NTV troubles - new plugs, oil, fuel filter & coolant = f
ttr
PostPosted: 22:27 - 24 Oct 2010    Post subject: NTV troubles - new plugs, oil, fuel filter & coolant = f Reply with quote
Hi there
Recently decided to give the NTV a bit of attention, changed the oil & filter, fresh coolant, new plugs and chucked a new fuel filter on there (the old one looked a bit skanky).
Tried firing it up afterwards, ran fine for a few seconds, then cut out (presumably when the carb drained).
After that wouldn't start for shit, so, assuming it was that fuel wasn't getting to the carb, I swapped the filter back to the old one to check if that was the problem.
It then started, but would only just about idle, given any revs it would sputter and die.
I still think this must be fuelling, but I'm really not sure where to look next. The only other thing I changed that might affect it (that I can see anyway) is the plugs, but they're brand new and it was running (reasonably) well before on aged horrible ones.
Any thoughts? I'm stumped!
Cheers in advance!
GS125-> NT400->VFR400->CRM250->Z750 + GS125->NTV650 rat + VMX1200->GSF600 + GPz550
PostPosted: 22:34 - 24 Oct 2010    Post subject: Reply with quote
Did you turn the fuel tap back on when you put the tank back on?
If it's anything like my VFR tank, there is a fuel shut-off tap up under the tank that lets you remove the tank without draining it.
I recently had my tank off to change the shock. Bike was doing exactly what you just described. Then I realised the tap wasn't flicked on properly but it took me a bit of head scratching.
Certainly sounds like fuel starvation anyway. Check the usual trapped fuel line, blocked breather, disconnected vacuum hose (no petrol in the tank? Wink ).
Got the filter in the right way round?
ttr
PostPosted: 23:43 - 24 Oct 2010    Post subject: Reply with quote
Hi there
Filter's the right way round, and I've tried the tank on res & on positions just in case (it is quite full also).
I don't belive I have trapped any lines as I haven't disturbed any barring the ones between the tank, filter and pump. I checked these repeatedly when it started being difficult!
Cheers again!
PostPosted: 23:57 - 24 Oct 2010    Post subject: Reply with quote
I wonder if it's possible for a fuel pump to get airlocked? Or an airlock further up the line.
Not sure how you'd check.
It would be nice if there was some way of checking that fuel is actually flowing to the carbs so you can rule that in or out. I presume detaching the fuel line at the carb end, putting the end in a jam jar and cranking the engine over would give you some idea about the fuel flow or lack thereof. Never tried this though so if it catches fire, don't blame me.
Are both pots firing. Both exhausts headers getting hot? Stick a drop of oil on each and watch for it burning off.
c_dug
PostPosted: 01:06 - 25 Oct 2010    Post subject: Reply with quote
When we took the_godfathers tank off of his Thundercat we had issues getting the fuel to flow past the pump again, I think we fed some directly into the carbs first to make sure that was the issue.
Really unhelpful but I can't remember how we sorted it in the end Confused Laughing
Will get him to take a look at this and see if he remembers.
Still you can check if it is a problem with an air lock in the pump by bypassing it completely and see if it starts like that, you may need to hold the tank up a bit for it to work, guessing the pump is there because the tap is below the level of the carbs or something hence having to raise the tank a bit.
Odie
PostPosted: 01:20 - 25 Oct 2010    Post subject: Reply with quote
If you have changed all 4 plugs check to make sure you have not pulled the wires that feed the front coil.
el_oso
PostPosted: 11:27 - 25 Oct 2010    Post subject: Reply with quote
check that you haven't been a dipstick (like i was) and crushed the fuel line under your fuel tank.
you can make an external fuel tank out of a bottle of water and a length of hose to check
keep the hose in the fuel and above the pump. the hose needs to be filled with petrol as well. gravity will feed fuel through the line when you crank the engine over
Duke 390
Car: Jeep Wrangler 4.0L
map
Mr Calendar
PostPosted: 15:01 - 25 Oct 2010    Post subject: Reply with quote
ttr wrote:
...decided to give the NTV a bit of attention...
Confused Shocked
I've always thought of the NTV as an old fashioned V-twin with 2 spark plugs.
Is there a Alfa-Romeo inspired twin spark version that I've been previously unaware of?*
* option 1, option 2 is Odie doesn't know what a NTV is and is being general
PostPosted: 18:50 - 25 Oct 2010    Post subject: Reply with quote
I'd go with the "Odie got confused when stinkwheel was going on about his VFR having a similar fault." option.
