Service Costs
MikeyC
PostPosted: 10:32 - 28 Jul 2004    Post subject: Service Costs Reply with quote
How much will I expect to pay on a full service on a Gixxer 6? Also, how long will it take?
Cheers Thumbs Up
craigT19
Jolly Green Giant
PostPosted: 13:14 - 28 Jul 2004    Post subject: Reply with quote
i dunno about the gixxer but a full service on my ninja cost about £300 and took around 3 hours
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
byke95
PostPosted: 13:22 - 28 Jul 2004    Post subject: Reply with quote
Not really an answer (sorry) but more of a related question:
What is a 'full service', is it different from a 'service'?
Mine's about due for a service to and I've no idea what say or expect for my money! Embarassed
dainesefreak
PostPosted: 13:23 - 28 Jul 2004    Post subject: Reply with quote
A 4000 miler on the Blade is about £90 or so.
craigT19
Jolly Green Giant
PostPosted: 13:54 - 28 Jul 2004    Post subject: Reply with quote
A full service will cost a lot more than £90 mate.......expect to pay out soon Laughing
A full service generally includes.
New brake fluid
fork oil (depending on milage u shouldnt need to worry yet)
Oil
plugs
Air filter
Brake pads (if needed)
Carb balancing
valve clearances and timings etc
Shims (if needed)
Cam chain tensioning (if needed)
drive chain and sprocket check and adjustments (again if needed)
Obviously getting to the valves on most modern sports bikes is a right bitch hence why it costs a bit in labour Thumbs Up
Robby
Dirty Old Man
PostPosted: 14:02 - 28 Jul 2004    Post subject: Reply with quote
Generally a full service or major service includes valves and carb balance, whereas a minor service is really just oil and filters and a general chassis check over - bearings and the like. Spark plugs sometimes done on a minor.
Also worth noting that it should work out cheaper from an independant garage, but if the bike is worth something, get them to use a genuine oil filter. A franchised honda dealer will use honda parts and charge honda labour.
byke95
PostPosted: 14:10 - 28 Jul 2004    Post subject: Reply with quote
So...
A full service (i.e Craig's £300 one) is the one done every 5000-6000 miles and the 'service' (i.e Freak's £90 one) is the small one done every 3000 miles (oil change, air filter, spark plugs)?
Robby
Dirty Old Man
PostPosted: 14:22 - 28 Jul 2004    Post subject: Reply with quote
Well valve clearances only need checking/adjusting every 24k ish on modern bikes. Carb balance should be checked ever 10-12k. Brake fluid every 2 years, but it doesn't always need changing - theres a tool you dip into the resevoir, it tests the fluids boiling point and tells you if it needs changing or not.
So basically on any fair size modern bike you should have a minor service every 4k and a major every 12, and the uberservice at 24.
Of course, after 30k bikes are worthless, so the second uberservice is rarely done on anything but expensive tourers and BMWs.
craigT19
Jolly Green Giant
PostPosted: 17:36 - 28 Jul 2004    Post subject: Reply with quote
heres a pullout from my owners book...yours should have one also.. but i wouldnt have thought it would be much diferent to mine
hope it helps to clear things up Thumbs Up
The last post was made 21 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 59.77 Kb
