Carb Restriciton
Redoko
PostPosted: 21:39 - 04 Nov 2010    Post subject: Carb Restriciton Reply with quote
My friend has a '99 600 gixx,
Restricter is a washer in the carbs.
He has come to the end of his restriction, how would we go about getting it out... As he can't afford a proffesional to do it.
Mr. Green Thumbs Up
L4Isoside
PostPosted: 21:42 - 04 Nov 2010    Post subject: Reply with quote
Lift up the tank, take off the carbs, reveal washers... reverse Razz
Redoko
PostPosted: 21:51 - 04 Nov 2010    Post subject: Reply with quote
Was hoping for a little more detail but that'll have to do.
L4Isoside
PostPosted: 22:02 - 04 Nov 2010    Post subject: Reply with quote
Sorry there isn't a lot more to it tbh Confused
Except, you may have to remove the seat to lift the tank, pull off a hose or two from the tank and unscrew the carb fixings to be able to lift them off.
0l0dom0l0
PostPosted: 23:38 - 04 Nov 2010    Post subject: Reply with quote
If he can afford it, get a haynes. It will have detail about removing the carbs and you will see the washers. Just oik them out with a screwdriver and reverse!
Redoko
PostPosted: 23:48 - 04 Nov 2010    Post subject: Reply with quote
Think I got one banging around somewhere, might be back at uni though. Will have to wait till next weekend then.
Cheers guys.
Karma
Ingah
PostPosted: 23:51 - 04 Nov 2010    Post subject: Reply with quote
Have you considered the possibility that the jets could've been changed as part of the restriction?
-- Ingah
Redoko
PostPosted: 23:56 - 04 Nov 2010    Post subject: Reply with quote
Hmm.
If so, what problems would this occur?
L4Isoside
PostPosted: 00:06 - 05 Nov 2010    Post subject: Reply with quote
Redoko wrote:
Hmm.
It would change the fuelling, but I very much doubt they have been changed, likely hood is 4 washers under the carbs.
Ingah
PostPosted: 00:07 - 05 Nov 2010    Post subject: Reply with quote
Well, id've thought not changing it back would make it run too rich or too lean, depending on what was changed (i can only speak for the CB500, but i can tell you that if the restriction has been done properly - i.e. the jets changed to the BIGGER #125 size - then failing to change them back would mean the derestricted machine was running too rich).
-- Ingah
Ditto
PostPosted: 00:16 - 05 Nov 2010    Post subject: Reply with quote
Have a look at this thread I did a while ago:
https://www.bikechatforums.com/viewtopic.php?t=193237&highlight=anyone+confused+fit+restrictor+kits
Its for a Bandit but if its washer restricted youll get the general idea about where everything is.
My mate had a CBR 600 which wasnt rejetted but it had slides in the carbs to prevent the diaphragm opening fully so could look for that aswell.
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
The last post was made 15 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 71.82 Kb
