So, how would you teach someone to ride a geared bike?
map
Mr Calendar
PostPosted: 13:51 - 27 Oct 2010    Post subject: So, how would you teach someone to ride a geared bike? Reply with quote
As per title.
I'll be trying to teach someone how to ride a 125 (it's the old '85 CG).
However. she's not ridden a geared bike before.
All other attempts either have her releasing the clutch too quickly without also appying revs and stalling. Once she did racing off down the road, scaring herself and then stalled (private road officer).
I've been trying to get her to balance the bike on the clutch biting point first. However, this is still difficult.
No point in moving to gears until the bike is at least able to move forward.
I'm racking my brains how I did it and coming up with nothing Rolling Eyes
So, any pointers and advice appreciated.
Thanks Thumbs Up
CptBlack
PostPosted: 13:56 - 27 Oct 2010    Post subject: Reply with quote
Put it on the centre stand (leaning forward!) to get used to the clutch biting point
PostPosted: 13:58 - 27 Oct 2010    Post subject: Reply with quote
Whilst teaching my daughter i got her to freewheel down a hill and asked to pull in the clutch as she braked. Same again in gear and a little throttle. A slight downhill helped with clutch control in the first half hour. After that i taught her where to look. i.e not too close. Then i showed her how to pick up a 250 Mr. Green
Pat
ThoughtContro...
PostPosted: 14:13 - 27 Oct 2010    Post subject: Reply with quote
Do what they did (or should have done) on your CBT.
You'll have to get her used to the biting point before you let her toddle off down any private road. If it was me I'd let her get used to JUST playing with the throttle at low revs, so she can get used to how much twist she needs to not stall and what the engine will sound like.
Then let her play with just the clutch (no revs), slowly releasing it till she can properly feel the biting point, notice the sound of the drop in revs and then pulling it back in. Once she's got used to where the BP is and is fairly confident of those, then get here used to synching the two together, till she can start off without a stall 8 out of 10 times. Let her go small distances, wheel the bike round and do it again till it becomes second nature.
Make sure the clutch is properly adjusted on the bike. My first CBT attempt was a nightmare as the clutch on the bike didnt bite until almost fully out. She'll get it in the end, all you need is patience, time and encouragement. Once the clutch/gears control is sorted the rest should be easy enough.
I do hope your private road is well away from any coppers. You dont wanna get royally rogered by a ten foot pole up the bum trying to help her out.
Prize cunt
DrDonnyBrago
PostPosted: 14:18 - 27 Oct 2010    Post subject: Reply with quote
get her to keep the throttle steady at a point where the revs are quite a bit higher than you would normally use to pull away, tell her the engine will sound loud as it is 3 feet away and there is no sound insulation, plus bikes like to be revved more than cars so don't worry about it.
To start, some slow stuff - get her to control her speed using the clutch rather than the throttle.
If she keeps that throttle position steady and slowly slips the clutch in then it is only one thing to think about, rather than trying to get the clutch and throttle right at the same time. The biggest issue I had was not revving it enough when pulling away, losing the revs as it engaged and stalling - not worrying about over revving it helped.
When she is moving, get her to pull the clutch before the brake, introduce leaving the clutch out during emergency stops at a later date.
Ultimately though it is just practice.
HTH Thumbs Up
CptBlack
PostPosted: 14:20 - 27 Oct 2010    Post subject: Reply with quote
Possibly turn the idle up really high so she doesn't have to think about throttle
Paxovasa
PostPosted: 14:25 - 27 Oct 2010    Post subject: Reply with quote
Trial an error.
Just be patient and give her plenty of encouragement Thumbs Up
Misc
PostPosted: 14:31 - 27 Oct 2010    Post subject: Reply with quote
Get them to ride the bike with the biting point only & no throttle just clutch. Not sure if a 125 would move quick enough to be able to ride it on the biting point but that should get them used to where the clutch engages (or is it disengages lol)
On the test i was taught to do the throttle + clutch at the same time, got there in the end but i reckon it'd of learned quicker if i spent more time on just the clutch.
map
Mr Calendar
PostPosted: 14:47 - 27 Oct 2010    Post subject: Reply with quote
ThoughtControl wrote:
...a nightmare as the clutch on the bike didnt bite until almost fully out....
I suspect this may be the case with the CG. No hassle if you're used to it.
I do suspect she'll get it in the end. Trouble is she gets really frustrated really quickly if she can't get the hang of anything straight away. I think that's something to do with her dyslexia (why do they make that so difficult so spell?).
Anyhow, going to give your ideas a go this pm and then again on Friday afternoon (bit more daylight).
Thanks.
