wee lead just stoped
skikman
PostPosted: 18:55 - 05 Nov 2010    Post subject: wee lead just stoped Reply with quote
hi.i took my honda lead 100 out for a run today and only got out of my estate and it stopped.i wheeled it home and took it round the back to have a look.tried it again and it started,ran for a while then stopped.sounded like a fuel problem so i checked it was getting fuel ok,it was.then i took out the plug and checked for spark.no spark.tried different plug,still no spark.then tried different coil and lead,still no spark.fuse is ok as lights and horn work.wire connections from engine seem ok.not sure how to check cdi but connections to it look ok.any ideas?
TQ
PostPosted: 01:23 - 06 Nov 2010    Post subject: Reply with quote
Kill switch?
I don't just mean the switch itself I mean the contacts inside. Check the resistance through the switch with it set to "Run".
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
yen_powell
PostPosted: 09:36 - 06 Nov 2010    Post subject: Reply with quote
Did you open the fuel cap just before it started again? Sometimes the fuel cap breather gets blocked and the bike runs until the air in the tank disappears then cuts out. Open the fuel cap, replenish the air and the problem repeats itself. Cure is to blast some air through the cap's breather hole, on locking caps that is also the key hole.
XT1200Z and a DR350 in bits
skikman
PostPosted: 12:27 - 06 Nov 2010    Post subject: Reply with quote
its not a fuel problem.it has no spark
skikman
PostPosted: 12:31 - 06 Nov 2010    Post subject: Reply with quote
TQ wrote:
Kill switch?
no kill switch on the bike.ill look at the wires at where the key goes
The last post was made 15 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 43.54 Kb
