*CAR* Wheel bearing death
Martay
PostPosted: 22:41 - 30 Oct 2010    Post subject: *CAR* Wheel bearing death Reply with quote
Hi,
thought id ask on here as you lot know what your on about Smile
My car seems to have a problem with rear wheel bearings. Really odd, ive not experienced a simmilar problem before.
Since ive owned the car (April / May ish this year) I have had 4 rear wheel bearings, as they keep going.
When i got the car, there was a hint the rear right was slowly going, so i got it replaced. A week later, the new one collapsed while i was doing 70ish on the duelly, spinning the car sideways up the verge. This one was replaced at a different garage. About a month later, the rear left sounded like it was giving up, so got it replaced by the same garage. Now, the rear left sounds like its dying on me again!!! About 50mph theres a really loud droning/rumbling noise from the rear, increasing in loudness with speed, accompanied by a vibration when accelerating. Ive jacked the car up and had a good look around, nothing seems missing/broken. Currently, the rear wheel has a 'clicking' feeling when you grab the tyre and rock the top/bottom of the wheel into the car.
What could be causing this? Just real bad luck? I do alot of miles (1500-2000 per month) but surely they should last longer than this??
Thanks
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
PostPosted: 22:56 - 30 Oct 2010    Post subject: Reply with quote
Are you running wheel spacers by any chance?
Martay
PostPosted: 22:59 - 30 Oct 2010    Post subject: Reply with quote
Nope, no spacers. Its got a set of OE alloys, but these problems were occuring before i swapped the steels for the alloys. The wheels are the same size as the steels.
stonesie
PostPosted: 23:06 - 30 Oct 2010    Post subject: Reply with quote
Are the garage fitting El-Cheapo no-name bearings?
To be fair even if they are fitting the cheap stuff it should last better than that but next time ask them to fit the better quality stuff.
My car gets SKF bearings, I would rather slam my dick in the door, repeatedly, than fit anything by trupart again... utter toss. It really is get-a-car-through-a-test stuff that will need replacing again next year if not sooner
I had no option but to fit trupart pads once, they were so bad I really would call them dangerous...
Edit just seen your sig, Mk4 fezbomb, It's rare to have rear bearing issues with those... Has it had a smack on the curb? next time the rear drums are off get the garage to check the stub axles are not bent. It takes quite an impact to do this but it's possible.
If that's your problem a replacement rear axle is the best bet, not massively difficult to swap the stubs over.
Martay
PostPosted: 23:12 - 30 Oct 2010    Post subject: Reply with quote
I understand what your saying, i hope thats the case and not something more serious. Ive been paying ~£50 all in to get it sorted. Parts + Labour.
Will it be a huge amount more for decent parts? I know you 'get what you pay for' but im not paying £300!! Laughing
Thanks
Raffles
PostPosted: 10:37 - 31 Oct 2010    Post subject: Reply with quote
The cost difference between good quality parts and crap ones is often quite small and I don't understand why people fail to insist on the A1 stuff. Anything else is just false economy.
iooi
PostPosted: 10:49 - 31 Oct 2010    Post subject: Reply with quote
I would say you are either driving the car in a way thats killing them... You know masses of handbrake turns or bouncing up and down a lot of kerbs.
Or something is seriously out of line/worn and causing the wheels to be out of line.
Perhaps someone has messed up when changing before and the bearing are not a good fit, so they are moving around in the carrier.
What do the tyres wear like ?
Any chance you can get someone else to drive the car while you follow behind to see if the car crabs or the rears look out of line.
What did the HPI say about the car history. Has it been a write off and not repaired properly. Give the old owner a call and see if they had any problems. Thumbs Up
pits
PostPosted: 12:35 - 31 Oct 2010    Post subject: Reply with quote
Depends.
Mitsubish rear wheel bearing £350 iirc
Pattern part rear wheel bearing £189
Difference, one doesn't have the Mitsubishi label stamped on it
Mitsubishi stepper motor £600
Denso stepper motor £180
Difference, pull the Denso sticker off and read the Mitsubishi part number underneath.
Some companies just add a silly amount on top of parts for just their name.
As for rear wheel bearing eating, your car has probably had a shunt and the camber is out massively, I would spend the cash and get a full 8 point laser alignment done on the car, to check.
MattEMulsion
PostPosted: 13:16 - 31 Oct 2010    Post subject: Reply with quote
If the bearing has failed already then take it back to the garage with a view to getting it done under warranty. I am assuming that it hasn't been in many months at all.
Reasons as to why it is going could include: poor quality bearings, poor fitting of the bearings, the way you drive (do you abuse the car?) and finally are you sure it is not partly down to the wheels that you have stuck on. The size of the wheel is unimportant in this instance, it is OFFSET of the wheel that will put the strain on the bearings, if it is wrong that it will wear them out at an alarming rate.
Yamaha YZF-R6
PostPosted: 14:28 - 31 Oct 2010    Post subject: Re: *CAR* Wheel bearing death Reply with quote
That's a warranty issue from poor installation, surely? No bearing should fail after a week. If it did, it was either installed poorly or there is another factor which a competent fitter should have noticed and informed you of.
