Charging battery
moto
PostPosted: 13:21 - 18 Oct 2010    Post subject: Charging battery Reply with quote
I have not been able to ride the bike for about 3 weeks due to what I think is a trapped nerve in my shoulder.
Just went to the garage and tried the electric start, it turns the engine slowly, might actually die before the engine fires.
I have a car batter charger, is there any reason why I should not sue it to charge the bike battery?
It's an XT600E 4PT by the way.
Tavares
PostPosted: 13:24 - 18 Oct 2010    Post subject: Reply with quote
as long as its not a high powered car charger it should be fine, i'm guessing its not one that has different settings for different battery types?
2006 Eurostrada RX8 125(sold)>2004 Kawasaki ER-5(sold)>2002 Honda CB600F Hornet
0ddball
PostPosted: 13:31 - 18 Oct 2010    Post subject: Reply with quote
Yeah it'll be right. I use a cheapo (1 setting) car charger to keep my zxr battery good while i rebuild the bike.Been giving it a quick zap every couple of months for over a year now and it's fine.
A decent battery should hold good charge for months though so yours sounds tired.
moto
PostPosted: 13:34 - 18 Oct 2010    Post subject: Reply with quote
I bought it many years ago for the car in case of emergencies but so far have never needed to use it.
It does say suitable for 6 or 12 volt car, motorcycle and lawnmower batteries but wanted to see if anyone came up with a reason not to use it on my bike.
Ages ago I saw a post about using a specific motorcycle battery charger.
It is a heavy duty battery charger with trickle charge.
Hopefully it will be OK to use, just a matter of disconnecting the battery from the bike and connecting up.
Mr Hammers
PostPosted: 13:36 - 18 Oct 2010    Post subject: Reply with quote
Mine blew i'ts own fuse when I tried charging a (12v) bike battery. Worked ok on a car battery after I changed it though, but I won't be using for that again.
A Guide To Powerbands
ollieholt
PostPosted: 14:48 - 18 Oct 2010    Post subject: Reply with quote
yeah i would go for a trickle charge for a couple of hours and see how you get on. i normally bang mine on a massive charger we have at work specifically for 12v batterys. it constantly adjusts charge to the size fo the battery.
i cannot see it doing it much harm if you put it on the normal charge setting and just hooked it up for half an hour but keep a close eye on it, if its getting hot, warm is fine but hot, take it off and stand clear.
batterys can give off hydrogen when charging (well they do) so make sure its ina well ventalated place and there isnt any sources of ignition about. also keep anything that could burn well away, if it explodes or melts down you dont want things catching fire. many a building has been turned to dust due to battery charging accidents and many veicles ruined.
Laughing < This? Well this is just a day brightner.
moto
PostPosted: 16:39 - 18 Oct 2010    Post subject: Reply with quote
I put it on trickle and the charge light came on but when I checked an hour later the light was out, I thought the connections must be bad but when I connected it to the bike again it fired up straight away.
It is the original battery (2003) and I bought the bike in January when the shop charged it up, since then I have not had to.
I only get a chance to use the bike about every 2nd weekend and lately it turns the engine over slower but now fast agin.
Thanks for all the help.
Paxovasa
PostPosted: 16:43 - 18 Oct 2010    Post subject: Reply with quote
So you have two flat batteries Shocked
moto
PostPosted: 19:22 - 18 Oct 2010    Post subject: Reply with quote
Yes apparently. The other one is in a parallel Universe.
Sorry, I honestly have no idea why it posted twice, I only clicked submit once.
Anyway thanks to my research the battery problem is sorted Smile
doggone
PostPosted: 20:16 - 18 Oct 2010    Post subject: Reply with quote
Battery will often state a maximum (advisable) charge rate, typically just 1amp but agree you can charge faster but don't leave it on long.
When the bike is running the alternator will be pumping out 20amps or more.
You get better results from long slow charging.
headlamp
PostPosted: 10:48 - 19 Oct 2010    Post subject: Reply with quote
I use something called a Tricklemate - which I plug in once a week. As my riding consists of a (relatively) slow commute into the West End the battery never gets a full charge back - with the alarm and headlamp on all the time the battery will eventually discharge more then what is going in. They are not expensive and cwrtainly cheaper then a new battery once a year!
Using a mobile phone while driving a car should be made a capital offence!
The last post was made 15 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 70.67 Kb
