quick release nut?
gray84
PostPosted: 00:28 - 08 Nov 2010    Post subject: quick release nut? Reply with quote
does anyone know of a quick release nut?
ive just got my bike trailer and the light board is on a tilting panel which drops down when you undo 2 nuts to make access to the ramp.
its a pain in the ass doing and undoing 2 nuts and i reckon there must be some kind of quick release type thingy out there..
thanks Thumbs Up
PostPosted: 01:01 - 08 Nov 2010    Post subject: Reply with quote
People usually use an antiluce fastener for that application.
https://www.uesint.com/upload/propic/3274_001_side.jpg
yen_powell
PostPosted: 09:45 - 08 Nov 2010    Post subject: Reply with quote
Drill a hole through the bolts and fit R clips.
XT1200Z and a DR350 in bits
PostPosted: 09:50 - 08 Nov 2010    Post subject: Re: quick release nut? Reply with quote
One's I've had have often used a stud with a hole and a 'key ring' style clip - not sure the official term, but it's basically a key ring where one end points in to the middle. That makes it easier to put on and remove than a keyring, but more secure than an R-Clip.
PostPosted: 10:25 - 08 Nov 2010    Post subject: Re: quick release nut? Reply with quote
A lynch pin?
https://www.pivotpins.com/img/catimgs/lynch_pin.jpg
PostPosted: 10:29 - 08 Nov 2010    Post subject: Re: quick release nut? Reply with quote
Ah, yes, used those as well Thumbs Up... but no, what I was describing was basically a cheaper form of one, as it's just a single bit of metal.
It wasn't actually a keyring and was designed for purpose (bit more flexible), but wasn't far off.
DrDonnyBrago
PostPosted: 10:33 - 08 Nov 2010    Post subject: Re: quick release nut? Reply with quote
https://www.force4.co.uk/4059/Marine-Pre-Packs-S-S-Split-Ring----25mm--2--.html?referrer=froogle&utm_source=google&utm_medium=froogle&utm_campaign=pid4059
Them?
gray84
PostPosted: 21:48 - 08 Nov 2010    Post subject: Reply with quote
thanks for the ideas guys.....from the way there is a threaded stud already welded in place and i am limited to room i think a nice chunky R clip would be good if i can drill through the stud...
The last post was made 15 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 56.74 Kb
