| kramdra |
 kramdra World Chat Champion
| N cee thirty |
 N cee thirty Banned
| stonesie |
 stonesie World Chat Champion
 Posted: 20:46 - 06 Nov 2010 Post subject: |
It looks like the end of the neutral switch to me, how the hell did that get in there
If I remember rightly, the bolts you need for the centrifugal filter are M6 and you need countersunk heads.
https://img97.imageshack.us/img97/974/dscf0118f.jpg |
| kramdra |
| kramdra |
 Posted: 22:18 - 06 Nov 2010 Post subject: |
| rob yarrr wrote: | havnt a clue what that is,maybe something a previous owner bunged in ?
also how hard is it to get the the centrifugal filteR ? what do you have to do to get in to it ?
thanks |
hmm
first give bike a good run to get oil warm, drain it and clean the mesh filter.
exhaust off
foot pegs off
kickstart off
undo clutch cable
*Clean* the engine cover, oily rag will pick up most dirt.
12 bolts on cover. Need very small 8mm, 1/4" drive socket for one of them, theres no space for anything else.
Then put in gear, hold brake, and undo these screws. Clean with cloth, new gasket, put back..
I went through the gears a few times with the cover off, and it seems not to go up into 3rd. the mechanism is strange but I guess it works when engine is running. |
| N cee thirty |
 N cee thirty Banned
| kramdra |
 Posted: 21:59 - 08 Nov 2010 Post subject: |
well my phone got stolen last night, pick-pocketed...
anyway that means I dont have pictures, but the filter was clogged, 2-3mm layer of shiny oil sludge, with tiny bits of metal in it round the edge... Since the bolts were untouched I dont think its been cleaned before..!
It seems much better now, gear changes smoother, and it can now actually go into neutral while running! this caught me out a couple of times at junctions today!
At 70-72mph (very long hill!) the engine starts getting very very loud, rev limiter?
Idk if its vibration or something else, but Im going to be careful not to rev it that much.
It lost two foot peg bolts, and 1 exhaust nut, and some others were lose, there are some more lose bolts I can hear but cant see! |
| N cee thirty |
 N cee thirty Banned
| kramdra |
 Posted: 00:28 - 09 Nov 2010 Post subject: |
| rob yarrr wrote: | lmao pretty epic that you got it up to 72,no wonder bolts were falling off
could i just go through that centrifugal filter again
empty oil,take off exhaust, footpegs,undo clutch cable(what happens to the thing the cables connected to?)
then take off the clutch cover and the centrifugal filter should just be there with like 4/6 bolts you undo ?
cheers |
yes thats mosty it, but the important points are
make sure everything is clean, engine/cover, surrounding frame, your garage... whole side of engine is exposed, unlike a normal filter..
Get some spare screws. they are very tight, and being cross head, 9/10 will round off.
clutch cover, and filter gasket. The old one will not be in one piece afterwards. Wemoto has set for £15.. I made cardboard copies for next time :p
let the *cleaned* clutch cable dangle over the open engine, it wont go anywhere, it slides out easily from the engine cover.
Also cleaning the filter, the inner cone part, theres a lot of hidden dirt in there hidden down the side of the bolt. |
| N cee thirty |
 N cee thirty Banned
| kramdra |
| kramdra |
| N cee thirty |
 N cee thirty Banned
| Mark65 |
 Mark65 World Chat Champion
| kramdra |
| stonesie |
The last post was made 15 years, 72 days ago. Instead of replying here, would creating a new thread be more useful? |
