| sinety |
 sinety L Plate Warrior
| Skinned |
 Skinned Renault 5 Driver
| sinety |
 Posted: 20:09 - 03 Nov 2010 Post subject: |
i have no idea what the Fuel Filter is
i filled it up with petrol yesterday and theres loads in there so it deffinetly isnt that.
i guess ill just have to take the body off and fiddle around untill i find the carb ha |
| Syris the Indomitable |
 Syris the Indomitable Crazy Courier
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 22:27 - 03 Nov 2010 Post subject: |
read this https://www.bikechatforums.com/viewtopic.php?t=17124
Dellorto's are fairly easy to dismaantle & re-assemble
lift fuel tank & follow fuel hose from the tap on tank, down to where it clips onto the carb. (you may have an in-line fuel filter 1st, this will ned cleaning or replacing) & remove the bolt holding the banjo on (8mm socket iirc) & underneath this is a disc shaped nylon gauze fuel filter.
remove & clean.
remove the carbs float bowl while your there & give the jets a good spray with carb or brake cleaner, then blow through with airline.
cheers,
GAZ |
| alains |
 alains World Chat Champion
The last post was made 15 years, 349 days ago. Instead of replying here, would creating a new thread be more useful? |