Any other ideas still welcome Thumbs Up
The Artist
PostPosted: 14:50 - 27 Oct 2010    Post subject: Reply with quote
CHR15 wrote:
i just kept doing it until i got it right.
took me quite a while, and im sure allymoss got a good laugh out of it as well.
Laughing I remember that day on the rx. We all went to Single tracker and bought helmets and gloves, came back mine and went up and down that back lane thing. Good times.
truslack
PostPosted: 15:10 - 27 Oct 2010    Post subject: Reply with quote
Last time I taught someone to ride on the H100 I watched them wheelie or stall a few times, they eventually got bored of having to kickstart the bike and that pushed them to learn to set off properly Laughing
HD
PostPosted: 15:20 - 27 Oct 2010    Post subject: Reply with quote
As others have said learn the biting point first. I know bikes and cars that dont need any throttle whatsoever to pull away. Just let the clucth out reeeaaaallllyyyy slowly (10 seconds) until its all the way out. Hopefully it wont stall and will just roll at idling revs. Then if she gets that either apply the throttle after she aint using the clutch or apply the throttle from a standstill. At least she will be used to the biting point.
It might be an idea if you give it a go first as I said some bikes I know do it, not all!
G'luck
PostPosted: 19:19 - 27 Oct 2010    Post subject: Reply with quote
Combination of trial and error and get her to go through the movements off the bike. i.e Sitting on a bus or car, when the driver changes gear get her to run through the movements "throttle off, Clutch in, change gear, clutch out and throttle on."
That way the movements become second nature and its just a case of practicing on the bike
spetom
PostPosted: 19:54 - 27 Oct 2010    Post subject: Reply with quote
Teach him/her the first two golden rules of biking.
Or what in my opinion should be the first two golden basic beginner rules of biking, although the usage of number 1 changes as you get more experienced.
Exclamation Exclamation Exclamation
1) Always keep the clutch in when you are stationary!! If you don't know you're in gear always keep the clutch in!! When you're starting the bike always keep the clutch in. If you panic or lose control remember left hand clutch in!!
Then/or...
-Only release the clutch if you know you're not in gear, check to make sure you are in gear by rolling the bike back and forward.
-Only release the clutch slowly at the beginning, do not over Rev the engine. Even if you think you are in neutral
(The reasoning for this is the amount of inexperienced & experienced bikers who revving their bike forget they are in gear and release the clutch, and the bike goes airborne. This is usually a huge fuck up on bigger bikes. Quick clutch release has caused so so many bike take offs!)
https://www.youtube.com/watch?v=YgAkKrIimcc
2) Keep your hands and feet away from the sprocket! Never ever run the engine when you are doing mechanical maintenance on it despite what everyone says. Keep your hands and feet away from the sprocket and chain!
(The reasoning for this is obvious but to the novice)
nokiakeys
Token
PostPosted: 20:23 - 27 Oct 2010    Post subject: Reply with quote
Everyones given their thoughts, so I thought I'll add mine.
Get her to listen to the engine mainly.
Put the bike in 1st and keep clutch in.
While it's in, start to rev the engine at a steady pace, then slowly let go of the clutch while listening to the engine and feeling the bike ready to go I.E. the biting point Smile
That will tell her when she needs more power to move off. When she starts to move off a bit pull the clutch in and repeat previous steps a couple times until shes happy with the biting point.
Then bobs your uncle she can move a geared bike... hopefully Thumbs Up
Sam_Y_93
PostPosted: 20:39 - 27 Oct 2010    Post subject: Reply with quote
Its trial and error as others have said. Does she have a car? if not then she wont be used to the clutch control. I would tell her to sit with the bike in gear releasing it to the BP and bringing it back in, once she knows where it is then get her to apply a little throttle whilst finding the biting point.
You could also show her some videos on youtube or something, found this helped me when I taught my self https://www.youtube.com/watch?v=CdySkge4aKM
JP7
PostPosted: 20:42 - 27 Oct 2010    Post subject: Reply with quote
The piece of advice that stuck most in my mind was this: car drivers never want to ride or slip the clutch because they're told it's a bad thing. On a bike it works better if you do ride the clutch.
Once I'd grasped that concept, I was well away. Hope that helps.
PostPosted: 23:00 - 27 Oct 2010    Post subject: Reply with quote
I taught my girlfriend the basics on my H100 on the local airfield.
Got her to use the back brake first. Pushing her along and coming to a halt using it. This give confidence in the initial stages while riding slowly. If it all goes wrong or you feel out of control, stop using the back brake, worry about the rest later.
Once she was happy with that, I got her to play with the throttle and clutch while holding the back brake on so she could feel the bike pulling against it.
