How long does it take for tyres to warm up?
LordShaftesbu...
PostPosted: 18:59 - 27 Oct 2010    Post subject: How long does it take for tyres to warm up? Reply with quote
I've been riding about 3 years now, but it was only on my way home tonight that I managed to absolutely scare the living shit out of myself. Taking a left at an empty roundabout, gently upped the throttle like I normally do on the way out, only this time the back of the bike is suddenly all over the place and the handlebars are slapping like I've never experienced. It seemed to go on forever, I remember thinking it's either going to stop now, or I'm off ... oh, it's not stopping. I was absolutely certain I was coming off. Luckily it all seemed to die down of its own accord.
I was thoroughly shaken by the experience - straight afterwards I thought I could feel something wrong with the back end, some kind of weird wobble. I stopped to check to see if I had a puncture but it must have been my paranoia because the back tyre was fine. The only think I noticed was that it was virtually stone cold. This was after riding for about 20 minutes at about 40mph. I'd say ambient temperature was around 10-15°C, so quite warm, and the road have been dry all day.
I'm sure I've been able to get away with more throttle doing the exact same thing before, so I guess what happened is I just used a bit too much power while leaning over, and while the tyres were still cold?
So my question is, to prevent this happening again, how far/fast should I go before my tyres are safe? I was riding a Street Triple on BT-016s, if that helps.
L-Jam
PostPosted: 19:02 - 27 Oct 2010    Post subject: Reply with quote
Weird how they are stone cold, After about 10 mins mine are very warm to touch and I can push the bike hard.
Journalist, student, egotist.
PostPosted: 19:06 - 27 Oct 2010    Post subject: Re: How long does it take for tyres to warm up? Reply with quote
Depends on a lot of factors.
Can easily be riding at a relatively 'rapid' pace on track and still have the tyres pretty much stone cold when you get back because of the wet, cold, etc.
I like tyre that still give good grip from cold.
J D
PostPosted: 19:07 - 27 Oct 2010    Post subject: Reply with quote
When i had bt16s on my old gixer they took an age to warm up properly Thumbs Down
Get some better tyres.
Paxovasa
PostPosted: 19:10 - 27 Oct 2010    Post subject: Reply with quote
Mine warm up enough after a couple of miles Thumbs Up It also gives the bike a chance to warm up.
After that it is play time Razz
Rob W
PostPosted: 19:17 - 27 Oct 2010    Post subject: Reply with quote
This, Thumbs Up.
The GSX-R is wearing a set of Pilot Power's, and I usually find I can go silly in just a few miles, unless it's freezing cold/raining etc.
On the Blade though, I'm running an 014 on the front and a Pilot Power on the rear, and I dont feel that comfortable to push the bike for quite a while to be honest. The rear feels fine (it's only done 200~ miles) but I dont seem to be getting much feedback from the front. Maybe it's because they're a mismatched pair, or the fact that sunconsciously I'm not going as mad because the roads aren't exactly in the sort of condition to be doing it.
Rob W
PostPosted: 19:18 - 27 Oct 2010    Post subject: Reply with quote
EDIT - Double Post.
LordShaftesbu...
PostPosted: 20:31 - 27 Oct 2010    Post subject: Reply with quote
That's interesting. After a bit of googling I've found others who say the same - they're good, but take ages to warm up. The "middle" compound (it's a '5'-compound tyre) is so focussed on high mileage, its low grip means harsh acceleration and braking are out.
LordShaftesbu...
PostPosted: 15:08 - 28 Oct 2010    Post subject: Reply with quote
How do tyre pressures affect warm up time? Would reducing the pressure help?
.Bishbash.
PostPosted: 16:55 - 28 Oct 2010    Post subject: Reply with quote
Don't listen to JD he only likes to warm the middle of the rear tyre, no other part. Laughing
Yeah, lowering the PSI in your tyres can make them warm up quicker. More surface area I think, I could be wrong, it's happened before.
Get yourself a set of Racetecs, never ever had a slip on one of these tyres, I highly rate them.
Current bike - GSX-R1000 k8
St0rmer66
PostPosted: 17:45 - 28 Oct 2010    Post subject: Reply with quote
If you weren't going silly with the throttle then have you considered that it might have just been something slippery on the road instead of a problem with the tyres? Also, what about your suspension?
:: Honda XR 125 L ('53) => Kawasaki GPZ 500S ('02) => Suzuki SV650S ('00) => Aprilia RSV-R ('51) ::
LordShaftesbu...
PostPosted: 17:59 - 28 Oct 2010    Post subject: Reply with quote
Just got home after taking the same route as yesterday, only this time in daylight. There was a large patch of what looked like white gravel or maybe salt at the edges of the road, exactly where my wobble started. I remember my tyres were covered in white speckles so maybe that's the explanation.
I'd have thought lower psi would warm tyres up quicker cos it would allow them to flex more ...
Walloper
PostPosted: 18:27 - 28 Oct 2010    Post subject: Reply with quote
There was a test done in a bike mag a few years back on different tyre charactersitics.
