Carburettor Needle
HD
PostPosted: 12:16 - 21 Nov 2010    Post subject: Carburettor Needle Reply with quote
Okay so I have sorted out my bike after many months and its running Mr. Green
My dad reckons he put the little washer thing on the needle on the fourth notch down when it is supposed to be third (or vice versa, cant remember).
What will this do to the bike?
As at the moment I haven't ridden it properly (two weeks til my CBT) but it does seem to be running odd. It hasn't been taken up the round or round the block so it probably was never fully warm but it just seemed to do the 'two stoke crackle' sort of thing. Its hard to explain but when they are cold and they seem to sort of 'stuggle'... You know what I mean Wink
We probably will end up changing it when we can get hold of the correct* throttle cable but what will it do for now?
* I have tried 2 different throttle cables and neither fit. Same with the clutch ones :/
Bikeless
PostPosted: 12:44 - 21 Nov 2010    Post subject: Reply with quote
It will either be slightly richer or slightly leaner depending on which groove he has put it on,the lower the groove,the richer(raises needle)and vice versa.It shouldn't make too much difference as the main jet is still the same unless of course you have changed that aswell.
Ask Kickstart,he'll fill you in with all the info about needle height,float height,jet sizes,part fuelling etc.
HD
PostPosted: 13:04 - 21 Nov 2010    Post subject: Reply with quote
Changed the main jet as I bought a new exhaust (my standard one was knackered) but jetted it to what PJ Motorcycle Engineers recommended. So haven't had a proper warm run yet to see what its like but of course I will be running it in so its harder to tell exactly what it is like.
On a side note, it does seem to run better. Not sure if it is the exhaust but it now seems to have a powerband. Never did before. Would that be down to just the exhaust or the fucked clutch, piston, cylinder, carb, airbox?
HD
PostPosted: 12:37 - 22 Nov 2010    Post subject: Reply with quote
Vincent wrote:
The jet needle has to be in the right position in relationship to the "cutaway" on the carb slide for the optimum fuel/air mixture at the right time. If it's wrong you would suffer poor pick up and/or bogging down. If the bike has standard carb, jets, bore and exhaust, just stick the needle clip on the manufacturers recommended groove.
The powerband should be noticable on any sports two stroke, if you didn't have one before there must have been something very wrong.
There really was.
And as for the needle, because I have a new exhaust you reckon it should be okay or put it to the manufacturers standard anyway? I have upjetted the main jet and put everything back to standard.
The last post was made 15 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 45.08 Kb
