Like a bit of maths? Have a go at this...
PostPosted: 00:31 - 12 Nov 2010    Post subject: Like a bit of maths? Have a go at this... Reply with quote
This is a question in my analytical methods assignment on my HNC construction course. I've already got the answer, but it's quite an easy question once you know what you're doing, just takes a little time to work out.
A site is surveyed and it is found that the angle to the top of the main building is 45 degrees when measured from a distance. When measured from 200 metres closer, the angle is 80 degrees. Assuming the ground is horizontal, make some practical calculations using degrees and the three trigonometric ratios, sin, cos or tan to find the height of the building.
Please post your answer up in size 1 writing so as not to spoil it for other people if you do get the answer right Thumbs Up
rac3r
PostPosted: 00:33 - 12 Nov 2010    Post subject: Reply with quote
1
Chequered Flag
PostPosted: 00:37 - 12 Nov 2010    Post subject: Reply with quote
Are you stupid, Warped?
Stand at the side of your house from ten metres away, look up to the top of it, now stand with you chest touching the wall of your house and look up to the top of it again.
As if by magic, the angle of your head has changed Surprised
You're going 200 metres along the ground, not up a cherry picker towards the top of the building at the same angle.
Rac3r - No Laughing
rac3r
PostPosted: 00:39 - 12 Nov 2010    Post subject: Reply with quote
ms51ves3 wrote:
Rac3r - No Laughing
Worth a shot Laughing
Thumbs Up I hate maths Thumbs Up
Chequered Flag
blurredman
PostPosted: 00:46 - 12 Nov 2010    Post subject: Reply with quote
I didn't read it through properly. I am a dick.
I know it's pythagoras triangle, you work out the final angle degree by using the 45 and 80 figures.
bacon
PostPosted: 00:53 - 12 Nov 2010    Post subject: Reply with quote
242.81m
basic maths people Razz
HP
PostPosted: 00:57 - 12 Nov 2010    Post subject: Reply with quote
The height of the bulding is the the distance of which you was away originally, however im struggling to find an exact figure for the distance.
What flavour would you like the windows Harvey?
Frost
PostPosted: 01:01 - 12 Nov 2010    Post subject: Reply with quote
242.8
PostPosted: 01:09 - 12 Nov 2010    Post subject: Reply with quote
Autocad says 242.81m Very Happy
DJH
PostPosted: 01:12 - 12 Nov 2010    Post subject: Reply with quote
I don't know.
L4Isoside
PostPosted: 01:15 - 12 Nov 2010    Post subject: Reply with quote
So in "everyday" life, when will I ever need to do this? Razz
Frost
PostPosted: 01:20 - 12 Nov 2010    Post subject: Reply with quote
If you're an engineer wanting to know how high something is and you don't have a tape measure long enough?
Something similar to this was first used to calculate the size of the earth.
L4Isoside
PostPosted: 01:37 - 12 Nov 2010    Post subject: Reply with quote
Fair enough
I won't learn how to Razz
PostPosted: 02:23 - 12 Nov 2010    Post subject: Reply with quote
https://i48.photobucket.com/albums/f216/stinkwheel/trig.png
Fukin' maths!
Stinkwheel used his head, (but a scientific calculator, not Trig tables)
EDIT: Also. I've drunk 5 pints of magners.
EDIT 2: I should also add, it's been 16 years since I did maths and I also claim full marks for showing my working.
PostPosted: 02:50 - 12 Nov 2010    Post subject: Reply with quote
Ever use an OS map? How do you think they worked out how far apart everything is?
https://www.trigtools.co.uk/images/primary-rays2.png
They only measured one of those lines in the South of England, then did another in the North of Scotland to check their sums. They were less than two inches out.
ollieholt
PostPosted: 03:09 - 12 Nov 2010    Post subject: Reply with quote
hehe pervascope.... thats hilarous! Laughing
Laughing < This? Well this is just a day brightner.
swanny
PostPosted: 07:42 - 12 Nov 2010    Post subject: Reply with quote
well if you stand next to the building and look up, its at 90 degree's unless its built by cowboys in which case the whole equation is wrong.
M SWANNY.. see a sig !
PostPosted: 08:05 - 12 Nov 2010    Post subject: Reply with quote
Autocad is wrong if you do the whole calculation to 8 decimal places Wink
Well done Stinkwheel for showing your working.
Suntan Sid
PostPosted: 09:07 - 12 Nov 2010    Post subject: Reply with quote
The answer is:-
242.814m
You will never have to do that calculation in real life, you ask your CAD buddy to spare 10 secs of their time to work it out for you!
Charlie
PostPosted: 11:40 - 12 Nov 2010    Post subject: Reply with quote
Slightly different method to Stinkwheel
Although I guess I lose marks for not using a ruler Mad
qarka
PostPosted: 11:47 - 12 Nov 2010    Post subject: Reply with quote
Awesome SOH/CAH/TOA mnemonic Very Happy
You would ordinarily measure the 200 metres from the base of the wall then measure the angle (x) to the top of the building.
tan x = height/200
Not always possible to measure the distance from the base of the wall though because other buildings may be in the way and you can only get a line of sight from certain locations.
If you're stood on site with a theodolite, a mape measure and a calculator and you have to call a mate to work out the height of a building on a CAD package. The foreman is going to give you the sack.
I'm a believer in maths having a purpose though and for the people doing it to be aware of that purpose. Especially at lower levels. Someone doing an HNC in construction shouldn't have problem knowing exactly why you'd want to do that calculation. The question posted should be well within the reach of someone doing GCSE/Standard grade maths but at that level I might have worded it differently. Maybe something like this:
https://i48.photobucket.com/albums/f216/stinkwheel/baddesley-clinton-solihull-gb939.jpg
The last post was made 15 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 130.2 Kb