Teflon-Mike
tl;dr
PostPosted: 17:06 - 31 Oct 2010    Post subject: Reply with quote
As others have said. Top of the list is that the replacement bearings fitted first time were chitpart items. In which case, they could be made of toffee, so replacingthem may have solved it. Unless replacements are also chitpart bits!
As they are 'sealed' bearing with thier own races, its unlikely that a poor fit would cause them to fail. If they didn't fit, they'd flop around and it would be obviouse. More likely is that in previouse bearing failure debris has welded itself to teh stub axle & been ground off to fit new. Not a big problem, BUT if it was in the hub-seal wiper zone.... VERY LIKELY then that will chew the seals, so you loose lube.... and the bearings run dry and fail.....
So top of the list after decent bearings, is the seal... was THAT replaced at the same time as the bearings? (Should have been, as usually cause of failure) Was the stuf 'dressed' causing new seal to prematurely fail?
Fiesta has a tortion bar, trailing arm back axle. A side swipe into a kurb or similar can bend an arm or mnounting. Consequent misalignment can then cause the car to crab, BUT symptom would tend to be uneven tyre wear, before bearing failures, so I think unless the tyres were pretty ropey, I'd be looking at the hubs and stub-axles.
£50 is a pretty low price for an independent to charge for a pair of wheel bearings, likely that its a job they've given the aprentice (its a simple one!) and that they will have used cheapest parts.
This is good, means its a dead simple DIY job for you to do yourself.
Get a Haynes. You'll probably need a big socket or spanner, probably around 22mm for the hub nut, and possibly the borrow of a hub puller, but if the jobs been done recently, you should be able to take the wheel off, undo one big nut and slide the hub off.
Then a xcase of beating the bearings & seal out with a hammer & drift, cleaning everything, fitting new good quality replacements, cleaning & inspecting the stub axle, greasing it all back up and puting it back together. Pre-load on the bearings can be set by hand. You tighten the hub nut up until the hub wont turn, then back it off 1/4 turn at a time until it just spins freely, then tab over the lock washer!
It really isn't a scary job. Probably £30 worth of bearings & seals, and an afternoon with basic tools, and the paynes manual.
IF there is a question mark over the stub axles, then replace.
Obviousely new will be the definitie answer, but they are likely to be expensive. I have no idea how much. Depends on main stealer price structure. Could be anything from perhaps a tenner, up to couple of hundred each, depending! If exhorbitant, procure from a breakers, better ones will inspect & make sure they are OK for you before you buy. Normally bolt to the axle via three or four bolts, only thing you'll need to swap them is a decent breaker bar to take them off and a torque wrench to tighten them back up.
Again, hubs off, shouldn't add more than half an hour to the job.
While muggering about in the back hubs, though, worth inspecting the brakes. Seem to rcall that the Fiesta has a rather wampy self adjusting hand-brake mechanism inside the back-plate, at the bottom where all the brake dust collects. Bit of time cleaning that up can make the hand brake a lot more effective as well as the main brakes, if you bleed them after.
OH forgot!
If the hub-seals have failed, grease on the back-plate is often a clue. If it IS present DEFINITELY check the brakes over, & clean, and its probably worth replacing the shoes, as grease can contaminate the frition material.
HD
PostPosted: 17:27 - 31 Oct 2010    Post subject: Reply with quote
How can you tell if a car bearing has failed?
What is crabbing? (guessing where the wheel is out of alignment and the whole car is moving forward and the wheel is going at a different angle?)
Sorry to be a dumbass, but hey, Im still learning Mr. Green
PostPosted: 17:28 - 31 Oct 2010    Post subject: Reply with quote
No new wheel bearing should fail in a week. My guess is if they weren't poorly fitted then they weren't changed at all, just cleaned & greased to shut them up and the fitter counted on them lasting a little longer than they did.
Teflon-Mike
tl;dr
PostPosted: 18:02 - 31 Oct 2010    Post subject: Reply with quote
Normally a speed dependent whine developes, with a little steering vuageness. When you hear grinding and clanking noises, its normally BAD.... then the wheel locks solid at a funny angle when the bearing colapses!
Technically the body of the car is travelling slightly sideways when its going in a straight line, the wheel alignment under the body being 'out' in relation to the body's axis.
If you have bent a rear radius arm, that would tend to make the car steer strangley, but adjusting the tracking, angle of the front wheels in relation to each other can sometimes true things up a bit, but cause the car to crab. Depends on how out of align the back axle is to body or the radius arms to each other what effect you see, but normally always accompanied by accelerated and or uneven tyre wear.
stonesie
PostPosted: 19:57 - 31 Oct 2010    Post subject: Reply with quote
CHR15 wrote:
have they been correctly preloaded?
Good point..
I always gunned them until the nut (multi layered, self locking affair) was 'down' then gave them the final tightening with a torque wrench.
