SatNav doesn't work in London?
Swifte
PostPosted: 18:37 - 12 Nov 2010    Post subject: SatNav doesn't work in London? Reply with quote
Hi everyone,
I've been considering SatNav either a TomTom Rider or Smartphone with app + blue tooth headset.
I was recently speaking to someone employing london couriers who said that SatNavs couldn't handle the streets in London whether iPhone app, Android, XDA or TomTom Rider and that they would make several errors such as not handling one way systems etc. so that often you are better with a conventional map.
I find this difficult to believe and I wanted to hear it from the horses mouth, anyone from London and especially London couriers have any experience of this?
Marmalade
PostPosted: 19:38 - 12 Nov 2010    Post subject: Reply with quote
You do get the odd hiccup but not enough that a paper map would be better.
If you are in London a lot you'll learn your way around and only use sat nav for last bit of trip and if you're not it won't matter anyway.
I use a rider2 and rarely have problems but like i said, they do occur.
Peirre oBollox
PostPosted: 19:40 - 12 Nov 2010    Post subject: Reply with quote
its a common problem in major cities due to the tunnel effect created by the huge number of high rise buildings blocking out the line of sight for the GPS signal to the satnav receiving unit your using
PostPosted: 20:00 - 12 Nov 2010    Post subject: Re: SatNav doesn't work in London? Reply with quote
I've found mine Zumo 660 fine in London.
If you don't keep them up to date, you will eventually find bits that have changed.
I've found decent GPSs are fine even around central London, but they may start to become a bit less accurate as they have more trouble locking on to satellites.
doggone
PostPosted: 20:05 - 12 Nov 2010    Post subject: Reply with quote
Just the more complex nature of tightly packed streets and buildings plus dense traffic is going to mean more errors are likely.
Whenever I've been in London half of it seems to be getting dug up at anyone time.
AngelGrinder
PostPosted: 20:37 - 12 Nov 2010    Post subject: Reply with quote
Never had an signal problem, only problems seem to normally be caused by the aforementioned roadworks, one way streets or no left/right turn junctions.
Just use common sense. Also, on the tomtom (other makes may have the same feature) you can tell it to point an arrow in the direction of your destination. This way, whenever you have to deviate from the intented route, you can try and head in the right direction!!
calyx
PostPosted: 22:03 - 12 Nov 2010    Post subject: Reply with quote
As an ex London courier I must say they do work fine. Garmin was worse than the tomtom.
Signal bounces from tall building in some areas but it is very rare and you learn those areas in a month or so.
A tomtom should take you to point B 95% of the time with no problems. Just use the "shortest route" option.
Boris - London
Swifte
PostPosted: 10:00 - 13 Nov 2010    Post subject: Reply with quote
Ok so Tom Tom rider is ok.
I wanted to combine my SatNav with a phone it would save me carrying a phone and a GPS around at the same time, and if I'm going to spend £200+ I might as well get one of these smart phones instead.
Any experiences of these phones, iPhones or Androids? Do they really work in London?
How about having Android with a TomTom app and then hooking this up as well for extra connectivity? Would this work?
https://catalog.ebay.co.uk/TomTom-Navigator-5-GPS-Receiver-/55976724?_pcatid=121&_refkw=tom+tom&_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A3444&_trksid=p3286.c0.m14#pbe-rvws
Forgot to add I'm not to interested in a flashy phone a cheaper one would be fine, just want one that has decent SatNav, good internet and is a phone nothing else required.
Having said this there looks to be a bloody good deal on an HTC Desire Z on contract.
Cheeseybeaner
PostPosted: 12:06 - 13 Nov 2010    Post subject: Re: SatNav doesn't work in London? Reply with quote
Swifte wrote:
Hi everyone,
You're better off with a decent large scale master atlas really, sat navs aren't much use in town. For £16 you can get a nice hardcopy a4 book which shows you everything and allows you to easily plan your route.
The problem with sat navs is they make you lazy and you don't memorise details plus they suffer from signal issues as well as the aforementioned pointing you the wrong way up a one way street!
Personally I'd rather not rely on one.
Are you commuting to the same location every day?
AngelGrinder
PostPosted: 21:04 - 13 Nov 2010    Post subject: Re: SatNav doesn't work in London? Reply with quote
Cheeseybeaner wrote:
Swifte wrote:
Hi everyone,
You'll get out your map, plan your entire route, then the moment you arrive in London, you'll realise the junction you wanted is a left turn only, or buses only, or shut with roadworks, or theyve decided to change the one way system round the other way.
Tying to navigate to different places all day is a nightmare if you do know it. Even if you only have a rough idea of where your going, some places are an absolute maze, Soho etc.
calyx
PostPosted: 03:44 - 14 Nov 2010    Post subject: Re: SatNav doesn't work in London? Reply with quote
Unfortunately this is the reality Mr. Green
For instance; it never says "no right turn" on the map. In London there are loads of no right turn junctions. ie: charing cross to shaftesbury avenue. saville row to conduit street.
I wouldn't bother with maps. Just get a tomtom and a compass. Compass helps a lot when the junction you want is shut with some stupid reason.
