CG125 Fork seals
deleted111
PostPosted: 12:58 - 24 Oct 2010    Post subject: CG125 Fork seals Reply with quote
I got my CG back in August with the intention of doing it up for when I get my CBT.
I got my CBT yesterday, and now I'm looking at sorting the forks out on the bike.
They're dead. No oil, fork seals are well and truly shag*ed.
Is it possible for me to take the forks apart and fit new seals and oil myself?
Really can't afford to pay through the nose for a bike garage to do it.
Any help/guidance greatly appreciated.
Karma
Cheers in advance,
Steve.
deleted111
PostPosted: 13:09 - 24 Oct 2010    Post subject: Reply with quote
My bike is a 99 model.
Would these be okay to use?
Do I need any sort of specialist tools or with a bit of guidance is it do'able in my garage next sunday afternoon?
Not planning on getting dust seals as my bike's never had them, and it's got gaiters.
PostPosted: 13:55 - 24 Oct 2010    Post subject: Reply with quote
It's perfectly do-able but can be a bit of a fiddle.
I'm not exactly sure howe CG forks are arranged, the most difficult bit is usually taking out the bolt that goes up through the bottom of the fork (under where the wheel spindle is now). The bit it's bolted to is free to turn so you land up turning the whole lot instead of undoing the bolt.
That said, I'm by no means certain this is the arrangement in a CG. Smaller bikes sometimes just have the whole lot simply pushed together, you just take the circlip out from above the seal and batter them apart. I'd need to see an exploded diagram to see what the arrangement is.
The important thing is that the stanchion is in good nick. If it's all pitted/rusty, the new seals will fail too.
Usually the only special tool you need is a bit of pipe that's wider than the stanchion and narrower than the outside of the seal to drive the new seals in with.
Digit
PostPosted: 14:21 - 24 Oct 2010    Post subject: Reply with quote
The first piece of advice I'd give anyone in this position is simple, buy a manual!
The exploded drawings will help familiarise you with the internal workings, then any info from the board will also make more sense.
Roy.
Happy daze!
pepperami
PostPosted: 14:59 - 24 Oct 2010    Post subject: Reply with quote
I usually use a socket Thumbs Up
salty21
PostPosted: 15:27 - 24 Oct 2010    Post subject: Reply with quote
did the fork seals on my cg yesterday, easiest fork seal change i have ever done, mainly due to the lack of bushes in cg forks, this means you can change the seals with the leg out, doesnt get much easier than that.
just undo the 6mm allen bolt on the bottom of the fork leg (you may have to do this with the spring still in as the damper rod may just spin with the bolt without the pressure of the spring holding it.
Then undo the top bolt and remove all the oil and internals taking note of the order (not that there are many bits in a cg fork). separate the fork and swap the seals.
put everything back in the same order it came out and top up with oil, i found if you fully compress the fork leg and insert the spring then the oil level should be roughly 10mm from the top.
deleted111
PostPosted: 17:47 - 24 Oct 2010    Post subject: Reply with quote
Cheers for the input guys.
I do infact have a Haynes manual for my bike but it is for the 76-78 model (I think). Definitely cracking on 2 decades out of date, but will this tell me how to do them sufficiently?
Will go scout for the manual and report back!
Karma
Cheers,
Steve
blurredman
PostPosted: 17:49 - 24 Oct 2010    Post subject: Reply with quote
my haynes manual for my CG is years 78-06.
Where'd you get yours from ? Shocked Laughing
deleted111
PostPosted: 17:58 - 24 Oct 2010    Post subject: Reply with quote
Haha. Mine came with the bike, the previous owner never rode it from what I've gathered, but was just a tinkering man.
Bike needed sorting, he sorted it partially but then gave up on it and sold it because it didn't fit in with the old Brit bikes in his garage.
Found the manual, just seeing what it has to say about the forks now.
Anybody know of any online manuals if this turns out to be crap?
Cheers!
WildGoose
White Van Man
PostPosted: 18:18 - 24 Oct 2010    Post subject: Reply with quote
How do you solve the problem of the spinny bit spinning when you are trying to undo the bottom bolt? I am about to have this fun myself.
