Plastic welding - Update!!! pics added
cb1rocket
PostPosted: 23:21 - 15 Nov 2010    Post subject: Plastic welding - Update!!! pics added Reply with quote
Hello all
so plastic welding.............basically what am I doing wrong?
I have welded a car bumper bracket once using a soldering iron but without using any filler or the like as it was quite a thick so there was enough plastic to mould into the break.
Any how I thought i would just post up some pictures of the panels that i'm trying to repair with tiny success. One of the panel tabs has totally broken off so i attempted to weld it back on.
See pic
Its not great as again I have use no filler or the like. I did try to use some cut up plastic from a gravy lid or a milk bottle lid but it just didn't stick, am I using something that isn't a suitable plastic to use as filler? Or is my welding technique totall wrong?
I'm using a 100 watt soldering gun and as such melting the plastic in direct contact with the iron tip. Wrong or what?
What should i be doing/using?
https://www.bikechatforums.com/download.php?id=75859
https://www.bikechatforums.com/download.php?id=75858
alun111
PostPosted: 23:26 - 15 Nov 2010    Post subject: Reply with quote
You need to use a similar (or identical) type of plastic as your "filler".
timR6
PostPosted: 23:28 - 15 Nov 2010    Post subject: Reply with quote
You need to use compatible plastics,
Assuming the part your trying to repair is ABS, then in an ideal world you would use a piece of ABS as the 'filler' - something like a cable/zip tie works well in my limited experience
Ichy
PostPosted: 23:56 - 15 Nov 2010    Post subject: Reply with quote
Plastic straws or, obviously, broken fairing parts work very well.
cb1rocket
PostPosted: 21:00 - 17 Nov 2010    Post subject: Reply with quote
thanks guys, will try my broken jigsaw cutter casing and see what happens.
Its plastic from 1979 for a GP100 so not even sure if ABS was around back then!
Robby
Dirty Old Man
PostPosted: 21:11 - 17 Nov 2010    Post subject: Reply with quote
I needed to reattached some plastic tabs a while ago, and found that a decent epoxy was better than amateur plastic welding. I used the strongest one that Maplin do, cost about 7 quid and it'll last ages. Designed for use with plastics, too.
The epoxy is stronger than the surrounding plastics, and I smeared a fair bit over the surrounding panel to spread the load a bit.
Teflon-Mike
tl;dr
PostPosted: 22:37 - 17 Nov 2010    Post subject: Reply with quote
Looks like you have got the joint deep enough, but when you add the filler, yes it has to be a similar plastic, but also you need to broaden the 'pool' of molten plastic melting old into new to get a more homogeniouse mix over a wider area, other wise you just get a crack full of new plastic.
reminds me: must get that How to written up!
bacon
PostPosted: 23:54 - 17 Nov 2010    Post subject: Reply with quote
do it, my winter ahead will consist of fairing repairs and ill be needing some tips, ill contribute with my success or failure by photos as well Thumbs Up
cb1rocket
PostPosted: 23:56 - 17 Nov 2010    Post subject: Reply with quote
thanks mike!
Yeah its a first go at doing something fragile unlike the car bumper bracket i did 3/4 years ago.
Will try my broken jigsaw casing as filler at some point (haven't got round to it). Pretty sure its ABS as most things like casing and covers are the norm these days.
Will write up when I get something done about it.
BumpingUglys
PostPosted: 01:26 - 18 Nov 2010    Post subject: Reply with quote
Wikipedia wrote:
The list of applications for ABS is long and continuously growing. Its light weight and ability to be injection molded and extruded make it useful in manufacturing products such as drain-waste-vent (DWV) pipe systems, musical instruments (recorders and plastic clarinets), golf club heads (due to its good shock absorbance), automotive trim components, enclosures for electrical and electronic assemblies, protective headgear, whitewater canoes, buffer edging for furniture and joinery panels, luggage and protective carrying cases, small kitchen appliances, and toys, including Lego bricks.
There ya go. Raid Toys R US and you've got an infinite supply of ABS in any primary colour you care to mention.
If you're really good you could leave a few studs stuck out and mount lasers n' shit under your indicators. Wink
cb1rocket
PostPosted: 00:23 - 21 Nov 2010    Post subject: Reply with quote
Hi all
After breaking my jigsaw cutter casing into bits, i got this far.
The pictures shows the extent of the repair so far.
So far its loooking pretty good and i must say the jigsaw casing is a good plastic (possibly ABS type) as a filler. Got it hot it enough that I managed to molten the plastic into a jam like spread.
Its feels much stronger as i tried to seperate it with some force without breaking it.
Cheers for all help guys
https://www.bikechatforums.com/download.php?id=75910
https://www.bikechatforums.com/download.php?id=75909
https://www.bikechatforums.com/download.php?id=75908
DrDonnyBrago
PostPosted: 10:29 - 22 Nov 2010    Post subject: Reply with quote
If you run out of jugsaw casing, me and bacon used plastic coat hangers yesterday and it seemed to work well Thumbs Up .
