MOT - Indicators
JD-234
PostPosted: 01:43 - 01 Nov 2010    Post subject: MOT - Indicators Reply with quote
Hi there,
Would my DT pass an MOT without indicators.
I've heard that if you dont have any indicators then it will but if you have them and they dont work it wont.
Thanks JD
blurredman
PostPosted: 10:19 - 01 Nov 2010    Post subject: Reply with quote
I believe the way it goes is:
If there is no switch, then it's fine not to have something.
Wanna take your light off? You can, but you gotta take the switch off too, same for indicators.
Not sure about the brake, though why get ride of the brake light Smile
TimNorwich
PostPosted: 10:36 - 01 Nov 2010    Post subject: Reply with quote
Why not just buy some cheapy mini-indicators? You could get a pair for £20, and as a result you will be safer on the roads too.
PostPosted: 10:42 - 01 Nov 2010    Post subject: Reply with quote
How old is the bike.
If it is newer than mid 1980s then it must have indicators (older than that and no trace of them is fine). Cut off date is 1/8/86.
There is the day time MOT fiddle (so no lights).
There is also an exemption for solo off road machines.
JD-234
PostPosted: 12:48 - 01 Nov 2010    Post subject: Reply with quote
If direction indicators are fitted they must meet the requirements of this inspection, but need not be fitted to a machine which:
. cannot exceed 30mph / 50kph, or
. was first used before 1 August 1986, or
. 'off road' machines which are designed
to carry only the rider.
. 'off road' machines with side car designed to carry the rider and one passenger in the side car.
off road machines are constructed or adapted primarily for use off roads (whether by reason of its tyres, suspension, ground clearance or otherwise).
Going by this i will pass an MOT if i dont have rear foot pegs then, which i dont have anyway
PostPosted: 12:53 - 01 Nov 2010    Post subject: Reply with quote
Don't think a DT would be classed as constructed or adapted primarily for use off roads, being built primarily as a road bike.
JD-234
PostPosted: 13:50 - 01 Nov 2010    Post subject: Reply with quote
Well it has nobblies, long travel suspension and a big ground clearance. So why wouldn't i be able to say that i use it off road and green laning
Paxovasa
PostPosted: 13:54 - 01 Nov 2010    Post subject: Reply with quote
Because they are designed to be a road worthy 125 cc trail bike.
The nobblies are the dual purpose type.
PostPosted: 13:59 - 01 Nov 2010    Post subject: Reply with quote
It has longish suspension travel, road biased knobblies and slightly increased ground clearance. However it was built with road equipment such as indicators and a horn.
Think under SVA rules there is a specific limit for ground clearance to be treated as an off road bike and that is a min 900mm seat height and min 310mm ground clearance (different limits for trials bikes but with the addition of a fuel capacity limit). It would make sense for the same limit to be the one used for the MOT.
It is not what you claim to use it for but whether it was "constructed or adapted primarily for use off roads". Being a road bike it certainly wasn't constructed primarily for use off roads.
It will probably come down to how sympathetic the MOT tester is
The last post was made 15 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 63.85 Kb
