charging issues
lonie This post is not being displayed because the poster is banned. Unhide this post / all posts.
Paxovasa
PostPosted: 00:41 - 30 Oct 2010    Post subject: Reply with quote
Get a multimeter on it and check it when the bike is running. Check it at tick over and when giving the bike a few revs.
Report back with your findings Thumbs Up
weasley
PostPosted: 10:26 - 30 Oct 2010    Post subject: Reply with quote
Another culprit that is a common failure is the regulator/rectifier. The multimeter testing should discover this.
PostPosted: 13:34 - 31 Oct 2010    Post subject: Reply with quote
Not sure on the bike. Some power the headlight directly on AC on a separate circuit so check the other lights. Do the other lights get brighter when you rev the engine? If so then that suggest the charging circuit is working so I would look at the battery first.
If the lights get brighter, but not much then it suggests that full power isn't being delivered. Normal regulator / rectifiers either work or don't work so I would check the stator.
However most common failure seems to be the regulator /rectifier. This is 2 things combined into one unit. The rectifier turns ac to dc, and not that much there to reduce power. The regulator controls the voltage, and when it goes wrong it is likely to either stop the system charging or supply too high a voltage (and boil the battery, blow bulbs, and burn out electronic units).
The last post was made 15 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 72.85 Kb