Frost
PostPosted: 10:34 - 22 Nov 2010    Post subject: Reply with quote
I used plastic welding on a bit of a bike before... it cracked open again as it was on a bit that flexed slightly when you sat on the bike. Fiberglass done in lots of thin layers using that tissue stuff rather than the weave is absolutely spot on i think. You can use if on the visible parts to as it fills very fine holes and can be sanded down. bloody strong stuff too if done right.
Lynxx
PostPosted: 13:36 - 22 Nov 2010    Post subject: plastic weld Reply with quote
when ever you weld plastic make sure u use the same plastic type or it will hold for no time at all. also make sure u bond and fill the plastic together. also when ever you weld plastic it will hold, but makes the plastic brittle due to the heat. somtimes its better to just use some epoxy and fiberglass material. or fiberglass but fiberglass is heavy.
Also to add, if you can get some stainless mesh, weave that into the plastic as it improves strengh. i used stainless bug screen off a screen door.
loply
PostPosted: 22:38 - 22 Nov 2010    Post subject: Reply with quote
I found one of the best techniques for adding strength to plastic welds is to embed wire in the joint.
I would take a series of 15mm long bits of strandy-core electrical wire and fray both edges and lay them across the crack like stitches.
Then I would use a big soldering gun to melt the wire down into the plastic, then melt more plastic on top, till the wire disappears from view.
This seems to help massively with strength Thumbs Up
Yamaha SZR660 Caution to the wind, the throttle pinned!
kramdra
PostPosted: 02:27 - 23 Nov 2010    Post subject: Reply with quote
ack!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
STOP. This ^ is a nasty joint, it will crack. If it was a metal weld, that is what would be called pigeon shit :p
The joint broke for a reson. You need to make it thicker to reinforce it. And your reinfocement should flex to absorb any forces.
Epoxy would not allow any flex, might crack again. Also messy :O
Hot glue. Heat it with a lighter, smear in circles into and around the joint. This gives it strength, quickest, easiest....
After - heat up one end of a trimming blade and use that to spread the joint smooth... looks much better after.
Plastic welding is better done with the correct solvent, or atleast a temperature controlled soldering iron set at ~230...
PostPosted: 10:26 - 23 Nov 2010    Post subject: Reply with quote
Fuck off! Lego is the only plastic in the world more expensive than fairing panels Laughing
BumpingUglys
PostPosted: 20:56 - 23 Nov 2010    Post subject: Reply with quote
Lol. Fair point, eloquently put. But think about it....laser guns under your indicators.... Wink
gonzo
PostPosted: 21:05 - 23 Nov 2010    Post subject: Reply with quote
ok can i just say this am new here but will give you some help on this get some old ABS fairing and get a drill and drill into the plastic and the small bits you get of the drill bit put in a cup with some 99.9% ACETONE (ch3.co.ch3) and put a bit of the acetone in to the cup and it will melt,mix it up and put some on the crack if you can put some holes in the bit thats broken so the stuff melts into the holes aswell for strenth, let it dry over ngt ,and trust me you will be happy the ngt day Cool
the gonz Smile
0ddball
PostPosted: 22:11 - 23 Nov 2010    Post subject: Reply with quote
ABS plumbers cement can be useful too. Basically a ready mixed acetone/abs shaving paste.
cb1rocket
PostPosted: 23:35 - 23 Nov 2010    Post subject: Reply with quote
you mean this?
https://cgi.ebay.co.uk/P16-PVC-ABS-NON-PRESSURE-SOLVENT-BASED-PIPE-CEMENT-/300346861216?pt=UK_DIY_Materials_Plumbing_MJ&hash=item45ee1166a0
stigger
PostPosted: 01:03 - 24 Nov 2010    Post subject: Reply with quote
OK So I've a question... I've bust the corner off my screen, I don't care whether it see though or not I'll probably paint it anyway...
I've tried super glue and epoxy neither of them worked can this be "welded"? If so what sort of filler do you think will work???
gonzo
PostPosted: 01:31 - 24 Nov 2010    Post subject: Reply with quote
use just as if it was a bike fairing b/filler on the inside and like paint it matt black thay look cool like that
the gonz Smile
Noxious89123
PostPosted: 00:50 - 25 Nov 2010    Post subject: Reply with quote
Not sure what screens are made of? ABS or some might be polycarbonate?
ABS plastic melts in acetone (nailvarnish remover) iirc, and can be used as a sort of cement. Just a thought, be don't ask me for more details as I don't have any Embarassed Might be worth having a google for it though.
EDIT:
Nvm, had a look and found this. https://forums.clubrsx.com/showthread.php?t=558435
If you could get some clear ABS plastic you could use that to make some "ABS goop". But this is all depending on the screen being made from ABS and not Poly carbonate or something else.
DrDonnyBrago
PostPosted: 09:56 - 25 Nov 2010    Post subject: Reply with quote
I would be surprised if a screen was made of ABS. There should be a recycling mark on the screen somewhere, find it and look it up online to see what it means.
The last post was made 15 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 131.35 Kb
