Derbi gpr50
Turborange
PostPosted: 11:38 - 04 Nov 2010    Post subject: Derbi gpr50 Reply with quote
Hello
I have a 2005 gpr50 which isn't running right by any stretch of the imagination.
When I got it it had an arrow exhaust fitted what else I am unsure. There was a flat spot between 6-7k. The idle was a bit rough and sometimes didn't idle at all. A quick spray of carb cleaner on the body of the carb and the was an idle. But when it came to riding it you had to have the choke on a bit. I took it and a so called bike specialist who had the bike for 7 days and charged me £70 for the privilege. The bike then would not start at all. I called the aa out who on removing the plug show petrol dripping off the plug. They semi got me running again no choke at idle but choke to ride and still have flat spot.
Do you think that the carb is knackerd or is it just the jet needs doing.
Does anyone have a setting to go by on these carbs? I am now reluctant to take it to another bike shop to have my pants pulled down again. I am fine with spanners so doing. The work myself isn't to much of a issue. Based in Sheffield all help would be appreciated
Turborange
PostPosted: 12:23 - 04 Nov 2010    Post subject: Reply with quote
Don't know if it's been jetted what size should it be and where would I get one
Frost
PostPosted: 13:45 - 04 Nov 2010    Post subject: Reply with quote
Sounds like it's running richer than a rich thing that's just won the lottery.
New plug, find a manual online somewhere and find out the following:
Mixture screw position
Jet size
Needle height
Someone compotent with the spanners could remove, strip, clean check, rebuild and refit the carb in half an hour or so. You could probably do it in a few hours with the following tools:
Screwdrivers, flat and cross head of various sizes
Spanners, 8mm, 10mm, 12mm
And thats about all you need to do most jobs on most bikes, well worth buying!
The bike needs the following to run right:
Compression
Fuel
Spark
Air
In this case it sounds like fuel is probably the issue from someones past attempts at tuning. But don't forget the others! Check the airbox fits properly and seals onto the carb. Make sure it has no water in it and that the air filter is clean.
Put the spark plug against the engine and press the starter and see if it sparks
Compression is a bit more of an issue to check an requires a special compression tester and a rebuild to fix. So it's best to rule out everything else first.
Turborange
PostPosted: 15:41 - 04 Nov 2010    Post subject: Reply with quote
I have thought all along that it is fuel that is the issue here. I have already done the spark which is spot on. I have a compression tester so it's just a case of finding a manual for the correct compression and carb settings. I didn't see a filter element in the box. Would a k&n be ok or similar filter. I have a small one kicking around off one of my old cars oil breather system
The last post was made 15 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 54.35 Kb
