| jpderv |
 jpderv Nitrous Nuisance
| Frost |
 Frost World Chat Champion
| jpderv |
| Teflon-Mike |
 Posted: 04:43 - 26 Oct 2010 Post subject: |
Big one tend to have a better quality of finish & a reported to last longer, particularly the full chrome systems. Gianelli are black painted, & have a reputation for loosing thier finish fast and not lasting as long.
For the gains, if your existing pipe can be welded, save your dosh, get the old pipe welded & put the saving towards a bigger bike.
At BEST a replacement pipe will give maybe 5% more power top end, usually sacrificing mid-range to get it.
On a moped, given that they are restricted to begin with, you MIGHT get a wopping 15% more power, if you re-jet the carb to suit the new pipe and adjust the ignition advance or swap the CDI unit to suit the new pipe.
If the pipe doesn't come with reccomendations for those added mods, then either it is likely to wreck your engine, or its not going to offer an actual power gain..... I'll let you decide which is the more likely.
But lets say that for some peculiar reason, either pipe will defy the principles of conventional tuning and offer a genuine 'big' gain of around 15% power boost (about three tiumes whats typically achievable, and then only with associated carb & ignition mods) on a 3.5bhp engine, thats a less than half a horse power more.....
Seriousely you'd get a bigger kick in the pants from the after effects of a cheap curry!
SAVE YOUR MONEY ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| jpderv |
| jpderv |
| mr rip |
 mr rip Scooby Slapper
 Posted: 17:00 - 27 Oct 2010 Post subject: |
the ts50x pipe is about the most restrictive part on the bike
but it's a very effective expansion pipe when it's de-restricted, which isn't hard to do if you can weld & worth having a go at befor you splash out on an after market pipe,
(note) the last time I bought one, the gianelli pipes had a different sized stinger pipe so you can't mach up either half of the original pipe with it but have to get the complete gianelli system
if you have the pipe off the bike, have a look at it from the back/inside edge, as the pipe tapers down toward the stinger you will see two vertical rows of spot welds
cut the pipe between these two rows & you will see a flat plate with a hole in in eace half (a large hole engine side, & a small hole nearer the stinger)
I've tried several different variations of knocking these plates out from one or the other or both, but I got the best result from leaving them both in situe & get a 5mm drll & drill loads of holes in both plates so they both look like cullanders (the more holes the better) then weld it back together,
you will want to do away with the old steel reed valve in favour of something a little more flexable, & upjet to suit, you might have to raise the slide needle a notch too, but you will notice a big difference ____________________ never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes |
| jpderv |
| Blue_SV650S |
 Posted: 22:38 - 27 Oct 2010 Post subject: |
Do Fresco not still make pipes? - it was them and Geinelli when I were a lad!!
I had a TS50X and the exhaust is the best place to start, as stated above, you can de-restrict the stock one and it makes for a good pipe!
EDIT: {click click} ... 'Big one' is Fresco's new name ... as you were chaps!!  ____________________ The purpose of life is to fight maturity. |
| jpderv |
| jpderv |
| c_dug |
 c_dug Super Spammer
| mr rip |
| stevo as b4 |
The last post was made 15 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
