| map |
 map Mr Calendar
 Posted: 13:51 - 27 Oct 2010 Post subject: So, how would you teach someone to ride a geared bike? |
As per title.
I'll be trying to teach someone how to ride a 125 (it's the old '85 CG).
However. she's not ridden a geared bike before.
All other attempts either have her releasing the clutch too quickly without also appying revs and stalling. Once she did racing off down the road, scaring herself and then stalled (private road officer).
I've been trying to get her to balance the bike on the clutch biting point first. However, this is still difficult.
No point in moving to gears until the bike is at least able to move forward.
I'm racking my brains how I did it and coming up with nothing
So, any pointers and advice appreciated.
Thanks  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?
| CptBlack |
 CptBlack Trackday Trickster
| Howling TerrorOutOfOffice |
 Posted: 13:58 - 27 Oct 2010 Post subject: |
Whilst teaching my daughter i got her to freewheel down a hill and asked to pull in the clutch as she braked. Same again in gear and a little throttle. A slight downhill helped with clutch control in the first half hour. After that i taught her where to look. i.e not too close. Then i showed her how to pick up a 250
Pat ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| ThoughtContro... |
 ThoughtContro... World Chat Champion
| DrDonnyBrago |
 Posted: 14:18 - 27 Oct 2010 Post subject: |
get her to keep the throttle steady at a point where the revs are quite a bit higher than you would normally use to pull away, tell her the engine will sound loud as it is 3 feet away and there is no sound insulation, plus bikes like to be revved more than cars so don't worry about it.
To start, some slow stuff - get her to control her speed using the clutch rather than the throttle.
If she keeps that throttle position steady and slowly slips the clutch in then it is only one thing to think about, rather than trying to get the clutch and throttle right at the same time. The biggest issue I had was not revving it enough when pulling away, losing the revs as it engaged and stalling - not worrying about over revving it helped.
When she is moving, get her to pull the clutch before the brake, introduce leaving the clutch out during emergency stops at a later date.
Ultimately though it is just practice.
HTH  |
| CptBlack |
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 14:25 - 27 Oct 2010 Post subject: |
Trial an error.
Just be patient and give her plenty of encouragement  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| Misc |
 Misc World Chat Champion
| map |
 map Mr Calendar
| The Artist |
 The Artist Super Spammer
| truslack |
 truslack World Chat Champion
 Posted: 15:10 - 27 Oct 2010 Post subject: |
Last time I taught someone to ride on the H100 I watched them wheelie or stall a few times, they eventually got bored of having to kickstart the bike and that pushed them to learn to set off properly  ____________________ Current: Suzuki RG 125 Gamma, Honda H100, Triumph Tiger 800XC, Suzuki SV650 (minitwin) |
| HD |
 HD World Chat Champion
| pinkyfloyd |
 pinkyfloyd Super Spammer
| spetom |
 spetom Trackday Trickster
 Posted: 19:54 - 27 Oct 2010 Post subject: |
Teach him/her the first two golden rules of biking.
Or what in my opinion should be the first two golden basic beginner rules of biking, although the usage of number 1 changes as you get more experienced.
1) Always keep the clutch in when you are stationary!! If you don't know you're in gear always keep the clutch in!! When you're starting the bike always keep the clutch in. If you panic or lose control remember left hand clutch in!!
Then/or...
-Only release the clutch if you know you're not in gear, check to make sure you are in gear by rolling the bike back and forward.
-Only release the clutch slowly at the beginning, do not over Rev the engine. Even if you think you are in neutral
(The reasoning for this is the amount of inexperienced & experienced bikers who revving their bike forget they are in gear and release the clutch, and the bike goes airborne. This is usually a huge fuck up on bigger bikes. Quick clutch release has caused so so many bike take offs!)
https://www.youtube.com/watch?v=YgAkKrIimcc
2) Keep your hands and feet away from the sprocket! Never ever run the engine when you are doing mechanical maintenance on it despite what everyone says. Keep your hands and feet away from the sprocket and chain!
(The reasoning for this is obvious but to the novice) |
| nokiakeys |
 nokiakeys Token
 Posted: 20:23 - 27 Oct 2010 Post subject: |
Everyones given their thoughts, so I thought I'll add mine.
Get her to listen to the engine mainly.
