CBF 125 makes a bang.
locked
PostPosted: 08:44 - 21 Oct 2010    Post subject: CBF 125 makes a bang. Reply with quote
Recently I've noticed upon starting the bike in these cold mornings, after a couple of minutes with the engine running there is a bang on the right hand side of the bike.
Its happened every morning now for the past week. I can't see any physical signs of damage, no leaks or anything out of the ordinary. Engine oil is nice and full so I am kinda scratching my head here.
Its not due for a service for another 900 miles so i will ask the question then. In the mean time can anybody give me a heads up what it might be? Karma
PostPosted: 09:45 - 21 Oct 2010    Post subject: Reply with quote
Mechanical bang or a bang from the exhaust?
On such a new bike neither sound right. A bang from the exhaust would likely come from extra fuel landing in the exhaust unburnt then being ignited. Would suggest that it is running VERY rich when warming up or misfiring. However don't know enough about the CBF fuel system to comment beyond that.
locked
PostPosted: 10:16 - 21 Oct 2010    Post subject: Reply with quote
sounds more like a mechanical bang. It sounds like somethings ricochet off the engine and hitting the plastic cover. I'll get a video after work as it only happens after the bikes been standstill for a while.
PostPosted: 10:29 - 21 Oct 2010    Post subject: Reply with quote
Sounds odd. If it happened when you first moved the bike then I would suggest a brake pad sticking to the disk. Similarly the chain could slap the chain guard if way too lose and probably if wearing very unevenly (but I would be very surprised at this on a new bike).
PostPosted: 10:52 - 21 Oct 2010    Post subject: Reply with quote
Clutch possibly?
Whereabouts on the RHS of the bike.
PizzImperfect
PostPosted: 10:58 - 21 Oct 2010    Post subject: Reply with quote
My CBF at times makes a popping sound when cooling down or even sometimes warming up... But it's usually only a pop or 2 before it settles.. I assumed it was the metal expanding/contracting as it warms/cools...
How many miles have you covered mate?
Honda CBF125
locked
PostPosted: 11:21 - 21 Oct 2010    Post subject: Reply with quote
imagine your sitting on the bike, its the side where your right leg is resting on the plastic cover (not the fairing)
My bike does the usual expanding and contracting noise like all bikes do but this bang is defiantly not it.
Imagine using your knuckles and knocking your tank hard, thats the sound its makes but on the right side where the engine/exhaust is.
locked
only 1.6k miles
PizzImperfect
PostPosted: 11:39 - 21 Oct 2010    Post subject: Reply with quote
Very odd. I can't help you mate sorry Sad
Honda CBF125
DrDonnyBrago
PostPosted: 12:21 - 21 Oct 2010    Post subject: Reply with quote
I'd take the plastic cover off and see if it still does it, or see if you can isolate the noise.
Sounds like something is under tension and when things around it expand with heat it is released, maybe a clip or fastener or something. Perhaps something is warping with heat, like how a crap baking tray will ping into a new shape in the oven?
SillyMe
PostPosted: 12:57 - 21 Oct 2010    Post subject: Reply with quote
If it's not constant it could just the expansion of the exhaust or exhaust components, also as engines warm up the heat expansion of valves and valve clearances slightly affect combustion timing so you may even a very slight issue with back fire.
I get taps when my engine warms up which is unusual because engines normally become less noisy as they warm up. It turned out to be something totally unexpected but common on my bike. The noise coming from chain rattle sounds as though it's coming from other places on the bike too. Weird!
Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between)
Masked
PostPosted: 13:32 - 21 Oct 2010    Post subject: Reply with quote
Mine has done the same thing before, was the fairing popping in and out of the rubber lugs. Check that the screws holding the fairing on are done up properly, I replaced the screws on mine with allen bolts as the normal ones are really soft.
PizzImperfect
PostPosted: 13:54 - 21 Oct 2010    Post subject: Reply with quote
Maybe there's someone inside.. trying to get your attention...
https://thescenarios.org/wp-content/uploads/2009/08/men-in-black-alien.jpg
Honda CBF125
locked
PostPosted: 13:56 - 21 Oct 2010    Post subject: Reply with quote
hmmm funny you say that, I did add crash bungs on the bike a few weeks ago. It just seems odd, is the bike heating up that much its causing fairings to pop out of the lugs?
SillyMe
PostPosted: 15:02 - 21 Oct 2010    Post subject: Reply with quote
Thanks for the pic Pizz, another one for the collection.
If you ask me I think there's a little leprechaun dancing on his battery.
https://img177.imageshack.us/img177/4051/oie217336ydpa3pvc.gif
PizzImperfect
PostPosted: 15:09 - 21 Oct 2010    Post subject: Reply with quote
Take that casing off the side mate.. Ask the little fella what his problem is.
"Ttthhheee... Gaallaaxxyyy.... Iiiisss.... Uunnndddeerrr... Yyyoouuurrr... yyyooouuurrr *egh*... yoouurrr... Fuueell Caaappp"
Honda CBF125
SillyMe
PostPosted: 15:11 - 21 Oct 2010    Post subject: Reply with quote
LOL!
PizzImperfect
PostPosted: 15:14 - 21 Oct 2010    Post subject: Reply with quote
Or it could be something completely logical. But if it is what i said let me know and i'll give u £50 for him Thumbs Up
Honda CBF125
SillyMe
PostPosted: 15:41 - 21 Oct 2010    Post subject: Reply with quote
LOL!, And if it's what I said I want that pot of gold off him!
PostPosted: 15:43 - 21 Oct 2010    Post subject: Reply with quote
If it only has 1.6k on it it should still be under warranty, don't touch it let a dealers sort it.
locked
PostPosted: 16:08 - 21 Oct 2010    Post subject: Reply with quote
I think you hit the nail on the head there. I just gently punched the plastic cover where it meets the fairing lugs and its making that exact same banging noise.
The crash bung I added where the fairing screw use to be is nice and tight so I'm not sure whats actually making the noise.
I'll have to remove the panel later and take a proper look. Thumbs Up
locked
PostPosted: 16:10 - 21 Oct 2010    Post subject: Reply with quote
I'll just take the cover off to have a peep. sounds like a clip is loose or something. If it worse I'll book it in.
There is a gap of 1 year, 76 days between these two posts...
Olivernoob
PostPosted: 17:47 - 05 Jan 2012    Post subject: Reply with quote
sorry to drag out an old thread thought it was better than starting a new one! Im just wondering if you sorted this problem as i have the same thing and im not sure what it is?
scarborough_lad
PostPosted: 20:13 - 01 Apr 2012    Post subject: Reply with quote
Mine does the same, try tightening the bolts holding your heat shield to the exhaust.
The last post was made 14 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 3.27 - MySQL Queries: 13 - Page Size: 132.42 Kb