235 N:m / 174 Lb:Ft
I had to google that as its a good few years since I have done one.
pits
PostPosted: 21:20 - 31 Oct 2010    Post subject: Reply with quote
As said, or dependant on what type of bearing it is, you can jack the car up and see if the wheel rocks side to side and has any play in it that it shouldn't have, "hub bearings" however wont rock back and forth as they are in a casting
*tit bit of info aswell, never ever attempt a rear wheel bearing the the big fuck off 4.2 litre Phaeton, if anyone asks you to do it, tell them to fuck off.
Martay
PostPosted: 22:33 - 31 Oct 2010    Post subject: Reply with quote
Hi,
many thanks for all the advice. Lots of good stuff to consider.
Trying to respond to all the points:
I dont rag it at all, NO handbrake turns. The fiesta has an intersting (useless) self adjusting handbrake system. You can not physically lock the rear wheels, no matter how hard you yank the lever. Dont get me wrong, i tried it ONCE.
Tyres: Fronts seem to wear the outside edges, rears wear evenly allover. When i bought the car, it had old tyres on so i could see the wear easily. Fiestas tend to have bad camber issues when the front lower arms go, this would show on the tyres. I have obviously put decent tyres on now.
Wheels : Il put my steels back on and see if it helps. These problems were occuring before the alloys were put on.
It was deffinatly a new bearing, as i asked to have the old one, in a hope i could see why they're going so quick.
The car doesnt crab. Although whyen i removed the rear seats (to clean, not stripped out) there was little cubes of broken glass under the seats + carpet. I have had the car looked at (when i had the 3rd bearing done) and the garage said nothing is wrong underneith, so im assuming its been broken in to.
I will look into getting a laser alignment done.
Im not confident on doing the bearing myself. Not that i dont think im capable, but after seeing, and being part of a bearing collapsing at speed, i know how badly things go when they go. Id rather get someone 100% confident in a workshop to do it, rather than me on my drive. I have all the tools, but no.
I jacked the car up tonight and checked each wheel. It is deffinatly the rear left wheel, it clicks and moves.
Martay
PostPosted: 22:54 - 31 Oct 2010    Post subject: Reply with quote
Ive taken it to 2 different garages now.
The one that collapsed ive still got. The other one that went, but didnt collapse i threw away :/
Want pics?
Martay
PostPosted: 23:01 - 31 Oct 2010    Post subject: Reply with quote
https://i279.photobucket.com/albums/kk125/MartayP/P110510_16280001.jpg
^grease run down wheel^
https://i279.photobucket.com/albums/kk125/MartayP/P110510_08490002.jpg
https://i279.photobucket.com/albums/kk125/MartayP/P110510_16270002.jpg
https://i279.photobucket.com/albums/kk125/MartayP/P110510_16270001.jpg
^you can just make out melted/worn out rollers in there ^
Tyres that came off front when i bought the car.
https://i279.photobucket.com/albums/kk125/MartayP/P170410_20260001.jpg
https://i279.photobucket.com/albums/kk125/MartayP/P170410_20270001.jpg
jimspeed
PostPosted: 22:43 - 01 Nov 2010    Post subject: Reply with quote
a bearing that broken WILL have damaged the stub axle too as it has tried to seize tio it, if the stub axle is damaged in any way it needs replacing as it will just casue the next bearing to fail (as you have found out).
I can't believe that a decent garage didn't at least advise you of this at the time when it was stripped down.
easy and cheap solution is a couple of used stub axles and hubs from a scrap yard/breakers its only 4 bolts each side and the stub will come off with the brake drum and hub all attached.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Martay
PostPosted: 01:13 - 02 Nov 2010    Post subject: Reply with quote
Thanks for the advice.
The car is booked in at Ford tommorow to have its arse end looked at. Im already lubing up in expectation.
Even if the stubby is damaged from the one collasing, why are the ones the other side going too?
Currently its 2 on the right, 2 on the left that have gone.
jowettdriver
PostPosted: 17:42 - 03 Nov 2010    Post subject: Reply with quote
I have had some experience with this with my grandfathers car (Ford Escort) He went through 4 different sets of rear wheel bearings all on the rear nearside. They were fitted by different garages, the last one being a Ford main dealer.
After the last set started to go my Dad and I said we'd change them for him as this was getting ridiculous. We removed the hub and took the bearings out, luckily for him the stub axel was fine still. Sure enough the bearing was on its way out again. We reasembeld it with new genuine ford replacement bearings and it has been fine ever since. 50,000 miles on and all is fine still.
We can not be sure as to why the previous 4 failed but I do wonder if it was down to a lack of cleanliness on the part of the mechanic fitting the new bearings. Obviously everything must be scrupulously clean when fitting bearings.
I know this doesn't help your predicament but just shows this can happen and you are not the only one. Best of luck with it, lets hope your Ford dealer know what they are doing!!!!
Tim.
Bikes: 1980 Honda CX500, 2003 Honda CB250, 1980 Honda CG125
The last post was made 15 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 131.61 Kb
