Anti-mist visor spray
Killer Rat
PostPosted: 14:20 - 25 Oct 2010    Post subject: Anti-mist visor spray Reply with quote
got this Bob Heath stuff and it works great on the visor, however i still have a problem with my spectacles misting up.
Is it ok to use the spray on these aswell? My spectacle lenses are made of plastic so don't want them to melt preferably.
Thanks in advance.
DrDonnyBrago
PostPosted: 14:39 - 25 Oct 2010    Post subject: Re: Anti-mist visor spray Reply with quote
Thanks in advance.
Your lenses are probably polycarbonate, I use this material to store all sorts of nasties in the lab, so long as the demister doesn't stink heavily of aromatic solvents or nail varnish remover it will be fine.
So you know though, washing up liquid also works great as a visor demister Thumbs Up .
Killer Rat
PostPosted: 14:54 - 25 Oct 2010    Post subject: Re: Anti-mist visor spray Reply with quote
Great tip that Thumbs Up
LeeR
PostPosted: 20:23 - 25 Oct 2010    Post subject: Reply with quote
I use Bob Heath visor spray on my specs and as long as they're not coated (as this prevents the spray adhering) then it works well for a day or so. Thumbs Up
My claim to fame: Austin Vince nicked my pen...
tahrey
PostPosted: 15:08 - 26 Oct 2010    Post subject: Reply with quote
any kind of dilute soap works quite well actually, including a finger rubbed across a bar of hand soap. so long as you rub it dry afterwards. soam scum residue is even harder to see through.
dunno why this is...
however if your visor allegedly has an anti-mist coating, be wary of doing this across the whole thing. as the carpet cleaner bottles say, test it on a small area first. it did something very wierd to the visor on my Trip. Or maybe it was the other way round. The "coating" seems to give the visor a slightly rough surface on the inside and cloths/paper towels don't take kindly to being rubbed on it.
PostPosted: 17:41 - 26 Oct 2010    Post subject: Reply with quote
I've always used washing up liquid. Great for keeping the visor clear. Speaking of which.... Gotta go do that tonight when I clean my visor for the cornwall trip tomorrow.
Dazbo666
PostPosted: 18:00 - 26 Oct 2010    Post subject: Reply with quote
I need to do mine after my Cardiff to Brecon/Builth trip yesterday.
Insect splatting action in October, who'd have thought of it... Rolling Eyes
Word of the day : DILLIGAF
el_oso
PostPosted: 18:08 - 26 Oct 2010    Post subject: Re: Anti-mist visor spray Reply with quote
washing up liquid usually contains salt and scratches your visor to shit
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 18:48 - 26 Oct 2010    Post subject: Re: Anti-mist visor spray Reply with quote
Does it? Confused
I've used washing up liquid for years on all my visors, it's never caused any scratching. Smear on, then under a running tap to remove the washing up liquid. It results in a crystal clear visor.
Killer Rat
PostPosted: 13:27 - 27 Oct 2010    Post subject: Reply with quote
Tried the washing up liquid and the visor spray, but still managed to get my glasses misty.
Half the problem is that i wear a balaclava now in these colder months, it's a dilemma of wether to stomach the brain freeze and see the road clearly or keep warm and put up with blurred vision.
It could be time for me to invest in some contacts.
DrDonnyBrago
PostPosted: 13:41 - 27 Oct 2010    Post subject: Reply with quote
Flying goggles ftw Thumbs Up
https://www.factsurplus.co.uk/images/10382_orig.jpg
Killer Rat
PostPosted: 13:54 - 27 Oct 2010    Post subject: Reply with quote
How do you do it? genius!
Gogs will save me a fortune over contacts, will they fit over specs though?
el_oso
PostPosted: 17:09 - 27 Oct 2010    Post subject: Re: Anti-mist visor spray Reply with quote
ms51ves3 wrote:
Does it? Confused
some do, some don't. depends on brands. imo. not worth it unless you know that it doesn't contain salt. i used to use washing up liquid. never had a problem until i went to uni and changed the washing up liquid.
there was one other household product that worked really well at stopping my visor fogging up. can't for the life of me remember what it was. it may have been hairspray or something.
can you not just buy a pinlock? usually about £10. AVG also do anti-mist visors. they are not quite as effective as pinlock. they do fog up alightly around the bottom half of the visor, but it disappears instantly.
Duke 390
PostPosted: 19:05 - 27 Oct 2010    Post subject: Re: Anti-mist visor spray Reply with quote
Nearer to £20.
tahrey
PostPosted: 17:50 - 30 Nov 2010    Post subject: Reply with quote
Doesn't your visor need to be made to accept the pinlock insert though? Or at least you need to be handy with a drill and hope the curvature is correct?
If I could get a pinlock-compatible replacement visor for mine at £10-20 I'd be well chuffed (even better if it came with an anti-fog insert already), any good places to look?
AFAIK, the word on the street about salt in washing up liquid is that the cheaper brands tend not to have it, or at least have less, as it's a comparitively expensive ingredient, and is why they seem thinner and "more dilute". The premium stuff will have loads in to thicken it and make you think you're getting a more concentrated product. I never had trouble getting tons of bubbles out of a few drops of my third-the-price Lidl liquid.
Not sure whether or not it's "actual" salt (ie sodium chloride) or some other similar thing (like whatever's in dishwasher rinse-aid?), but either way, if it ends up crystallising and causing scratches - rather than being individually suspended atomic ions of Na+ and Cl- - either they've drastically overdone it, or you've allowed it to dry too much. Salt doesn't exist as the chunky, sharp edged grains you shake on your chips unless it's completely dried out.
Make sure the detergent is really quite dilute, and rub it off immediately and fairly forcefully with a soft, non-catching cloth. It doesn't take any noticable amount of time to take effect. Works wonders on my bathroom mirror, as I said above - and no scratches.
The last post was made 15 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 88.83 Kb
