cant get on with new rs 125
discusdan
PostPosted: 17:35 - 21 Oct 2010    Post subject: cant get on with new rs 125 Reply with quote
hi im really struggling to use my new rs 125 , i just keep stalling it and it keeps cutting out on me. im used to riding a 4 stroke pulse adrenaline and just dont know what to do
PostPosted: 17:38 - 21 Oct 2010    Post subject: Reply with quote
Use the revs. Make sure you keep the revs up (by slipping the clutch) when moving off. With a bit of practice you can hold the revs at about 4k to move off, feeding the clutch and throttle to keep the revs there until the clutch is fully released.
The RS (certainly in full power form) has pretty much nothing under 2500rpm as the power valve is open. It just does this so that around town it gets regularly operated to try and stop it sticking. I suspect they assume nobody will try and ride it at such low revs.
discusdan
PostPosted: 17:42 - 21 Oct 2010    Post subject: Reply with quote
hi thanks for reply Thumbs Up so i slip the clutch by revving quite high and release it slowly? i seem to be setting off at about 5mph and chugging up the road which is dangerous i darent go on the main roads at all.
PostPosted: 17:52 - 21 Oct 2010    Post subject: Reply with quote
Practice with the clutch.
You do not rev the engine and just let go of the clutch. What you need to be able to do is control the revs using the clutch. You could easily still be slipping the clutch at 15mph (around 5500rpm in first), and certainly at 5mph. Feed the clutch out slowly, and be prepared to pull it in slightly again if the revs drop too far.
The clutch will take a lot of abuse (far more than a car clutch) so do not worry too much about it.
Fluzzel
PostPosted: 18:27 - 21 Oct 2010    Post subject: Reply with quote
It will take quite a bit of practice but definetly listen to Kickstart Very Happy I've been riding my rs125 forlike 6 months and sometimes I forget and mess up to but be prepared to mess up a lot and stay calm Very Happy
MinhDinh
PostPosted: 19:19 - 21 Oct 2010    Post subject: Reply with quote
Stay on 4K upwards with the clutch lever on the biting point. Then let go slowly and move the bike and rev higher.
Hit the G spot. Wink
discusdan
PostPosted: 20:03 - 23 Oct 2010    Post subject: Reply with quote
big thanks to everyone for the help im now not stalling it and setting off a bit quicker Thumbs Up also what sort of revs and speed should i change up to say 3rd gear? is it ok to stay in the powerband? any more advice very very welcome Cool
also my dad stripped the bike down and found a dodgy electric connection that would cause the bike to be completely dead when i put the key in and if you tapped it the lights would come on so he soldered it and re did the wiring and now it doesnt cut out Thumbs Up
MinhDinh
PostPosted: 20:47 - 23 Oct 2010    Post subject: Reply with quote
Great stuff on your dad finding the problem.
Yu will learn what revs to change at, it's quite a patterned gear change I found, hit a certain speed and sound or feel, then change.
PostPosted: 10:18 - 25 Oct 2010    Post subject: Reply with quote
Depends how quickly you want to go.
When the engine is cold then keep the revs down. Keep it below about 5k.
However once properly up to temperature I wouldn't worry too much about revving it. If you want to go quickly then use all the revs available.
For example if cruising I would sit around 8k, so as I speeded up and slowed down a small amount the power valve opened and closd, stopping it sticking.
The last post was made 15 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 63.26 Kb
