ZXR400 and GSXR400
maria383
PostPosted: 17:25 - 19 Nov 2010    Post subject: ZXR400 and GSXR400 Reply with quote
Ok blonde question time.... Can I use parts from a ZXR400 on my GSXR400?
Muchas Gracias Smile
Happiness is realising you have another gear left
Jenks
PostPosted: 17:31 - 19 Nov 2010    Post subject: Reply with quote
you really need to elabourate a little more..?
what parts? what models?
Sure, some bits might well fit on, but i doubt much will go streight on..
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
MaybeGuy
all of them. theyre identical apart from the fairings and bike
maria383
PostPosted: 17:38 - 19 Nov 2010    Post subject: Reply with quote
Ideally the forks because mine are shagged.
Both 1994
Livefast123
PostPosted: 18:02 - 19 Nov 2010    Post subject: Reply with quote
I think your asking if you can fit some bits from a Kawasaki straight onto a Suzuki............ Thumbs Up
Why don't you just go onto ebay or similar and find the correct parts. Here's a set https://cgi.ebay.co.uk/1991-Suzuki-GSXR-400-Fork-Legs-/320619261964?pt=UK_Motorcycle_Parts&hash=item4aa665b00c
If the measurements, lengths and brackets are the same then you could swap the parts but the chances of that are Thumbs Down unless someone knows better
Current ride - Yamaha MT-07
maria383
PostPosted: 18:05 - 19 Nov 2010    Post subject: Reply with quote
The reason I asked is because someone I know is breaking one and I could do with a load of random bits.
Billing
PostPosted: 18:55 - 19 Nov 2010    Post subject: Reply with quote
Unlikely they will fit straight up, but nothing to say that with some time they can't be made to fit, you can fit the whole front end from the ZXR onto an NC30 with a spacer and bearings.
If they're the same diameter at the yoke clamp points and the same length thats the major ball ache sorted, after that you'll need to worry about caliper bolt spacing, spindle sizes etc. Would end up easier and probably cheaper in the long run to get GSXR forks Smile
Fisty
Tyres are the same size, some of the nuts and bolts will fit.
Not alot else will.
Fatter and faster than Fret
The last post was made 15 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 61.5 Kb
