| russeleoin |
 russeleoin Nova Slayer
| SpannerMonkey |
 SpannerMonkey World Chat Champion
 Posted: 20:24 - 27 Oct 2010 Post subject: |
Ahhh... the YB100, Memories of this bike flood back to me of pillion induced wheelies on take-off and general illegitimate behaviour...
I'm pretty sure there ARE 6v led's out there, but what you have to remember is LEDs are directional and only shine the way they are pointing unlike a conventional bulb...
https://www.norbsa02.freeuk.com/goffyleds.htm
Check that site out. |
| russeleoin |
| Nexus Icon |
| russeleoin |
| jimspeed |
 jimspeed World Chat Champion
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Paxovasa |
 Paxovasa World Chat Champion
| Wafer_Thin_Ham |
 Posted: 21:38 - 27 Oct 2010 Post subject: |
Have you tried looking for brighter bulbs? ____________________ My Flickr |
| russeleoin |
| chris-red |
 Posted: 22:34 - 27 Oct 2010 Post subject: |
I'm not sure how well direct AC lighting would cope with LEDs. It could conceivably have a tantrum because the LED would essentially stop half the current flow. If it didn't, you'd need to fit a huge ballast resistor to take up the difference in amps or the other bulbs would all pop too.
I suppose you could fit LED lights all round and re-jig it to run everything off the battery.
Or fit one of those super-duper bicycle lights as well as the standard headlight and charge it up every night.
A slight fly in the ointment is that last time I looked, your headlamp has to have a filament type bulb. It's a regulation that was brought in to stop people using acetylene lights when LEDs hadn't even been invented. They might have changed it by now though? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Myler |
 Myler Borekit Bruiser
| Blue_SV650S |
| russeleoin |
 Posted: 22:50 - 27 Oct 2010 Post subject: |
I have found these and have ordered a 15 watt and a 25 watt. The only issue I can see is that my bulb is the dual filament and these will only be single, so it is dip or bright only. Do I have to have both dim and bright for MOT. I may just see if I can put in a tempary fit so I can put the old bulb back at MOT time.
https://www.classic-car-accessories.co.uk/acatalog/12_volt_bulbs.html
CLB72
6 volt x 25w H3 halogen bulb for headlights, spotlights and foglights for cars bikes and scooters with a 6 volt system. Although the wattage is fairly low, to place as little strain on the system as possible, the light output is brilliant white giving high luminous intensity. Also used as a replacement bulb for hand held spot lights.
Thanks Myler, that looks like a plan. I may try and copy thay.
Russ ____________________ I love classic merc's but bikes take up less space.
Current ride is a Yamaha YB 100 and I love it! Oooow and now a running GPZ400R!
Next stop, Direct Access hopefully by the end of summer. |
 Posted: 23:15 - 27 Oct 2010 Post subject: |
With that lighting system, you need to fit a bulb with pretty much the same wattage as the original. Fitting a higher wattage one will just make it dimmer because there isn't enough power to light it up properly. A lower wattage one will pop.
What I have considered doing is converting my girlfriends one to DC lighting with as many LEDs as possible and fitting a proper 6V reg/rec to it instead of the current system of a single diode and hoping the battery takes up any slack. It's all a bit too much like wishful thinking for my tastes as standard.
You can use a standard three phase reg/rec and attach the single charging phase to one of the wires. Getting a 6V, low wattage flasher unit to run LED flashers might be problematic though.
EDIT: I did actually consider mounting a couple of 6V LEDs on a small circuit board with a clock timer circuit and attaching it to the inside of the flasher unit so the flashers flashed autonimously, just need to feed them 6V DC and they flash by themselves. The downside is that they would all flash in their own time (not together). I think this is ok though, my Tomos moped had a flasher relay that made them flash front-back-front-back because it was too weedy to power both flashers at once. The only reg I can find is that they must flash at between 60 and 120 flashes per minute, no mention of them being synchronised. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| 27cows |
 27cows World Chat Champion
| russeleoin |
| Blue_SV650S |
 Posted: 09:35 - 31 Oct 2010 Post subject: |
Yep, an LED rear light will gain you ~5w of headlight power - have one in my bike - not for power reasons, but they don't suffer from vibration problems like a normal bulb!  ____________________ The purpose of life is to fight maturity. |
| hmmmnz |
 hmmmnz Super Spammer
| G |
 G The Voice of Reason
| truslack |
 truslack World Chat Champion
 Posted: 12:32 - 31 Oct 2010 Post subject: |
Is it a bad beam pattern? I can ride comfortably on my H100's headlight at night  ____________________ Current: Suzuki RG 125 Gamma, Honda H100, Triumph Tiger 800XC, Suzuki SV650 (minitwin) |
| Blue_SV650S |
| Teflon-Mike |
 Posted: 16:18 - 31 Oct 2010 Post subject: |
Isn't the YB100 lighting circuit Direct off the mag?
Ie head & tail run on AC and can glow bright or dim depending on revs?
If so, higher wattage bulbs, as suggested my actually be dimmer, due to just not getting enough power.
Idea of using LED tail, as suggested may have problems from rectification effect, bulbs are diodes, so they'll only take volts on half of each ac wave.
Reading commentry, my thoughts were the auxilliary 12v lamps on a house alarm battery. Probably still the way to go, but, comment about switch & beam pattern did make me wonder.
Old addage, more usually applied to engines, is before looking for MORE than standard, make sure you got what you should AS standard.
I was wondering whether old wiring, & corroded connectors could be putting load on the circuits & dropping the volts your actually getting at the bulbs.
Stripping & cleaning connectors may have a pretty big effect; swapping out old ropey wiring might too.
In a similar vein, the headlamp itself. Whats the silvering like on the reflector? Whats the lense like?
Mirroring in the reflectors often goes dull with age, and lenses can go 'dull' with years of crud etching them.
a new headlamp, with nice shiney missoring and a cleaner lense, might work wonbders, just making best use of what light the bulb does chuck out.
Probably still not amazing, given its 6v direct, but could be enough.
Other one on 6v direct lights, if they do go bvright & dim with revs, have you tried riding in a lower gear?! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 15 years, 364 days ago. Instead of replying here, would creating a new thread be more useful? |