Once she had the feel of that, I got her to slowly let the back brake off as she felt it pulling, ride forwards a few feet, close the throttle, stop it again using the back brake and repeat. Pretty much had her balancing the clutch, throttle and back brake within the first 5 minutes (she's a smart lass)
Sounds a bit arse backwards but this is putting the groundwork down for the slow riding you need to do your test manouvers. I also know so many people whose first bike riding experience was wheelying an H100 into a chainlink fence on their CBT. To me it's logical to teach someone how to stop before you teach them how to go.
Then we did ride off, change into second, stop, change into first, ride away, change into second, stop....
Once she was confident she could stop under control and change gear, I got her to build up the speed a bit and start using both brakes to stop in the same way as before.
She pretty much did the rest on her own having got the hang of it.
Tonka
PostPosted: 08:43 - 28 Oct 2010    Post subject: Reply with quote
The other thing to consider is the problem I've had with levers - hands too small! Shocked Anyone jumping on the SV inevitably stalls it as I've had the lever 'tweeked' so that I stand a chance of letting out the clutch before I run out of fingers. You may want to take a look at how she manages on the stand, as someone else says, and see if she's right on the limit of her finger tips.
Another thing that was a mantra for me on the bike was don't let go with the left hand. I knew that the control of the bike was down to the clutch - I could rev the bolts out of it but go nowhere as long as I had the clutch in.
ThoughtContro...
PostPosted: 14:45 - 28 Oct 2010    Post subject: Reply with quote
+1 on that. After 35+ years pushbike riding my subconcious thought of the left lever as the back brake and let the thing go, without thinking, every time I stopped = stall. It took me a while to completely break out of that. Occasional brain fart = stall the bike.
Prize cunt
Glenben92
PostPosted: 17:23 - 28 Oct 2010    Post subject: Reply with quote
With the engine running? Think about it.
Clutch pulled, rolling back and forth will make NO difference, in gear or not
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Rowey
PostPosted: 17:59 - 28 Oct 2010    Post subject: Reply with quote
I taught my brother a while back.
Put the front wheel about a metre from a brick wall, then got him to let the clutch out to the biting point untill he bumped into it. Had him do that for a few minutes. Pushing it back then bumping the wall.
Eventually I got him further back and told him to let the clutch out and paddle the bike forwards then clutch in and brake before hitting the wall. Again did this for a little while.
Then further back, let the clutch out fully, feet still out, dragging on the ground, and clutch in, braking before the wall.
Once I was happy with that I let him go around a car park.
ZX6R C6F.
LordShaftesbu...
PostPosted: 18:30 - 28 Oct 2010    Post subject: Re: So, how would you teach someone to ride a geared bike? Reply with quote
Can you post a picture of the student? It will help me shape my advice.
rob_scott92
PostPosted: 21:09 - 28 Oct 2010    Post subject: Reply with quote
Just trail and error with me really, although i did have my uncle giving me 'some' guidence.
We did around 15 miles worth of constant stalling at lights! Really pissed me off and i couldn't be arsed riding back home Evil or Very Mad
But on the way back we stopped at lights and he told me to hold the clutch at the point it started to move (Biting point) and then release when moving properly. I think i must've just got it to move and then just dumped the clutch! also i've probably only stalled twice since then so thats good Smile
The main problem was i was worrying too much about everything! Indicators and whatnot. Rolling Eyes
Obviously people have there different ways of learning but the only thing i can think of is you walk beside her and tell her exactly what she should be doing, ie. when to let the clutch out and how much revs etc.
Have fun Laughing
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
Glenben92
PostPosted: 22:03 - 28 Oct 2010    Post subject: Reply with quote
This is all quite interesting as since getting my first ever geared bike (never previously ridden a geared bike in my life) in may I've only ever stalled twice. and neither of them were trying to pull away. both times were sitting talking to people for so long that i fogot i was in gear/on the bike/bike was running, then just letting go of the clutch and thinking "eh, what the fu.. ahh yes, i'm on a bike"
as far as actually beginning to ride, i knew the theory behind it (clutch use and gear positions etc.) and i just sort of got on and... did it. up the back lane to 3rd gear, back down the box and did a 3 point turn (its a tight lane) then the same back. repeated this 2 or 3 times then went for a ride around some empty streets to get used to signalling and turning along WITH the clutch use, then i was out riding properly and confidently within about 20 minutes of first getting on the bike. My riding has always been smooth and i've never had trouble with riding the clutch or choosing the wrong gear or slow control or anything like that.
I'm now wondering if i'm just naturally good with these things or if it's been something in my upbringing that i've missed. I have always had a quite complex understanding of engine mechanics and general physics, i wonder if it's the knowing exactly WHAT the clutch does and HOW it works that helps?
The last post was made 15 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 138.92 Kb
