Bike broken down again after repair by garage
Chris750
PostPosted: 12:14 - 18 Nov 2010    Post subject: Bike broken down again after repair by garage Reply with quote
My partners aerox 100, broke down a few weeks ago.
The garage said that it was due to the oil not getting through to the engine seizing the piston.
We had to pay £400 to get it put right and my partner only picked the bike up yesterday.
When she got home she decided to top up with oil, she came and got me as she was worried it didn't have any oil in it when it left the garage as she had only rode a couple of miles and it now seemed really empty. i.e. took the whole bottle to top up.
This morning she has driven to work and its seized again so I guess they didn't put any in and the journey from the garage to home was enough to do the damage.
Now I know the garage may try and get out of this but I'm dammed if I'm paying out another £400, we just don't have it this month now, especially after paying £400 yesterday for it.
We could of just bought a new bike at this rate.
If they did forget oil, would it of run for a bit with no oil and then break down even after we had topped it up?
Could they have put oil in, but not fastended something meaning the oil has leaked out?
What are you opinions? How should I play this. They may try and say its something else.
I'm really cross, she is stranded at the side of the rode again.
map
Mr Calendar
PostPosted: 12:25 - 18 Nov 2010    Post subject: Reply with quote
You will have to contact the garage and see what they say.
Any consumer advice grievance would recommend this.
You can try phoning first.
However, you will need to put it in writing and send it recorded or guaranteed delivery (to make sure it got there).
Any repair should have a guarantee period, one day just doesn't cut it. Problems come when garages say it's not the bit they repaired but some other bit that broke.
However, in this case it does sound a bit like negligence. Remember it may not have been the ride home that caused the damage but their test ride - they did test ride it before giving it back didn't they Confused Wink
Not that you can do anything about it now but £400 does seem OTT for a seized rebuild. Do you have an itemised bill? FWIW when the Vespa elastic band broke that fed oil into the mix and seized the piston it was just under £200 for the lot.
Hoe you get it sorted Thumbs Up
PostPosted: 12:26 - 18 Nov 2010    Post subject: Reply with quote
Which oil? gearbox or 2t? (is it a 2 stroke?) If either was empty I imagine it would have gone bang straight away. Did your partner run the bike in properly? Are you sure you didn't overfill the oil?
map
Mr Calendar
PostPosted: 12:30 - 18 Nov 2010    Post subject: Reply with quote
chris-red wrote:
... Are you sure you didn't overfill the oil?
Confused
If it's a separate 2-stroke oil tank then it's fed by pump into the mix. If you overfill it it comes out the top of the tank.
An Aerox 100 is a scooter. That means variable transmission. Hardly any need for gearbox oil is there?
Why do you post such rubbish and complicate matters?
Did you even read the original post or just imagined what it might say?
PostPosted: 12:35 - 18 Nov 2010    Post subject: Reply with quote
map wrote:
Confused
Whoa Calm down dear.
I only experience with 2t's is my RXS which had gearbox oil, I knew the Aerox was a scooter I didn't know weather it was a 4t or 2t overfilling a 4t engine with oil could cause lots of damage I didn't know it wouldn't have gearbox oil that was what I was referring to being overfilled.
Being fair 2t oil is a Consumable you wouldn't blame a garage if you run out of petrol on the way home.
Did your partner run it in properly?
Chris750
PostPosted: 12:36 - 18 Nov 2010    Post subject: Reply with quote
Two stroke oil.
I didn't think about the test ride, good point there.
I know £400 is alot but we had little choice, it my partners only way to get to work and they are the only local garage. Getting it transported elsewhere + extra time would of meant more days off work which would of also cost money/caused hassle with her job.
The garage in question are picking the bike up shortly. I would of liked to have had a look at it myself before they got hold of it but my partner is stuck at the side of the road (she has no breakdown cover even though I've gone on about it to her) and they are only a couple of miles away so again we have little choice.
Hopefully if its there fault which I imagine it is, then hopefully they are good enough to sort it out without trying to do us over.