One then was weird was how weaving left to right will not warm a tyre up. The best way to warm it up is by hard acceleration and braking.
Weaving side to side did hee-haw to improve warm-up times.
Lower pressure to worn the tyre is not recommended.
When you lower the pressure the centre of the tyre will not contact the road properly and this will cause the tyre to lose grip.
Run the tyres at the correct range.
Tyres set with cold tyres.
Roundabouts are a perfect place to have an off.
The road surface could be worn/polished due to heavy use.
The road could have spilled fuel on it.
The road could have a coating of tyre rubber from other vehicle use.
Motorway slip roads off roundabouts are always worth caution too.
LordShaftesbu...
PostPosted: 18:44 - 28 Oct 2010    Post subject: Reply with quote
Thanks man.
Offtopic, and I think I've asked this before, but what is WALLOPER? Every time I see it I think I've seen it somewhere before, but I've googled and googled and can't find anything. It's doing my head in!
But.It.Was.A.Bargain.Luv
PostPosted: 18:56 - 28 Oct 2010    Post subject: Reply with quote
Thumbs Up with St0rmer66
If you've never had it before, and you weren't raggin it, put it down to a bit of shit on road and crack on mate.
If you over analyse every time the front or back or both twitches, you'll be a bag of nerves in no time.
Very Happy
Walloper
PostPosted: 19:12 - 28 Oct 2010    Post subject: Reply with quote
Doug97 wrote:
Thanks man.
https://www.urbandictionary.com/define.php?term=walloper
Smile
LordShaftesbu...
PostPosted: 19:19 - 28 Oct 2010    Post subject: Reply with quote
OK, and married to the Cyborg Name Decoder you get your name. Weird, I must be thinking of something else .... Confused
Inkognito
PostPosted: 20:00 - 28 Oct 2010    Post subject: Reply with quote
Wallop is also some kind of IRC admin.
If anyone here even remembers what IRC is Razz
Walloper
PostPosted: 20:30 - 28 Oct 2010    Post subject: Reply with quote
Indeedee.
Plus I was press ganged into bcf's navy to repel boarders a couple of years back. I lost an eye in the squabble on the poop-deck but kept the patch.
Oh arr shiver m' timbers, they be pirating scoundrels afoot now and then m' hearties
evoboy
PostPosted: 22:43 - 28 Oct 2010    Post subject: Reply with quote
Moving on.....
Only tyres ive had issues getting heat into was a set of BT014's. All others have been fine within a few miles.
APT Motorcycles
PostPosted: 23:06 - 28 Oct 2010    Post subject: Reply with quote
The one and only time I got my peg down was on a motorway slip road.
J D
PostPosted: 00:47 - 29 Oct 2010    Post subject: Reply with quote
Lies Razz , on the gixer with 16's i went out with G on new years day on a fairly quick ride of about 55 ish miles and tyres were still spinning up way too easily. Racetechs are amazing though Thumbs Up
steven_191
PostPosted: 01:10 - 29 Oct 2010    Post subject: Reply with quote
from what i understand about the pressures are that you want a specific pressure once the tires are at the optimum temperature range. the only reason you need to alter the pressure are to either speed up/slow down the warm up speed (but overall i think this will affect the temp at its optimum) and alter the pressure at cold depending on the ambient temperature.
i know a group who take a car racing and the guy has a list of ambient temperatures and road conditions and from that he will know what to set the tires at at cold and after a few laps the tires are warmed up and the pressures correct.
but unless your on a track its not worth changing the pressures. your tires are for road use which means they will warm up how they need to for the road and probably not take too much of a beating. when your on a track tires can be a completely different story.
Walloper
PostPosted: 15:13 - 29 Oct 2010    Post subject: Reply with quote
Agreed, it would be the same for the transmission ratios I guess. And the ECM settings. And if you wear your woolen long-johns or not too. Razz
I have never noticed any difference in tyre pressures on public roads. Unless grossly under or over pressure.
Do not deviate from the OEM specification. That is the best overall pressure for normal road use. And an OEM will spend more time doing severely critical testing of their products than an average individual can do and that's discounting the cost of swapping rubber for testing.
That is taking into account cold, warm, wet, dry, smooth, rough and in general average road conditions which we all have to ride on.
If you feel a need to deviate or play with pressures the best advice may be got from the manufacturer's website Contact US/Technical.
They normally relish an opportunity to tell you how to use their products to the best advantage. (For you and for them)
PostPosted: 15:26 - 29 Oct 2010    Post subject: Reply with quote
As I've mentioned before, first time I got a 4th place in a club race (still the best result I've got), I had tyres probably around 20psi too high, in the 50s.
The fact this didn't cause me any problems suggests you have to be going a chunk faster than I was for it to be a big problem!
Low pressures can cause 'feel' problems as well as making steering a bit sloppy, but I've still often run dirt bikes at 10psi or less on the road when transiting between off-road sections.
The last post was made 15 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 131.71 Kb
