| nutter |
 nutter Nitrous Nuisance
| P.addy |
 P.addy Red Rocket
| Kickstart |
 Kickstart The Oracle
 Posted: 14:40 - 22 Oct 2010 Post subject: |
What kind of control unit do they have? If the older style ones that do not turn themselves off automatically then I would wire them through a relay, taking their power directly from the battery. I would use a wire from the rear brake light switch to trigger the relay (make sure you use the right wire at the brake light switch, otherwise you will have grips that only work when you are braking which would be even worse).
This way you are putting no real extra load on the wiring anywhere but will still have them turn off automatically when the ignition is off.
| nutter |
| Kickstart |
 Posted: 16:55 - 22 Oct 2010 Post subject: |
Easy to add a fuse. Halfords will sell you a fuse holder you can wire in. Basically +ve terminal to fuse holder, through fuse and to +ve feed on heated grips (might not matter if they are just a crude switch), and then the other wire from the grips to the negative battery terminal (or any secure earth on the frame).
I would advise a relay. Far too easy otherwise to completely kill the battery, or suffer from someone switching them on when you are parked.
| stinkwheel |
| nutter |
 Posted: 17:20 - 22 Oct 2010 Post subject: |
Thank you both.....think I'm going to fuse and relay it from the battery.....but i've going to have to wait 2 weeks til payday (I have 31p to my name till then lol
Thanks
Mark ____________________ Current bike is kawasaki ZR7 - Previous is CBR 125 (40,000 long long miles). Mod 2 passed 11/08/11 - Hope to become an instructor |
| Adam.I |
 Adam.I World Chat Champion
| Kickstart |
| Phoenix |
 Phoenix Twisted Firestarter
 Posted: 18:24 - 22 Oct 2010 Post subject: |
I've had a couple of sets, a pair of Daytona ones included which were pretty good, transfered them across 2 bikes aswell. The switch has high, low and off, if you set them to low they will never get warm so you have to set them to high and eventually they'll get too hot so you have to set it to low, they then cool down until they're virtually useless so it's back on high again, pain the backside. They only took a couple of mins to get nice and hot on high.
As you've already decided, a fuse and a relay is the way to go, it gives it it's own fused circuit so you don't risk blowing other circuit's wiring and it also prevents you from forgetting to turn them off.
To be fair to your dad, heated grips often tell you in the instructions to wire them directly into the low beam circuit using scotch locks, the circuit is perfectly capable of supporting them as they only draw an extra 50watts and as long as you ride with your lights on then then they'll only be off when you switch to high beam, if you're riding for long enough periods with high beam on for them to cool down then you either live in the middle of nowhere or you're blinding everyone. |
| nutter |
| Noxious89123 |
 Noxious89123 World Chat Champion
| molex |
 molex Renault 5 Driver
| stinkwheel |
| nutter |
| stinkwheel |
| nutter |
| stinkwheel |
 Posted: 10:37 - 24 Oct 2010 Post subject: |
A 4-pin automotive relay costs £2.75 delivered on ebay. I really can't think of a good reason not to use one
You connect terminal 30 to the battery, terminal 87 to the switch for your grips, terminal 85 to one of the switched lives and terminal 86 to either the frame or battery negative.
Connect the other wire from the grips to either the frame or the battery negative.
That's it, everything else is working out where to put it and routing the wires.
This is the right way to do it. If you do this, your grips will work whenever you switch them on, the headlight will work as normal and it will be impossable to leave the grips switched on when you park the bike. You will not need to worry about blown fuses or melted wiring.
| Quote: | Well to prevent overloading I was going to put the fuse after the grips come off the main circuit, would I be able to run it in parrel to the radiator, saving the need for the relay, and so if the circuit did get overloaded only the grips would fail |
Good thinking, but not entirely correct. You are still running both componants through the 10A fan fuse. Say (for simplicity) you added a 5A fuse where you branched off the grips.
If the grips were drawing say 3A and the fan was drawing 5A, you could sit there quite happily all day, 8A of draw, no worries. BUT say the fan motor was playing up and got a bit stuck (they sometimes do) and it drew 8A to get it moving, this would be perfectly fine under normal circumstanmces, there is a 10A fuse. However, the grips are still happily drawing 3A and there is now 11A in the fan circuit. Your fan fuse blows. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
The last post was made 15 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