Chris750
PostPosted: 12:39 - 18 Nov 2010    Post subject: Reply with quote
I know two stroke is a consumable, but its a couple of miles from the garage to our house. You thought after paying £400 they may of they enough oil in it so it doesn't seize straight away. We topped it up as soon as she got back.
And as to running it in, she has only done about 6 miles on it.
PostPosted: 12:48 - 18 Nov 2010    Post subject: Reply with quote
Don't tell them that you did anything to it. A "You didn't put any oil in it / yes we did / no you didn't" debate will just be a distraction.
All that matters is that it's got the right amount of oil in it now (middle of dipstick or middle of sight with the bike level, right?) and that it's seized again.
I know it's a piss-boiler, but try to stay calm. Mistakes happen, but it's up to the garage to sort it out. Give them a chance to do so, at no more cost to you.
If they give you grief or try to charge you one penny more, ask whether they want to recover it at their cost and do the job you've already paid for, or whether you should have it recovered and fixed elsewhere and then recover the full cost from them in small claims court.
If they don't see the sense in doing it themselves, then make sure you speak to the owner or manager rather than a peon - it really is smarter for them to fix it at cost rather than to pay full retail to a rival.
If you paid by credit card, even better - you should be able to recover your costs directly.
Make sure you write everything down - who you speak to, what they said, and when.
Best of luck.
UPDATE: just read your posts above.
Make it clear that you aren't authorising them to do any more paid work on it: it's at their cost.
Also, I'm really sorry to hear you're having this problem. For £400 you should have got a bike that damn well flies.
Chris750
PostPosted: 12:55 - 18 Nov 2010    Post subject: Reply with quote
Thanks for replies, hopefully they will sort it out, but at the back of my mind I'm just worried that, if they have fucked up they will try cover there arses and say its something differant that isn't there fault and its just a coincedence that it happended after thye had fixed it. I know the fact they had it in bits very very recently does hold a bit of weight though.
It's a 2 stroke, so there won't be a dipstick and you just fill it up.
I'd be in two minds about telling them it didn't have any 2 stroke in. Possible it may make things worse, but if they're decent folk, they may fess-up, of course.
Chris750
PostPosted: 13:08 - 18 Nov 2010    Post subject: Reply with quote
They have it now, so I'll give an update when they let me know what they are going to do.
truslack
PostPosted: 13:13 - 18 Nov 2010    Post subject: Reply with quote
As long as it hasn't scored the barrel, you could rebuild it yourself for under £50, and an spend an evening doing it instead of watching soaps - I know I'd choose that over £400 any day!
Chris750
PostPosted: 13:21 - 18 Nov 2010    Post subject: Reply with quote
If it happens again and its our fault I'm thinking maybe I will.
But I have been on at her to sell her aerox and get a CG and she is coming around to the idea now, just a bit worried about gear changes, but I've said I will show her in a car park and she will soon get used to it.
map
Mr Calendar
PostPosted: 13:28 - 18 Nov 2010    Post subject: Reply with quote
Chris750 wrote:
... just a bit worried about gear changes, but I've said I will show her in a car park and she will soon get used to it.
FWIW I posted for some advice on this subject not long ago - click for thread here. She got it in the end after a little bit of advice to keep the revs higher than she had been and then adjust when bite point reached and bike moving.
Chris750
PostPosted: 20:17 - 18 Nov 2010    Post subject: Reply with quote
Garage have said earlier that bike wasn't seized, it was just a problem with the spark plug cap (which we had been charged to replace incidentally).
My partner took the bike to work again.
She has just left work and its brocken down again.
The garage is now shut, she has had to leave it in someones garden and luckily they have given her a lift home.
But now she can't get into work again tomorrow
Moo.
PostPosted: 20:35 - 18 Nov 2010    Post subject: Reply with quote
That really is taking the biscuit..
Can you see any visible oil leakage around the engine?
Is the spark plug shorting on the engine casing?
Cant see how the spark cap could cause much problem.. doesnt do alot, sometimes if its too close to the engine casing, the spark jumps the gap and cuts the engine. Is the battery charged up alright?