Boris - London
Cheeseybeaner
PostPosted: 11:19 - 14 Nov 2010    Post subject: Re: SatNav doesn't work in London? Reply with quote
I don't know about that personally, how many places is the op intending to travel to?
Assuming he's just going to the same workplace every day its not that difficult to just follow a regular route.
The large scale section covers one way roads anyway so you have a rough indication of where you can and can't turn off.
I've never even considered using a sat nav in London as a master atlas allows you to see the place much more clearly and personally I feel a bit of an idiot following a sat nav's instructions, where's the skill in that!? Distracting too.
Personally I'd much rather rely on a decent map than an electronic device that isn't always accurate, requires battery charge and loses signal.
Apart from that they make you complacent and you don't memorise details with them.
Walloper
PostPosted: 11:27 - 14 Nov 2010    Post subject: Reply with quote
No problem with Satnav in towns.
I use mine in London loads of times.
It will get you there but sometimes the Satnav routing is suspect.
Swifte
PostPosted: 13:22 - 14 Nov 2010    Post subject: Reply with quote
Yea I'm one of those people whose lived in London for over a decade, but due to using the tube so much still can't connect the dots.
I've specifically transferred to a bike to finally learn the roads of London.
I've just been using a TomTom in london with a car, and it was absolutely fine, I take it the TomTom rider will respond the same.
I have the london rider pocket map.
Although it needs updating as some of the parking spots have moved, a bigger map would be much better.
If I was to get a sat nav the only option would be to get it on one of these smart phones anyone have any experience of how these would work in London?
I reckon a TomTom could make me lazy, so perhaps the way to do it is to have a large london map, and a smart phone app with blue tooth just as support. Then I'd actually learn london I reckon.
multijoy
PostPosted: 14:03 - 14 Nov 2010    Post subject: Reply with quote
I've no problem getting gps to work on my blackberry in the middle of town, and the only real difference (actual mapping aside) between a standalone unit and a smartphone is the GPS receiver. These days, there is bugger all in it- I've never struggled in lahndahn to get a lock, although my garmin 550 (or possibly earlier) takes a bit of time getting going if you've parked up underground for the day.
The obvious caveat is that whilst a garmin/tomtom bike unit and a sim-free smartphone (contract costs aside) might cost the same, the former tend to have fairly robust mounting solutions out of the box.
Paivi
PostPosted: 17:45 - 20 Nov 2010    Post subject: Reply with quote
Please don't rely on satnav to get around in London. There are too many people who do that and have no idea where they are or who's around them, they're too busy staring at the little screen.
The best way to find a good route it to ask a cabbie. I've now got three alternative routes to get home. Thumbs Up
PostPosted: 17:52 - 20 Nov 2010    Post subject: Reply with quote
Probably better than people trying to do the same with maps, however Smile.
Cheeseybeaner
PostPosted: 09:45 - 21 Nov 2010    Post subject: Reply with quote
In six years couriering I've never once considered using a sat nav around London, you're far better off using a large scale master atlas in my opinion and at least that way you will learn the place and gain street knowledge rather than simply be guided around by a computer.
A recent master atlas will tell you everything you need to know and you can at least view the whole picture with one as regards road options, possible diversions etc.
If you're only commuting to the same location each day I wouldn't have thought there was any need whatsoever to rely on sat nav as surely your route will be very similar each day.
Seeing how sat nav guided drivers drive I'd say they were more of a hazard than an aid to road safety.
If you need to stop and check the map that's easily enough done but you'll memorise the details and street names/turnings pretty soon you won't need to check it.
hellkat
PostPosted: 20:32 - 23 Nov 2010    Post subject: Reply with quote
I guess I'm just used to it, but I would think if you were following a satnav, you might as well be one of the people coming up from underground on the tube for 20 years and never really having a clue where anything is.
You'll never learn how to get about in London until you get PROPER lost and have to find your way out Laughing
I [still] do it all the time.
I simply cannot find my way out of the City of London.
So I skirt the edges (Puddle Dock, Holborn, Lower Thames St, Old St, etc) and avoid the middle for fear of getting lost and never getting back out again.
I've got a Satnav for my car, never used it yet, and I just wing it on the bike.
Still got a big A-Z, and rely on that, on random checks on Google prior to departure, and on luck/bad judgment/a trail of breadcrumbs...
hellkat
West End Girl
Mr Hammers
PostPosted: 11:25 - 25 Nov 2010    Post subject: Reply with quote
I used to courier (in a car) into London, using the A-Z at first until the boss bought us all sat-navs, which were the next big thing at the time. It was so much easier with the sat-navs, especially as I don't have a good sense of direction, and while sometimes it would lose the signal, I'd just pull up and wait till it picked up a satellite and carry on. Using maps was a pain as I can only ever remember a handful of directions at a time, and then I'd get paranoid I was going in the wrong direction or had missed a turn, so I'd be stopping every 10 minutes to double check.
It's true they can make you a bit lazy, but I never really had any interest in learning London anyway, but even so, eventually I'd learn roughly where things were after doing the same in/out roads again and again.
If you fancy the mental challenge to keep you on your toes, use a map. If you just want to get where you're going easily, without too much thinking and enjoying the scenery, get a sat-nav. Thumbs Up
A Guide To Powerbands
The last post was made 15 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 114.37 Kb