Put the bike in 1st and keep clutch in.
While it's in, start to rev the engine at a steady pace, then slowly let go of the clutch while listening to the engine and feeling the bike ready to go I.E. the biting point
That will tell her when she needs more power to move off. When she starts to move off a bit pull the clutch in and repeat previous steps a couple times until shes happy with the biting point.
Then bobs your uncle she can move a geared bike... hopefully  |
| Sam_Y_93 |
 Sam_Y_93 World Chat Champion
 Posted: 20:39 - 27 Oct 2010 Post subject: |
Its trial and error as others have said. Does she have a car? if not then she wont be used to the clutch control. I would tell her to sit with the bike in gear releasing it to the BP and bringing it back in, once she knows where it is then get her to apply a little throttle whilst finding the biting point.
You could also show her some videos on youtube or something, found this helped me when I taught my self https://www.youtube.com/watch?v=CdySkge4aKM ____________________ Bikes Past: Yamaha Aerox (sold) Yamaha R125 (written off)
Theory passed July 21st Mod1 passed August 3rd Mod 2 passed 26th August |
| JP7 |
 JP7 World Chat Champion
 Posted: 23:00 - 27 Oct 2010 Post subject: |
I taught my girlfriend the basics on my H100 on the local airfield.
Got her to use the back brake first. Pushing her along and coming to a halt using it. This give confidence in the initial stages while riding slowly. If it all goes wrong or you feel out of control, stop using the back brake, worry about the rest later.
Once she was happy with that, I got her to play with the throttle and clutch while holding the back brake on so she could feel the bike pulling against it.
Once she had the feel of that, I got her to slowly let the back brake off as she felt it pulling, ride forwards a few feet, close the throttle, stop it again using the back brake and repeat. Pretty much had her balancing the clutch, throttle and back brake within the first 5 minutes (she's a smart lass)
Sounds a bit arse backwards but this is putting the groundwork down for the slow riding you need to do your test manouvers. I also know so many people whose first bike riding experience was wheelying an H100 into a chainlink fence on their CBT. To me it's logical to teach someone how to stop before you teach them how to go.
Then we did ride off, change into second, stop, change into first, ride away, change into second, stop....
Once she was confident she could stop under control and change gear, I got her to build up the speed a bit and start using both brakes to stop in the same way as before.
She pretty much did the rest on her own having got the hang of it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Tonka |
 Tonka World Chat Champion
| ThoughtContro... |
| Glenben92 |
 Glenben92 Nearly there...
 Posted: 17:23 - 28 Oct 2010 Post subject: |
| Rowey |
 Rowey World Chat Champion
| LordShaftesbu... |
 LordShaftesbu... World Chat Champion
| rob_scott92 |
 rob_scott92 Could Be A Chat Bot
 Posted: 21:09 - 28 Oct 2010 Post subject: |
| Glenben92 |
 Posted: 22:03 - 28 Oct 2010 Post subject: |
This is all quite interesting as since getting my first ever geared bike (never previously ridden a geared bike in my life) in may I've only ever stalled twice. and neither of them were trying to pull away. both times were sitting talking to people for so long that i fogot i was in gear/on the bike/bike was running, then just letting go of the clutch and thinking "eh, what the fu.. ahh yes, i'm on a bike"
as far as actually beginning to ride, i knew the theory behind it (clutch use and gear positions etc.) and i just sort of got on and... did it. up the back lane to 3rd gear, back down the box and did a 3 point turn (its a tight lane) then the same back. repeated this 2 or 3 times then went for a ride around some empty streets to get used to signalling and turning along WITH the clutch use, then i was out riding properly and confidently within about 20 minutes of first getting on the bike. My riding has always been smooth and i've never had trouble with riding the clutch or choosing the wrong gear or slow control or anything like that.
I'm now wondering if i'm just naturally good with these things or if it's been something in my upbringing that i've missed. I have always had a quite complex understanding of engine mechanics and general physics, i wonder if it's the knowing exactly WHAT the clutch does and HOW it works that helps? ____________________ 57 Huoniao HN125-8 - , 97 Kawasaki GPZ500S -
99 Yamaha FZS 600 -
Mod 2 Passed - 01/10/2010 |
The last post was made 15 years, 325 days ago. Instead of replying here, would creating a new thread be more useful? |