A2 Passed 18/6/10
The Artist
PostPosted: 20:44 - 18 Nov 2010    Post subject: Reply with quote
Seizing means the engine is stuck. It won't turn over. Is this what you mean by seized?
All sounds dodgy to me. I suggest you try a different or reputable garage or someone off here near you could give you a hand rather than going to the same place again.
Chris750
PostPosted: 20:48 - 18 Nov 2010    Post subject: Reply with quote
I know what siezing means, I just assumed it seized as I wasn't there to have a look and I was worried anyway as they gave it us with no oil in it.
Chris750
PostPosted: 20:50 - 18 Nov 2010    Post subject: Reply with quote
again I haven't seen it, it has been left in someones garden for the night.
The Artist
Like I said, sounds like a dodgy garage.
TBH this could be as simple as a vacuum in the fuel tank.
PostPosted: 21:59 - 18 Nov 2010    Post subject: Reply with quote
At this point, I think it's pretty clear that they're incompetent, or liars, or both. Thumbs Down
What did you get for your £400? Piston rings? New piston? New barrel? Did they give you the old parts back (showing damage)? If not, ask for them now, plus evidence that they actually purchased new parts, plus a detailed list of all the work that they carried out. Not just "labour", a list of what they actually did (or claim to have done).
If they don't provide all of the above, I'd suggest that you ask for your money back and start looking into initiating a county court small claim to recover your money. Either way, I think you've given them more than enough of it already.
PostPosted: 23:58 - 18 Nov 2010    Post subject: Reply with quote
Whilst it seems like overkill...do this.
Im pretty sure £400 is a stupid amount to charge, a second hand engine is alot less. Ive bought whole bikes for <£400 with tax and test.
Definitely go in there and demand a total breakdown as Rogerborg has stated. Broken down once, spark plug cap fair enough, but twice! Stick a foot up their arse, demand spark plug cap price back..obviously! You want your old one back on there as it probably wasnt that.
Ask for your parts back, if they dont have them, which is likely then just ask for a total list of parts, time and if you can their order form with the parts.
Sound like tossers, if you need to name and shame.. go for it, BCF has a habit of raping the google spiders Wink Mr. Green
Chris750
PostPosted: 09:54 - 19 Nov 2010    Post subject: Reply with quote
Thyis is a break down of costs on the receipt:
remove engine & part listed below 175
crank rebuild 20
collection from hailey 18
mot 29.65
materials
piston kit 21
con rod kit 34.20
main bearings 15.75
crank seals 9.9
gaskets 10.90
spark plug & cap 7.43
sundries 3
We have phoned them this morning and they are going to give my partner a lift to work and collect the bike. We haven't really got many options as they are only local garage and we at least have to give them a reasoanble chance to sort any issues.
map
Mr Calendar
PostPosted: 12:21 - 19 Nov 2010    Post subject: Reply with quote
Chris750 wrote:
Thyis is a break down of costs on the receipt:...
So total 344.83.
I'd like to know how many hours labour that 175 represents.
Using my rule of thumb of £40/hour it's about 4 and a half hours.
I'm trying to decide if that's just a tad on the high side by an hour or so (obviously if hourly rate @ £90/hour it's only 2 hours!).
I also see there's no oil (as in 2-stroke) specifically listed (unless that's counted under sundries).
Might be worth asking the direct questions "How much 2-stroke oil did you put in it? and did you charge me for it?"
As said before, hope it's sorted ok Thumbs Up
PostPosted: 13:06 - 19 Nov 2010    Post subject: Reply with quote
map wrote:
So total 344.83.
+ VAT = £404.
It's not completely unreasonable if they did actually do all that work, and the cost includes investigation. But the engine must have been shagged: piston and con rod and bearings? Ouch.
Having done all that though, there's not much left to go wrong. If it's something noddy like a loose wire, and they sort it out properly, then fair enough, but after an engine rebuild they really should have ensured that everything was put back on properly before handing the bike back.
The last post was made 15 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.99 - MySQL Queries: 16 - Page Size: 139.08 Kb
