Speed Bleed nipples (check valve nipple)
calyx
PostPosted: 21:16 - 27 Oct 2010    Post subject: Speed Bleed nipples (check valve nipple) Reply with quote
Are they any good? Any leaks or problems?
https://speedbleeder.zoovy.com/
https://static.zoovy.com/img/speedbleeder/W174-H180-Bffffff/sbani.jpg
Boris - London
PostPosted: 21:18 - 27 Oct 2010    Post subject: Reply with quote
Looks brilliantly simple. Never used one though.
jimspeed
PostPosted: 21:29 - 27 Oct 2010    Post subject: Reply with quote
used some on the rally car (but on the clutch) brilliantly simple and work wonders if you need to do lots of regular bleeding (I did)
not so good after a year or so in the elements even with the rubber cap fitted the ball stuck tight.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
jimspeed
PostPosted: 21:47 - 27 Oct 2010    Post subject: Reply with quote
could have I suppose but it was in a proper awkward place to get at which was why I used them in the first place.
I just use a non return valve on some small rubber pipe now for most brake bleeding
The last post was made 15 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 39.71 Kb
