| Doovy |
 Doovy World Chat Champion
 Posted: 12:26 - 23 Oct 2010 Post subject: Headlight bolts rounded off |
Well, due to the numpty that put on the dominator headlights onto my hornet (before i bought it), the bolts holding the headlights in are rounded off.
https://i2.photobucket.com/albums/y41/doovydoo/utf-8BSU1HMDA0NjUtMjAxMDEwMTQtMTMwNy5qcGc.jpg
I want to fit a screen, which mounts in between the headlight bracket and headlights, with the bolt holding it all in place. I also have new bolts ready to go in, i just need the old ones out!
ideas please?
I have thought of cutting a groove into the bolt head (i dont have a dremel though) and trying to undo it through that.. might try later with a small saw but dont know if it will get to it. dont want to try drilling really..
thanks in advance  ____________________ Yamaha RXS 100 > Honda CD 250 > Honda Hornet 600 > Honda CBR 600RR > Yamaha RXS 100 > Kawasaki ZX6R J2 > Yamaha FZ1 |
| Syris the Indomitable |
 Syris the Indomitable Crazy Courier
| willi |
 willi Spanner Monkey
 Posted: 13:44 - 23 Oct 2010 Post subject: |
drill a hole straight into the center and buy a easy out.
are you sure you cant get a allen or hex key to grab there? appears to be enough to grab onto!
they are only soft bolts you could use a old flat screw driver and hammer by hitting the side of the bolt with screw driver and tap it around with the hammer.you will need to cut into the side of the bolt so the screw driver bites in while you hit it with the hammer. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/
wat goes around comes around. |
| Vincent |
 Vincent Banned
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| Vincent |
 Vincent Banned
| nowhere.elysium |
| Doovy |
 Posted: 15:06 - 23 Oct 2010 Post subject: |
thanks for replies everyone.
turns out the one in the picture had just enough left to turn with the right size allen key, but the other one is really rounded.
i have tried a junior hacksaw but due to bracket positioning and indicator placement it's not really possible.
have tried the screwdriver / hammer combination too but not really got anywhere (didnt really give a proper go)
will go for the torx bit idea! thanks nowhere.elysium, i'm slightly disturbed by your knowledge of my limberness.. perhaps i drank more that night than i remember..
good times
back off the garage....
| Doovy |
 Posted: 16:25 - 23 Oct 2010 Post subject: |
fail.
headlight bulb now blown.
the bolt still wont undo.
and the screw to undo headlight front cover to replace bulb is all rusted up and thread gone too.
taking to bike shop next week anyway for some crash repairs so get them to do this at same time.
i cba for this, i've got a dissertation to write lol ____________________ Yamaha RXS 100 > Honda CD 250 > Honda Hornet 600 > Honda CBR 600RR > Yamaha RXS 100 > Kawasaki ZX6R J2 > Yamaha FZ1 |
| Doovy |
 Posted: 22:40 - 23 Oct 2010 Post subject: |
| c_dug |
 c_dug Super Spammer
| Doovy |
| Walloper |
 Walloper Super Spammer
 Posted: 11:03 - 24 Oct 2010 Post subject: |
Awe shite...
I just saw this thread and was about to suggest breaking a hacksaw blade to make a slot in the head so you can attack it with a big effin screwdriver but the Dammed Dremel got there first.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Robby |
 Robby Dirty Old Man
| Walloper |
 Posted: 12:38 - 24 Oct 2010 Post subject: |
Photo quality Fail.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Vincent |
 Vincent Banned
| Walloper |
| Vincent |
 Vincent Banned
 Posted: 12:56 - 24 Oct 2010 Post subject: |
Looks good waloper but might be a drain on the battery  |
| Walloper |
| Doovy |
 Posted: 16:53 - 24 Oct 2010 Post subject: |
| nowhere.elysium |
 Posted: 19:19 - 24 Oct 2010 Post subject: |
| Doovy |
| tahrey |
 tahrey World Chat Champion
 Posted: 14:45 - 26 Oct 2010 Post subject: |
excellent. Good work with the dremel too.
Allen bolts are shite and used in far too many places (they're good for tight spots where a hex-head wouldn't work, but as demonstrated this clearly isn't the case for headlamps). I think I've come across almost as many rounded out ones as those which actually work.
My favourite is the torx trick, or in moments of desperation and severe rounding, abusing a spline bit. Had to do it only a couple days ago in fact, when hacking an old back-projector display unit apart to recover its tasty multipurpose guts. Torqued up to about five thousand newton meters AND with threadlock on a 5mm allen. Nothing doing.
Get a suitable size torx in there (one that JUST ekes into place), the spiky bits fit into the corner notches of the allen socket, but can't move along the flat bits, and the much sharper profile means they dig into the friable metal and stick well enough to turn the bolt, rather than filing it away and making things worse. Devil of a job to free the bit from its cold weld of course (mole grips & stuff), but worth it. |
The last post was made 15 years, 352 days ago. Instead of replying here, would creating a new thread be more useful? |
