 'phone to a mate and watching a game on TV.
Told him about the goal before it appeared on the SKY he was watching Very Happy
Digital (freeview and satellite) are out, as said probably by the processing involved. Also affects DAB radio as well.
PsychoHippy
Jammy Git
PostPosted: 15:18 - 18 Oct 2010    Post subject: Reply with quote
Satellite is obviously going to be out because the signal has to travel up to the sat and back down, this takes around 500ms, the signal then has to be decoded by the sat box which will add to the time too. The some modern TVs do post processing (even on an already digital picture) which slows down the output again.
Add all this time up and you can easily get the 2 second delay.
However without more details of the setup this is all merely speculation Smile
Paxovasa
PostPosted: 15:26 - 18 Oct 2010    Post subject: Reply with quote
It is due to the air been thinner upstairs and so the signal get tired Thumbs Up
The last post was made 15 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 60.92 Kb
