Burning an .iso file to disk?
Dazbo666
PostPosted: 05:51 - 28 Oct 2010    Post subject: Burning an .iso file to disk? Reply with quote
I've recently downloaded some .iso files to the hard drive, and want to burn/mount the files on to DVD's or CDR's
Can anyone recommend a piece of software (preferably freeware, but not essential) that can reliably do this??
If it makes any difference the burner is an NEC DVDRW drive ND-3500AG... and the PC is running Vista Home
Word of the day : DILLIGAF
PsychoHippy
Jammy Git
PostPosted: 06:21 - 28 Oct 2010    Post subject: Reply with quote
You can either mount the image to a virtual drive using something like
Virtual Clonedrive by Slysoft, or if you definitely want to burn them to disk then something like Infrarecorder is nice and simple.
Both of them are free and can be found quickly via Google Thumbs Up
I spend all my money on bikes and beer, the rest I simply waste!
t121anf
PostPosted: 09:15 - 28 Oct 2010    Post subject: Reply with quote
nero essentials
windows 7 does it iirc too
Kai.Wilson
PostPosted: 12:26 - 28 Oct 2010    Post subject: Reply with quote
https://www.ntfs.com/iso-burning.htm
one i use
and its free and easy to use
Frost
PostPosted: 12:38 - 28 Oct 2010    Post subject: Reply with quote
Yeah 7 does it, vista too probably. Right click, send to DVD drive, then write it to the drive and select 'image file' from the options.
If you just want to be able to access the data without having to write it to a disc you can use something like 'Alcohol 52%' to 'mount' it, or some zip programs let you extract it.
map
Mr Calendar
PostPosted: 12:48 - 28 Oct 2010    Post subject: Reply with quote
Another suggestion for image buring software is if you look on PortableApps.
The software there can be run from USB memory sticks so you're not limited to installing it on your PC and can take the software to the files if required.
For looking at the image contents without burning then there's always Microsoft's own Virtual CD_ROM (it takes DVDs too). If you click here it's the .exe installation download from microsoft.com.
All of the above software is free BTW.
HTH Thumbs Up
Daemon Tool is the best mounting software I have found.
Inkognito
PostPosted: 12:56 - 28 Oct 2010    Post subject: Reply with quote
+1
Takes 10 seconds to install and mount images with a few clicks Smile
Nice and easy and never failed me yet.
PostPosted: 13:30 - 28 Oct 2010    Post subject: Reply with quote
Puppy linux has an amazing tool for putting a bootable.iso file on a memory stick.
It makes the stick behave like USB stick, a removable HDD, a floppy drive and a CD ROM (when you plug it in, the computer sees all four as seperate drives). It'll boot on pretty much anything.
Dazbo666
PostPosted: 13:37 - 28 Oct 2010    Post subject: Reply with quote
PLENTY of options to keep me occupied... cheers for the info!!
TomCB
PostPosted: 13:58 - 28 Oct 2010    Post subject: Reply with quote
Imgburn if you just want to burn them.
daemon tools if you want to mount them.
Faldo: "Classic BCF. A thread about sky diving is NSFW on post #2."
The last post was made 15 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 69.26 Kb
