Like even more maths? (WRONG ANSWER REVEALED!)
PostPosted: 23:24 - 15 Nov 2010    Post subject: Like even more maths? (WRONG ANSWER REVEALED!) Reply with quote
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF3127.jpg
Once again, put your answer in small text so you don't give it away, and show your working if you can.
HP
PostPosted: 00:12 - 16 Nov 2010    Post subject: Reply with quote
4.26
What flavour would you like the windows Harvey?
PostPosted: 00:21 - 16 Nov 2010    Post subject: Reply with quote
HP wrote:
4.26
No.
trevoriv
PostPosted: 00:35 - 16 Nov 2010    Post subject: Reply with quote
Eighty-twelve?
Blue_SV650S
R=1.7 ... therefore diameter = 3.4
PostPosted: 00:40 - 16 Nov 2010    Post subject: Reply with quote
No Laughing
PostPosted: 00:45 - 16 Nov 2010    Post subject: Reply with quote
A clue is you need to use the Quadratic equation Thumbs Up
Blue_SV650S
ms51ves3 wrote:
No Laughing
I'm afraid it is (better go back and check my calculations mind, it is late Embarassed) ... BTW 1.7 is rounded as not using Pi to the zillionth decimal place! Very Happy
EDIT:- doh ... there was a mistake (for some reason I had written down the area given in the text as 216, not 200! ... odd Confused) ... the actual answer is:-
R = 3.14 (Pi) , so dia = 6.28 (2.Pi)!
PostPosted: 02:14 - 16 Nov 2010    Post subject: Reply with quote
Area of floor without cutaways = 12(18+r) = 216 + 12r
Area of central cutaway = πR² = π(2r)² = 4πr²
Area of corner cutaway = 0.5πr²
So cutaways = 4πr² + 0.5πr² = 4.5πr²
Floor area = 200 = 216 + 12r -4.5πr²
-16 = 12r -4.5πr²
-4.5πr² + 12r +16 = 0
Oh how much FUN. You've contrived to make me do a quadratic fucking equation. I last did one of these 17 years ago and I hated them then!
Using the quadratic solving equation: x = -b +or- √(b² - 4ac)/2a
r = -12 - √(144 - (-288π))/-9π
r = -12 - √(144 +288π)/-9π
r = -12 - √1048.779/-28.274
r = (-12 - 32.384)/-28.274
r = -44.384 / -28.274
r = 1.570
Check working:
216 + 12r -4.5πr² = 216 + 18.840 - 34.847 = 199.993
Close enough for government work!
I hate you!
PostPosted: 08:00 - 16 Nov 2010    Post subject: Reply with quote
I've not seen the correct answer yet. Keep trying kids Laughing
PostPosted: 09:34 - 16 Nov 2010    Post subject: Reply with quote
OK. Didn't read the question properly. Drop 1 mark.
Diameter of the central circle = 2R = 2(2r) = 4r
As r = 1.570. Diameter of central circle = 6.28 metres
PostPosted: 10:11 - 16 Nov 2010    Post subject: Reply with quote
Total area is 216 including the cutouts.
So
16 = pie * (2 * r)² + 0.5(pie * r²)
32 = 2 * pie * (2 * r)² + (pie * r²)
32/pie = 8 * r² + r²
32/pie = 9 * r²
32 / (9 * pie) = r²
r² = 1.1318
r = 1.064
R = 2.1277
Diameter of central circle is 4.2554
Charlie
PostPosted: 10:49 - 16 Nov 2010    Post subject: Reply with quote
Here's how I did it, however I suspect it will be somewhat similar to others.
https://cdn.bikechatforums.com/files/chivesmaths_398.png
PostPosted: 10:53 - 16 Nov 2010    Post subject: Reply with quote
Keith.
Your first proposition is incorrect. The overall length of the room is not 18.0m.
Charlie
PostPosted: 10:55 - 16 Nov 2010    Post subject: Reply with quote
I made the same mistake as Keith when I first did it, only checking the diagram after did I realise. Mad
PostPosted: 18:25 - 16 Nov 2010    Post subject: Reply with quote
Does anyone want me to post up my working and answer yet?
Blue_SV650S
PostPosted: 19:10 - 16 Nov 2010    Post subject: Reply with quote
Can do, but we already know the answer is 6.28 (2.Pi)! Very Happy
PostPosted: 19:11 - 16 Nov 2010    Post subject: Reply with quote
I don't need to see it because I'm happy I got the correct answer, but do it small like everyone else in case someone else wants to dip a toe in the thrilling world of algebra. Be interesting to see how you did the working.
And I'll tell you now. If you put up any more, I absolutely draw the line at calculus.
I am totally happy with the knowledge that while calculus is necessary, other people know how to do it.
PostPosted: 19:29 - 16 Nov 2010    Post subject: Reply with quote
Stink, your answer wasn't correct. No ones has been correct so far.
PostPosted: 19:33 - 16 Nov 2010    Post subject: Reply with quote
Well you'd better post your answer because as far as I can tell, it is.
The Original Muzza
PostPosted: 19:58 - 16 Nov 2010    Post subject: Reply with quote
I got the same as Blue (3.14 radius for R).
PostPosted: 20:05 - 16 Nov 2010    Post subject: Reply with quote
I'm typing it up now, bear with me.
PostPosted: 20:19 - 16 Nov 2010    Post subject: Reply with quote
Shitstorm incoming in 5, 4, 3, 2...
HP
PostPosted: 20:23 - 16 Nov 2010    Post subject: Reply with quote
dont post thr answer im going to retry it as i read the diagram wrong last time
PostPosted: 20:44 - 16 Nov 2010    Post subject: Reply with quote
Click me for the answer.
The last post was made 15 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 129.46 Kb
