RXS won't start
Dan79
PostPosted: 21:22 - 01 Nov 2010    Post subject: RXS won't start Reply with quote
On my commute home this evening the engine of my RXS100 spluttered, the exhaust went bang, and then everything died very suddenly, with very little warning. Much more sudden than failure of spark plug.
A new spark plug did not cure it - engine will turn, but there is no spark at the spark plug when removed from the cylinder. The neutral and oil lights light up.
Any ideas ? Could the ignition switch be at fault, or is there something else I should be checking ?
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
Syris the Indomitable
PostPosted: 22:39 - 01 Nov 2010    Post subject: Reply with quote
Well as previously mentioned, no spark means coil, CDI & timing
My guess is:
This means unburnt exhaust gases as a result of timing being out which could indicate the points have malfunctioned.
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
27cows
PostPosted: 08:14 - 02 Nov 2010    Post subject: Reply with quote
Check for water in the stator components, particularly under the coils. Attack with WD40/similar.
PostPosted: 09:22 - 02 Nov 2010    Post subject: Reply with quote
BLUEX5 wrote:
Make your fucking mind up Rolling Eyes
https://img219.imageshack.us/img219/637/dummyspit.gif
The last post was made 15 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.72 - MySQL Queries: 15 - Page Size: 55.18 Kb
