| Deece55 |
 Deece55 L Plate Warrior
 Posted: 17:38 - 21 Oct 2010 Post subject: kh125 jets |
My d reg kh125 has recently had a big bore (due to damage caused by the autolube failing). It is now +1.5 on standard, and i need to find out how much i should drill the jets out by to ensure it runs balanced.  |
| SillyMe |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
 SillyMe Trackday Trickster
 Posted: 21:33 - 21 Oct 2010 Post subject: |
Just wondering why an expert hasn't answered your question yet?
Well the KH 125 is 125cc as standard 56.0 x 50.6 mm (2.2 x 2.0 inches).
You say it is now +1.5 on standard.
I could be wrong but to my logic this could mean either 125cc+1.5cc=126.5
Or + 1.5% of 125cc =1.875
125cc+1.875= 126.875, or to round this up 127cc
This means oversized piston kit and or rings have been installed. If this is the case then up jetting won't be required.
Was is the actual bore size in terms of cc or diameter? ____________________ Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between) |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 21:39 - 21 Oct 2010 Post subject: Re: kh125 jets |
| Deece55 wrote: | My d reg kh125 has recently had a big bore (due to damage caused by the autolube failing). It is now +1.5 on standard, and i need to find out how much i should drill the jets out by to ensure it runs balanced.  |
Right, well to countermand Esoteric1's ramblings, I'm going to offer the more appropriate (and fundamentally basic) advice: Don't Drill The Jets.
Buy some jets, and re-jet it with those by all means, but given that jets are typically measured in microns, do you honestly think that 1) you've got a drill bit precise enough, and 2) your hand is steady enough?
The most likely answer is no, to both of these questions.
Jets are cheap, and readily available. What's the carb size/make/model? Should have at least the make stamped on the side. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project
| serlant |
 serlant Brolly Dolly
| Blau Zedong |
 Blau Zedong Banned
| SillyMe |
 Posted: 22:07 - 21 Oct 2010 Post subject: |
Funny how loads of jump on the bandwagon doods jumped on this question after I answered it. It was asked hours ago and no else offered to answer the question.
Siily idiots asking people to die!
They have probably just finished work and maybe tiered.
What is the actual bore size in terms of cc or diameter? ____________________ Once made equal to man, woman becomes his superior.
| SillyMe |
 Posted: 22:49 - 21 Oct 2010 Post subject: |
Edit! ____________________ Once made equal to man, woman becomes his superior.
| N cee thirty |
 N cee thirty Banned
| SillyMe1 |
 SillyMe1 Derestricted Danger
| chris-red |
| chris-red |
| chris-red |
| nowhere.elysium |
 Posted: 13:46 - 22 Oct 2010 Post subject: |
| SillyMe wrote: | Funny how loads of jump on the bandwagon doods jumped on this question after I answered it. It was asked hours ago and no else offered to answer the question. |
The point is not to post a steaming pile of lies to fill time while waiting for someone competent to turn up, the point is to give accurate, sensible advice.
Can you do us all a favour and just shut up?
Also, OP - to summarise:
Don't hand-drill jets, it always ends badly. See how the bike's running, and check the state of the plugs. If they look OK, and the bike's not got any significant flat spots, you don't really need to do anything much to it, other than ride.
If, however, it's running lean (as denoted by whiteish plugs), you'll need to rejet it as soon as possible, otherwise you face the prospect of holing the piston. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| Syris the Indomitable |
 Syris the Indomitable Crazy Courier
| nowhere.elysium |
| chris-red |
| Deece55 |
| nowhere.elysium |
 Posted: 11:04 - 23 Oct 2010 Post subject: |
| Deece55 wrote: | Oversize is measured in mm. As for drilling the jets i'm not quite nieve enough to try and do by hand! I have access to laiths, borers and milling cabinet's at work so can sort most things if know sizes.
Will check the carb numbers when get home in few hours. Hard to tell if running lean or rich at mo as using heavy tank mix whilst running in the new Piston and rings. Mixture was always ok before the piston melted to the cylinder, but bike ran weasy with flat spots all over, was +0.5mm oversized then so pretty sure will need jetting now! |
Sorry - I wasn't impugning your intelligence, but we do get some real numpties on here, sometimes, as has been amply demonstrated my Esoteric1, or whatever he's calling himself now.
As I've said, you should be able to get jets cheaply - if you find out what the standard sizes are, buy a range of a few that are larger; at least this way, you make no destructive changes, and it allows you to fine-tune the fuelling.
If the piston melted to the cylinder, it's running horribly lean. I don't know enough about rejetting to be able to make authoritative statements about what jet sizes to get, but I can comfortably tell you that the difference in sizes is on a micron scale, so it's really not worth trying to do it yourself, regardless of the kit you've got. Also, as I've said, destructive changes like drilling are pretty hard to undo. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| Deece55 |
| N cee thirty |
 N cee thirty Banned
| Deece55 |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 11:13 - 25 Oct 2010 Post subject: |
logic says its running lean,
i own a couple a1 model kh125's and out of the box they are a touch on the lean side, any 2 stroke is better off running a bit rich than running at all lean, compounded with it being a air cooled engine,
according to my calculations you are now up to 131.4 cc up from 124.6cc roughly a 5%increase in capacity,
that is definite re-jetting territory
im not sure what main you are running, i'd say around the 95 mark, id go to about a 105 may be even bigger
Esoteric1 if your a mechanic, ill fucken eat my old boots,
you need to shut up, and do some research before you go and spout off and give out shit infomation ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
The last post was made 15 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
