rs125 nostartin
andy 13
PostPosted: 17:39 - 27 Oct 2010    Post subject: rs125 nostartin Reply with quote
Hey all can sme 1 help please am having problems with ma rs125 1998.
it just wnt start my coil is working great cdi unit brand new getting a great spark and ma battery is brand new aswell, and still nothing any sujestions would b much appreciated.
thanks andy
Quote Me Happy
PostPosted: 17:46 - 27 Oct 2010    Post subject: Reply with quote
Is it getting fuel?
andy 13
PostPosted: 17:55 - 27 Oct 2010    Post subject: Re: rs125 nostartin Reply with quote
thanks andy
yeah its gettin plenty of fuel mate
HD
PostPosted: 17:59 - 27 Oct 2010    Post subject: Reply with quote
Have you checked properly?
Drain your carb, clean your fuel filter, maybe the air filter too.
andy 13
PostPosted: 21:51 - 01 Nov 2010    Post subject: Re: rs125 nostartin Reply with quote
thanks andy
Rite thats the air filter cleaned and back on carb stripped down and cleaned out cdi unit replaced coil replaced battery replaced and charged now have a crackin spark plenty of fuel getting through and good compression but still wnt fire up any sujestions cheers
Syris the Indomitable
PostPosted: 22:19 - 01 Nov 2010    Post subject: Reply with quote
Is the plug wet through?
You could be way to rich.
If not check behind the dash and see if you got one these playing havock.
https://img202.imageshack.us/img202/1871/meninblackalien.jpg
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
PostPosted: 22:24 - 01 Nov 2010    Post subject: Reply with quote
Can you bump start it?
Helped someone with an RS125 once which would bump start but not start on the starter motor. Taking the plug out gave a decent spark.
Problem turned out to be the clearance between the crankshaft position sensor and the flywheel which was WELL over that specified. On the starter motor with the plug in place it wouldn't spin over fast enough to trigger the ignition. With the plug out it would spin over more quickly and so spark.
andy 13
PostPosted: 22:30 - 01 Nov 2010    Post subject: Re: rs125 nostartin Reply with quote
thanks andy
Hi when i take the plug out it is wet not soaking (like its been flooded) and it wnt bump start either is there any way a can check the sink of the spark thanks
andy 13
PostPosted: 22:35 - 01 Nov 2010    Post subject: Re: rs125 nostartin Reply with quote
thanks andy
Ichor i think u may b on 2 something u got the number for the MIB
PostPosted: 22:48 - 01 Nov 2010    Post subject: Reply with quote
LOL, I know a man who knows a man!
Is the spring loaded slide which the needle is attached to right down to the bottom of the carb, there is a notch it slides down when you fit and screw the top of the carb back on, If not it won't start.
Yeah so just wondering about mixture then running to rich or a jetting issue, even the reed block not dispersing the mixture. (No ones messed with the reed block have they?
I had a nightmare with one of those carbs, with the one I had one of the floats were actually filled with petrol affecting the float height, and just because of this the bike ran terrible. I got the impression it was made that way to fail after a certain period of time. Those Aprilia's are now made to fail in a number of ways up to 7000 miles.
andy 13
PostPosted: 23:02 - 01 Nov 2010    Post subject: Re: rs125 nostartin Reply with quote
thanks andy
hey
The slide in the carb appears 2 be working i have a spare carb for it aswell av been told the mixture screws should be set at 2 turns out av tried them all in and out the reed valve appears fine aswell,PURE NITEMARE
2Smoke
PostPosted: 10:15 - 02 Nov 2010    Post subject: Reply with quote
Hi, you could have a flooded engine.. Try turning the fuel off, taking the plug out, putting it in gear and pushing it along for a bit to clear any fuel from the crankcases. Leave it for half an hour, go for a beer smoke whatever. Dry the plug out (heating it works well too). re-fit it, and see if it'll start.
Other possibilities are:
Crank seal popped out, can happen if there is excess fuel in the cases and it ignites.
Bad fuel (could be worth trying some fresh stuff)
Ignition timing out (woodruff key sheared and flywheel rotated on the taper)
Lack of compression through damaged bore/piston. Spin the motor over with the plug out, stick your thumb over the plug hole and see how much force there is.
Water contamination, maybe headgasket failure or through water in the fuel.
Have you tried draining the carb?
Did it just suddenly stop running or has it been sat for a while?
andy 13
PostPosted: 13:59 - 02 Nov 2010    Post subject: Reply with quote
The carbs been drained and cleaned out about a million times woodruff key is fine plenty of compression and not flooded it was runnin when it happened was actualy running perfectly couldnt have asked for better then it died and hasnt turned over since thanks
PostPosted: 16:21 - 02 Nov 2010    Post subject: Reply with quote
I think this is a case for M&S https://img714.imageshack.us/img714/4993/76358856.jpg
Not messed with the jets or needle height at all have you?
The standard main jet on a 28mm carb is a 120, so id be buying a 122 and 124 to start off and see how you go.
The main jet only controls the third 60 - 100% of your throttle therefore, you will need to adjust the needle jet for the rest of the throttle 35 - 60%.
Other than that all you need is a Deloroto VHSB 34MM
2Smoke
PostPosted: 09:51 - 04 Nov 2010    Post subject: Reply with quote
Well the main jet does have an influence on the running throughout the throttle range, but I dont think this is the problem.
Andy, have you taken the exhaust off at all and looked up the exhaust port at the piston? Be worth looking for signs of a partial seizure.
PostPosted: 11:39 - 04 Nov 2010    Post subject: Reply with quote
2Smoke wrote:
Well the main jet does have an influence on the running throughout the throttle range, but I dont think this is the problem..
It shouldn't because the needle jet will restrict the flow to a lower amount after it on smaller throttle openings.
Years ago the atomiser tube on the Gilera CX125 sheared off, effectively leaving the bike running without any form of main jet. Up to about 6 k on normal throttle openings it ran OK.
andy 13
PostPosted: 16:36 - 04 Nov 2010    Post subject: Reply with quote
Hey
the topend of the bike was just recently rebuilt and av had it on and off a couple of thimes checking the rings as for the jets i havent checked them but i do have 2 spare carbs and it wnt fire on any of them wats the chances they could all b fuked cheers
PostPosted: 16:50 - 04 Nov 2010    Post subject: Reply with quote
Not that high. Normally with a carb problem (unless very major) I would expect it to be startable with a bit of effort, even if it runs like a dog.
andy 13
PostPosted: 18:55 - 04 Nov 2010    Post subject: Reply with quote
Hey
the bike wnt fire up atall with any of the carbs in a canny b that unlucky can a lol
The last post was made 15 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 108.77 Kb
