Rs125 Problem at 6000-8000 Revs
Stefan RS50 Wood
PostPosted: 23:41 - 29 Oct 2010    Post subject: Rs125 Problem at 6000-8000 Revs Reply with quote
Right Ive bought a cheap rs125 £500
New power valve kit
OK so the bikes starts first time every time, seems smooth at up until 6-8k revs makes loud splutter noise's.
I only know the basics about bikes, so any help on what this would be would be appreciated.
Thanks
Digitalize
PostPosted: 23:45 - 29 Oct 2010    Post subject: Reply with quote
does it rev past the 8k?
1998 CB600F Hornet
Syris the Indomitable
PostPosted: 09:37 - 30 Oct 2010    Post subject: Reply with quote
I sold a lad one of these fully restricted and never reved past 7000 revs.
It looks like the APRILIA RS125 1996-2006 sport pro.
Just because the power valve solenoid actuator has been fitted it doesn't mean it de-restricted.
1. There will be a catalytic converter in the exhaust check to see if it's been welded or if you have a totally different exhaust fitted other then the standard exhaust.
2. Check the air box, the nozzles may have a tube blocked up, just remove that blockage.
3. cdi, under the rear seat, is a black box, in the back of this black box is a silicone patch, dig the silicone out, and there is a little circuit board. snap it and remove it. this gets rid of the little restriction, also known as a environmental dip.
4. You want a br10es for a unrestricted bike.
5. Power valve, you will need the rave unit, solenoid, pv cable and pv blade and pv housing.(You Have this fitted already)
6. The carburettor set up on these is absolutely crucial, it will need changing or up-jetting, see a specialist about this or maybe someone will tell you exactly how to up-jet the standard car on these. If your able to do this your self it will turn out to very cheap.
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
Stefan RS50 Wood
PostPosted: 12:05 - 30 Oct 2010    Post subject: Reply with quote
Thanks the bike will not rev past 8k im going to do the Cdi inabit, the exhuast is standard but i wont be welding that because its not much of a difference ive heard, my local machanic will do a k&n air filter and rejet the carb for me for around £20, ile also buy 1 of those spark plugs, if it all doesnt work ile be back on Very Happy
Thanks all
PostPosted: 12:53 - 30 Oct 2010    Post subject: Reply with quote
K. Good luck. Hope it works well without having to remove the catalytic converter because removing/replacing the exhaust on them is a nightmare; I had to grow muscles to replace the springs on mine, and had to cut an Alan key down to a stumpy to tighten the bolts at the manifold end.
PostPosted: 13:00 - 30 Oct 2010    Post subject: Reply with quote
The cdi mod has no effect outside the 5k to 6k range (it bypasses a massive amount of ignition retard between those rpm which is there to cause a large flat spot). If the problem you have is from 6k to 8k then the cdi mod will have no impact. I would leave it alone for now until you have found and fixed the real problem.
Check to see the power valve is actually open. It should also be open below 2500rpm.
Stefan RS50 Wood
PostPosted: 19:15 - 31 Oct 2010    Post subject: Reply with quote
Thanks all the cdi looks abit nakerd, all cut up and everything, i have ordered a new 1, if that isnt the problem then i have no idea because, when its in neutral or the clutch is pulled in it will rev to more than 8000, when riding everythink is smooth but as soon as it gets to about the 8000 mark it wont go higher
Stefan RS50 Wood
PostPosted: 19:25 - 31 Oct 2010    Post subject: Reply with quote
rob yarrr wrote:
maybe the exhaust is coked up,mine did this on my rs50
Exhaust looks fairly new, no rust and it hasnt been sprayed so i would assume it hasnt been on the bike to long but i would have to burn it out right ?
Stefan RS50 Wood
PostPosted: 22:20 - 31 Oct 2010    Post subject: Reply with quote
Just took the bike out for a spin, as soon as it hits around the 7k revs it just splutters, but sometimes it will like it happened twice in 30mins and that was in 1st gear, power seems fine when it gets past the splutter, noticed it backfires as well when letting off the throttle
PostPosted: 11:09 - 01 Nov 2010    Post subject: Reply with quote
I would check the jetting (someone may have done something silly with the jetting when derestricting it previously).
Also check the power valve is in the right way up (common issue, but really only knocks about 5mph off the top end).
Check the power valve operates smoothly (opens at just under 8k).
Check the air filter is clean.
Stefan RS50 Wood
PostPosted: 20:59 - 01 Nov 2010    Post subject: Reply with quote
Thanks only thing left now is to take it to a mechanic to do the jetting, it is running very very rich as if i turn the petrol off, it revs freely while driving, well better than before, its a 28m carb on the thing i cant afford a 34m at the moment so what jet size should i go for ?
Thanks for all this help, i really shouldn't have a bike if im asking all these questions but hoping to learn Very Happy
PostPosted: 21:04 - 01 Nov 2010    Post subject: Reply with quote
On the 28mm carb the main jet should be around a 120 (give or take a few). Not unknown for people to get confused and fit a ~150 main jet (about what the 34mm carb uses).
The last post was made 15 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 97.05 Kb