Also, how do you tighten it back up again when you are putting them back together?
pepperami
PostPosted: 18:22 - 24 Oct 2010    Post subject: Reply with quote
you two can swear and curse and then come back on here and tell us how you did it , with lots of pics Thumbs Up Smile Thumbs Up
salty21
PostPosted: 19:28 - 24 Oct 2010    Post subject: Reply with quote
undo the bolt before you remove the spring.
tighten the bolt after you have fitted the spring.
the pressure of the spring on the damper will hold it for you Thumbs Up
also when you come to pour out the old oil remember the damper will fall out so be ready to catch it
TimNorwich
PostPosted: 20:17 - 24 Oct 2010    Post subject: Reply with quote
When I had my 2005 CG project I paid £100 for some almost new forks off eBay, I'm sure because your bike is older you could find 2 forks for a fraction of what I paid.
deleted111
PostPosted: 20:35 - 24 Oct 2010    Post subject: Reply with quote
I'll have a look on eBay man, but cost is my major concern.
Trying to spend as little as possible, so I was hoping that I'd only have to buy seals and oil, bringing the grand sum to <£20.
But if I find it overly difficult to do, I'll definitely consider buying newer forks.
Cheers,
Steve.
PostPosted: 21:11 - 24 Oct 2010    Post subject: Reply with quote
How do you get a socket to fit over the fork stanchion?
I use a 3 foot length of plastic wastepipe and a mallett.
Teflon-Mike
tl;dr
PostPosted: 22:27 - 24 Oct 2010    Post subject: Reply with quote
Get the correct manual, they made a lot of changes to the CG over the years.
But in the meantime, this may help. Wrote a How-To on the topic doing snowies CB125.
HOW To: Overhaul the front forks / Replace fork Seals
Yes, undo, or at least just loosen, the damper rod bolts in the bottom of the slider before either undoing the yoke clamps or the stansion caps. Remove stansion caps and springs before undoing joke clamps and dropping the legs out, to give you purchase to undo stuff!
salty21
i also use the waste pipe trick, but i find you have to slice it lengthways so it will spread to a larger diameter, also i have to double it up for the cbr, as in 2 pieces of pipe cut down the length, one ontop of the other.
The beauty of cg forks is they have no bushes so the stanchion can be removed with the seal still in place, thats why fitting them is a doddle as you can use a large socket to bash them in.
I dont have a large range of big sockets only the specific sizes i need for various spindles so didnt actually have the correct size for the cg seal.
You need a 28 mm ish to fit nicely, i made do with a 24 iirc, but it was still way to easy so i wasnt complaining.
deleted111
PostPosted: 10:20 - 25 Oct 2010    Post subject: Reply with quote
Cheers for the help guys.
Gonna order my seals and oil on friday I think, when I get paid.
Will start taking the bits apart when I get home today.
Rob mate that'd be awesome if you could fella, thanks
want me to PM you my email?
Cheers,
Steve.
deleted111
PostPosted: 11:36 - 25 Oct 2010    Post subject: Reply with quote
PM sent Thumbs Up
Won't be able to have a look at it until I get home but cheers man.
Karma
Steve.
map
Mr Calendar
PostPosted: 14:47 - 25 Oct 2010    Post subject: Reply with quote
If you're stuck the this site offers some advice. Look in the Servicing, Suspension and the Winter Riding, Fork Gaiters sections.
I'm sure you've already found the pdf manual for 1977 to 1991 CG125 models (click here). Might give a few pointers, I doubt they've changed radically.
pepperami
PostPosted: 19:26 - 25 Oct 2010    Post subject: Reply with quote
When i`ve seperated the lower leg from the stanchion........ Hmmm? just looked at my forks and the`re not as easy as my GT250`s or my TS250`s.
Cos with them you just undid the bolt at the bottom of the forks and the legs could be pulled away from the stanchions, leaving the forks seals in the top of the legs.
deleted111
PostPosted: 11:34 - 26 Oct 2010    Post subject: Reply with quote
Okay this is more challenging than I initally expected.
I've not yet ordered the seals or the oil, I just wanted to pull the forks apart ready for when I did.
I've just been out to the garage with the intention of pulling the forks apart to bring inside to work on, as it's warmer and I can't feel my bloody fingers in the garage.
ANYWAY, I took the front wheel out, no problem.
Then tried to take the forks out. I've undone one bolt (fairy large thing) on the top yoke which showed me a spring. And a lot of oil dripping on to the floor as a result.
Am I doing something wrong? Or should I remove the springs on both sides? Remove my headlight, indicators etc also?
A stumped Steve.
deleted111
PostPosted: 11:35 - 26 Oct 2010    Post subject: Reply with quote
Also, please see my 2nd post. Those are the seals I'm thinking of ordering this afternoon.
The last post was made 16 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 135.45 Kb
