Sym Jet 50 Basix problems
SchumiFan5
PostPosted: 14:11 - 21 Nov 2010    Post subject: Sym Jet 50 Basix problems Reply with quote
hello,
just wondering if anyone can tell me what is causing this on my Sym Jet Basix
When the bike is cold, starts perfectly.
But if you ride somewhere, park up for 5 minutes and try to start it again it just will not do it (on kick or electric)
when the bike is going, and i pull up to a traffic light the idle just gets lower and lower then eventually cuts out then it will not start again. (ive tried to higher the idle speed but still doesn't have any effect on it cutting out)
waiting to pull out of a junction, give it throttle, it moves, then the engine sounds "dull" and no power is being kicked out, then it cuts back in again and then rides normal
if anyone could help me on this i would be very grateful
Livefast123
PostPosted: 16:18 - 21 Nov 2010    Post subject: Reply with quote
Firstly I'd give your carb a clean and stick a new plug in it unless it has had one very recently. If it has a fuel filter check that it's clean and if not replace for the sake of a few quid.
Don't know that ped but if it has a choke check it isn't stuck on. Also what is your battery like? give it a good charge to see if that makes any difference
Current ride - Yamaha MT-07
SchumiFan5
PostPosted: 18:38 - 21 Nov 2010    Post subject: Reply with quote
thanks for your reply.
i will clean the carb tomorrow at work and see how it goes Smile
its only just had a new plug + battery
thanks for advice Very Happy
Livefast123
PostPosted: 22:49 - 21 Nov 2010    Post subject: Reply with quote
Did the problems start with the new plug and battery?
Change it anyway as just because it's newish doesn't mean it's ok. Get a proper NGK one and give the battery and good charge.
radical
PostPosted: 23:05 - 21 Nov 2010    Post subject: Reply with quote
check that the automatic choke is functioning properly as it could be constantly on, this would be indicated by excessive smoke and a sooty sparkplug. Change your plug first and if the problem persits check the choke operation and all the electrical connections from the carb.
SchumiFan5
PostPosted: 18:40 - 28 Nov 2010    Post subject: Reply with quote
thanks for reply guys,
i cleaned out the carb, and put it all back together, about 9pm so i took it for a 'test ride'
unfortunately, it was icey and i crashed it Sad
but seemed to run alot better Smile thanks for advice
Astridax
PostPosted: 20:06 - 28 Nov 2010    Post subject: Reply with quote
Lol bad luck. Sad But that is funny Razz Almost like god was telling you it was going to end your life sooner or later and saved you from that fate Very Happy.
SchumiFan5
PostPosted: 20:53 - 01 Dec 2010    Post subject: Reply with quote
Razz
after a couple of days riding, i still am getting all the same problems as before, ideas anyone? Thinking
Astridax
PostPosted: 20:56 - 01 Dec 2010    Post subject: Reply with quote
IT SURVIVED!
beechbone: Oh crap...I'm turning into 27cows Shocked
Walloper: And giving up one's leg to save a falling motorbike is the stuff of leg-ends....Embarassed
The last post was made 15 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 65.68 Kb
