Heated front windscreen not working on my car.
TimNorwich
PostPosted: 12:55 - 22 Oct 2010    Post subject: Heated front windscreen not working on my car. Reply with quote
Fiesta Mark 5 1.25
I press the button to turn it on and the light comes on, however it doesn't do anything (both sides of the screen not working) and the mist stays on the windscreen.
I don't think it could be the fuse as the light wouldn't be coming on?
Any help is much appreciated.
EDIT: I have looked in the owners manual and cannot find a fuse for the windscreen and believe it is on a relay instead?.
Thankyou very much,
Tim.
lukamon
PostPosted: 13:06 - 22 Oct 2010    Post subject: Reply with quote
no such thing as an unfused electrics in a modern car. the switch is on a different circuit to the actual window as yes, it will have a relay Thumbs Up
killa wrote: Im an ass man myself
blurredman
PostPosted: 13:50 - 22 Oct 2010    Post subject: Reply with quote
Just be lucky you had one. Wink
I don't have such luxuries as your car seems to have.
PostPosted: 13:58 - 22 Oct 2010    Post subject: Reply with quote
Would suspect there is a feed for the switch to power the on / off light and trigger the heated window (probably taken from the fused circuit for the dash lights). However it probably triggers a relay, and likely the relay has its own fused feed (or possibly has a fuse on the relay).
Chalky.
PostPosted: 13:59 - 22 Oct 2010    Post subject: Reply with quote
It's not supposed to clear mist. It's designed to melt ice.
TimNorwich
PostPosted: 14:09 - 22 Oct 2010    Post subject: Reply with quote
https://i206.photobucket.com/albums/bb106/timmyboynorwich/IMG00416-20101022-1326.jpg
In the manual under the "Relays in the central fuse box" it has the heated front screen down as "Relay II" - Green. But looking under the bonnet nothing is clear.
I went through all the fuses in the Central fuse box and they are all fine.
Chalky.
PostPosted: 14:21 - 22 Oct 2010    Post subject: Reply with quote
I used to have one...
The Artist
PostPosted: 15:35 - 22 Oct 2010    Post subject: Reply with quote
Mist is cleared by putting fans on with heat...
Those tiny little wires running through the windscreen melt ice...
PostPosted: 15:39 - 22 Oct 2010    Post subject: Reply with quote
Your car mists up because warmer moist air (and breathing generates plenty of that) condenses on the cold windscreen. Warming the windscreen prevents it condensing, so warming it up using either the heater fan or a heated screen should stop it steaming up.
Air conditioning demists the screen by drying the air, removing the moisture.
D O G
PostPosted: 15:43 - 22 Oct 2010    Post subject: Reply with quote
I bloody hate these things. Every so often I realise the wires are there and focus on them, which is rather annoying. Thankfully I very rarely drive a Ford so don't have the problem. Shame, as I'm a Ford man. Can't see me owning any Ford built afer 2000 or whenever it was they brought them in. Sad
TimNorwich
PostPosted: 16:36 - 22 Oct 2010    Post subject: Reply with quote
I don't even notice the wires Cool
carvell
Scuttler
PostPosted: 16:40 - 22 Oct 2010    Post subject: Reply with quote
Please don't tell me you use your heated rear window to melt ice!
The heated front window serves the same purpose as the heated rear window - to clear mist. As an added bonus, if you wait long enough, you'll find it melts ice too.
Yamaha TDM 850
lukamon
PostPosted: 18:13 - 22 Oct 2010    Post subject: Reply with quote
_used_ to have one in a fiesta st Sad im gonna miss it this winter Sad and btw, it does both, great for frosty mornings gone in 30 secs!
carlosthejack...
PostPosted: 19:42 - 22 Oct 2010    Post subject: Reply with quote
I love Mondeo. Had a Focus prior to the Megane I had last. Missed the heated screen sooooo much in the Renault. Glad I'm back with Ford, that screen's invaluable on a winter morning...
The last post was made 15 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 82.07 Kb
