Fitting a New Chain yourself ?
blownygti
PostPosted: 13:36 - 03 Nov 2010    Post subject: Fitting a New Chain yourself ? Reply with quote
I have a new DID X ring chain coming to fit to my NC29 I have got the old one off via a hacksaw, has anyone fitted a new one with the usual chain tool ? if so what did you use and how easy was it ? I believe all you need to do is mushroom to end of the link rivetr link is this correct ?
https://www.bikepics.com/members/blownygti/90cbr400/Default.asp
DrDonnyBrago
PostPosted: 13:57 - 03 Nov 2010    Post subject: Reply with quote
I used one of these on a DID 525VX chain with soft link rivet:
https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Products/CHAINTOOL
Cost me £22, it is identical to another one I found an instructions PDF for that was stamped with motion pro, everyone seems to use the same tools stamped with their own logos. It is a good piece of kit, it seems well made considering it is so cheap. Kickstart has the same chain tool also.
The tool did require a small amount of modification to fit the DID master link:
https://www.bikechatforums.com/viewtopic.php?t=199399&highlight=press+plate+modify
Overall though it is pretty simple, here is the instructions PDF for the tool I bought (well the branded version of the identical tool):
https://www.motionpro.com/images/documents/08-0058.I8-0058.pdf
Quote Me Happy
PostPosted: 14:17 - 03 Nov 2010    Post subject: Reply with quote
It's very easy if you have a decent tool. I have one from B&C Express that makes doing it pretty fool proof although it was quite pricey at £70. It's already done more chains than my old Motrax one that broke on it's 3rd chain though.
PostPosted: 14:26 - 03 Nov 2010    Post subject: Reply with quote
I've done somewhere around 10 chains with my Heine Gerickes own brand chain tool. Cost £65.
I've also done quite a few with mole grips and a small nut at the side of the road in my time but the chain tool is definately the way forwards.
The last post was made 15 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 40 Kb
