Keeping a bike on charge......
noddy
PostPosted: 22:51 - 15 Nov 2010    Post subject: Keeping a bike on charge...... Reply with quote
Bought a cheap battery charger from Aldis a couple of weeks ago.
Dont use the bike over the weekend usually. Bike is garaged, close to a 230v socket.
Would like to connect the charger to the bike over the weekend. But need to pull out the carpet lining and unscrew 4 screws to connect the terminals to the battery and keep the seat up. It's abit of a potch Shocked
My question to you knowledgable lot is ;
Can i connect the charger to the scoot using my underseat cigarette lighter socket Question
What i plan to do is buy a male cigarette adaptor, and connect the other end to the crocodile clips of the charger Idea
Thanks Mark
Current ride: Honda Pantheon FES 125 2003.
Previous bikes: Suzuki TS50x, Honda MTX125, Suzuki AP50, Gilera Runner 180sp.
jimspeed
PostPosted: 23:14 - 15 Nov 2010    Post subject: Reply with quote
I suppose that depends on if the ciggy socket is live with the key removed or just with the engine running really. if its permantly live I dont see a problem with doing that as long as there is a fuse somewhere and the battery charger is int automatic type Thumbs Up
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
map
Mr Calendar
PostPosted: 00:20 - 16 Nov 2010    Post subject: Reply with quote
Why can't you just have another flying lead off the battery terminals with a connector to plug into the charger (may have to adapt the charger).
This is an option you get with the Accumate/Optimate chargers. Lead from the charger has connector where you can plug inthe croc clips or the plug (socket?) from the flying lead. Means you don't have to take the battery out, useful in bikes like BMWs.
binge
Emo Kiddy
PostPosted: 00:58 - 16 Nov 2010    Post subject: Reply with quote
No reason why not.
My Dad's Goldwing had an Optimate quick-access lead on the battery.
He also had a Ciggy lighter socket with an Optimate attachment on the other end. So when he was out on a ride etc, he plugged the Ciggy socket into the Optimate lead giving him access to a 12v plug.
When he wanted to charge it, he would unplug the ciggy socket, and plug the optimate into the quick-access lead.
So no reason at all why you cant charge through a ciggy socket. Just make sure there's no diodes or resistors in the male plug.
Ben
iooi
PostPosted: 08:46 - 16 Nov 2010    Post subject: Reply with quote
Should not need to charge the battery up that often. If you are then you need to look at why.
The type of charger you have is to charge a battery up.... Not leave it connected to all the time.
Good way to end up with a fcuked battery or even worse a fire......
map
Mr Calendar
PostPosted: 11:16 - 16 Nov 2010    Post subject: Re: Keeping a bike on charge...... Reply with quote
noddy wrote:
Bought a cheap battery charger from Aldis a couple of weeks ago....
iooi wrote:
...The type of charger you have is to charge a battery up.... Not leave it connected to all the time...
@iooi. If it's the Aldi charger then it is ok to leave plugged in.
It says so in the instructions, plus the specs have it as trickle charge.
Aldi wrote:
* Suitable for all 6 and 12V car and motorbike batteries
* Cut-off function once battery reaches peak voltage
* Trickle charge function
* Charging cable: length approx. 1.91m
* Power cord: length approx. 1.90m
https://www.aldi.co.uk/uk/media/offers/01_10_week_40/Product_detail_Wk40T10.jpg
click on image for link (link may expire)
The only thing with this one is the hardwired croc connectors. Would need to be replaced with suitable connector(s) if want to fit a flying lead permanently connected to the bike battery.
Also remember to only use on the motorcycle setting or indeed you may have a fcuked battery or worse (that's why I like dedicated Accumate/Optimate for the bikes). I have this Aldi charger as a reserve plus can use it on the car batteries.
HTH Thumbs Up
noddy
PostPosted: 18:52 - 16 Nov 2010    Post subject: Reply with quote
Thanks people. And to MAP, thats the one. Ill make up a fly lead of the battery, and the one for the croc clips Thumbs Up
The last post was made 15 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 60.74 Kb
