want to derestrict my 07 rs125. help please????
jasepugh1984
PostPosted: 15:43 - 24 Oct 2010    Post subject: want to derestrict my 07 rs125. help please???? Reply with quote
got an o7 rs125 as far as im aware i need to put a 172 main jet in it different spark plug and fit a powervalve.but before i do it ,wanted to make sure i got everything covered.thanks
Aprilia Rs125 2007 11kw (SOLD) - Honda CBR600RR 2008 (Current Summer Toy) - Honda Cb600 2000 (Current Work Commuter)
stirlinggaz
PostPosted: 17:30 - 24 Oct 2010    Post subject: Reply with quote
hi,
to completely de-restrict you will need a powervalve unit, a a new main jet, & a different exhaust.
but 1st you need to establish what CDI you have & which carb is fitted. (phbh or vhst)
if its the older style CDI, then its simply a case of bolting the solenoid to the frame, bolting on the pv housing to front of the cylinder & connecting the bowden cable.
then plugging in the solenoid to the spare block connector.
the older style bikes came with the seperate pv control unit already fitted (its inder the rear seat)
& when you plugged in the solenoid, the circuit was complete.
the newer style CDI comes with the pv control unit combined & needs to drilled at a specific point.
the size of main jet will depend on whether you intend to complete the de-restriction (by removing the cat or fitting another exhaust) & which carb you have.
the spark plug should be either a BR10 or BR9 (if you dont red-line it continually)
there are a couple of official aprilia de-restriction guides available, but you need to specify which CDI & carb you have.
cheers,
GAZ
jasepugh1984
PostPosted: 18:29 - 28 Oct 2010    Post subject: Reply with quote
im going to check what carb i have, was looking on ebay and are all rs125 powervalves the same,i mean will one from say an older rs125 fit my 2007 thanks.
https://cgi.ebay.co.uk/Aprilia-RS125-Powervalve-/180579610606?pt=UK_Motorcycle_Parts&hash=item2a0b622fee#ht_484wt_1156
stirlinggaz
PostPosted: 19:43 - 28 Oct 2010    Post subject: Reply with quote
yes, the actual powervalve housing,blade.bowden cable & solenoid fits all years.
have you looked to see whats fitted to your bike?
seen a few that were sold as restricted & they had the pv bolted on the front & were just not plugged in,lol
you should have a blanking plate if its restricted.
remember & check what CDI you have,
cheers,
GAZ
ps : 75 quid is a bit much. (seen them go for under 50 quid or 75 with the rave box)
jasepugh1984
PostPosted: 17:26 - 29 Oct 2010    Post subject: Reply with quote
ive checked my carb its an vhst 28 and my cdi is one of the new ones i have a spare one that already has been drilled.i think a while ago when i saw an official aprilia derestriction guide it said 172 main jet
jasepugh1984
PostPosted: 17:28 - 29 Oct 2010    Post subject: Reply with quote
i was going to get the exhaust cut at work and remove the cat aswell
The last post was made 16 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 49.52 Kb
