| stinkwheel |
 Posted: 22:48 - 24 Oct 2010 Post subject: What's this hard, white crap on my exhaust valve? |
Pulled the cylinder head off the Enfield Bullet yesterday to see if I can see why it's burning so much oil. (30 minute job)
There is a plaque of hard, white material in the middle of the exhaust valve. It looks a bit like plaster but it's hard as nails, I had to literally chisel it off.
I have no idea what it is. Could it be sulphates or something from the unleaded petrol?
That valve was polished (like mirror polished on a buffer) 10k miles ago. The soot I can explain, it's venting more oil into the environment than BP. The white crap, I have no idea about.
https://i48.photobucket.com/albums/f216/stinkwheel/enfield%20head%20231010/head.png ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| LongJohn22 |
 LongJohn22 Trackday Trickster
| tatters |
 tatters Exxon Valdez
 Posted: 23:12 - 24 Oct 2010 Post subject: |
Had the same white deposites on my R100GSPD after 50,000 miles of the crank case breather venting oil into the air box. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| el_oso |
 el_oso World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:41 - 24 Oct 2010 Post subject: |
I'd SO like to say that its calcium deposits from the tap water used in the cooling jacket, denoting water getting into the cylinder due to head-gasket failure..... but I think that jest would last about as long as it took for you to say 'But its air-cooled'... occassionally works though!
Yup. Tis normal depositation, and entirely usual, especially if the bikes been burning oil. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| stinkwheel |
 Posted: 00:04 - 25 Oct 2010 Post subject: |
Cheers guys.
The more observant of you may have noticed where the head gasket appears to have failed to seal properly between the cylinder and the exhaust pushrod tunnel. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Walloper |
 Walloper Super Spammer
| weasley |
 weasley World Chat Champion
 Posted: 21:56 - 25 Oct 2010 Post subject: |
I'll give the chemistry lesson!
It is not 'coke', but 'ash'. Coke is carbon-based deposits, like soot and so on - these will burn off if hot enough. However there are metallic compounds in engine oil that, when burnt, form oxides (eg calcium oxide, magnesium oxide, zinc oxide) - these will never burn off and are, as you have discovered, quite hard to remove. An acidic substance may help remove them, but then this could attack your valve too, so maybe not! |
| Chalky. |
 Chalky. World Chat Champion
 Posted: 21:58 - 25 Oct 2010 Post subject: |
Remember that time when you got "close" to your bike?
The aftermath
/\ what they said. |
| stinkwheel |
 Posted: 23:50 - 25 Oct 2010 Post subject: |
It's off ok. I chiselled the worst of it off with an old screwdriver then scraped the remnants away with a 2p.
I was just wondering if it was indicative of some other problem other than the oil leak, which hopefully a different type of head gasket and some new, all-singing, all-dancing flange sealant should fix. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| tahrey |
 tahrey World Chat Champion
The last post was made 15 years, 350 days ago. Instead of replying here, would creating a new thread be more useful? |