Odie rides a Bros with an africa twin engine which is pretty much the same as an NTV engine, give or take a shaft drive. (Assuming it's the same Odie I've met before).
PostPosted: 19:00 - 25 Oct 2010    Post subject: Reply with quote
Alfa aren't the only ones to use 2 plugs per cylinder. Quite a few V twin Hondas do. People have done twin plug conversions for BMW and Guzzi twins. Not sure but didn't some of the Aprilia v twins? Also at least Nissan did a twin plug head version of one of their engines.
ttr
PostPosted: 19:16 - 25 Oct 2010    Post subject: Reply with quote
confirmed: NTV & Bros engines both have 4 plugs.
I'm away from my bike at the moment so can't check the stuff suggested but will report back ASAP. Pretty sure I've not fouled any lines though - as said, only disturbed two and I'm certain I haven't trapped them.
c_dug
PostPosted: 19:37 - 25 Oct 2010    Post subject: Reply with quote
Also, my NTV has had the fuel pump bypassed and runs fine.
ttr
PostPosted: 19:50 - 25 Oct 2010    Post subject: Reply with quote
"(dead - in garden)" Laughing
I've heard they starve at high revs without the pump, but this is a bodge I'm willing to do if that's the issue (until I can be arsed to get a new pump/one comes up cheap on eBay)
Odie
PostPosted: 20:10 - 25 Oct 2010    Post subject: Reply with quote
Yes mate, same odie, it was an NTV not a bros or africa twin, it was rather sweet if i say so myself, had to sell her but hey ho, want another they are that much fun, anyone want to swap a GS500 for an NTV?
c_dug
PostPosted: 20:14 - 25 Oct 2010    Post subject: Reply with quote
Pulled all right to over 100mph, seemed fine to me Laughing
Odie
PostPosted: 20:18 - 25 Oct 2010    Post subject: Reply with quote
I owned one for 3 years, never let me down, did over 25,000 miles.
I serviced it myself as i am a time served bike mechanic and yes it does have 4 plugs, 2 per head, the center plug on both cylinder's is a right cunt due to the access / lack of.
So map....................... Middle Finger Mr. Green
map
Mr Calendar
PostPosted: 12:13 - 26 Oct 2010    Post subject: Reply with quote
Odie wrote:
I owned one for 3 years...yes it does have 4 plugs, 2 per head, the center plug on both cylinder's is a right cunt due to the access / lack of....
Thanks, I've learned something new today then.
Odie
PostPosted: 15:01 - 26 Oct 2010    Post subject: Reply with quote
Vincent wrote:
Shouldn't do, gravity feed should be more than enuf to keep the float bowls full.
Float bowls are higher than the tap on the tank so do really need a pump to pump it up to the carbs.
the pump is known to give problems but only known of a few, pump is the same as some other Honda's.
here is a link to the NTV owners web site: https://ntvhonda.proboards.com/
very handy site, loads of help if needed but dont act like a prat! lol
PostPosted: 15:05 - 26 Oct 2010    Post subject: Reply with quote
Odie wrote:
Float bowls are higher than the tap on the tank so do really need a pump to pump it up to the carbs.l
Should be fine until the fuel level drops below the level of the carbs.
yen_powell
PostPosted: 15:40 - 26 Oct 2010    Post subject: Reply with quote
On my Africa Twin you can bypass the pump at the side of the road with just fingers. Whilst it's fine with a fullish tank up to about 50mph, attempting to overtake at 70/80 on a motorway results in the engine cutting out, the bike rolling to a stop on the hard shoulder, a 10 second wait whilst the float bowl fills up again.
Facet contactless pump is a more reliable, much cheaper alternative to the Honda/Mistubishi original. My Facet fuel pump has done nearly 50,000 miles with no problems.
XT1200Z and a DR350 in bits
ttr
PostPosted: 19:38 - 28 Oct 2010    Post subject: Reply with quote
managed to make it home this evening so will be taking a look to see if I can get her running.
If it seems to be a pump issue - are they at all user serviceable or is it new pump job?
Also if I bypass it, anyone know how many miles I can expect to get from a tank (given I wont have reserve if levels are the issue!!)
The last post was made 15 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 139.04 Kb
