| map |
 map Mr Calendar
 Posted: 18:32 - 21 Nov 2010 Post subject: Senior moment - rear drum brake help needed - SORTED |
As title I had a bit of a senior moment when taking off the rear wheel to fix some binding brakes. The machine has been stood for a while. Anyhow, ended up taking off the brake arm without marking its original position.
So now when everything is connected together applying the brake just locks the brake on, it doesn't release.
Any help appreciated as I can't remember the trick to set these right (so two senior moments then, Alzheimer's here we come).
Thanks in anticipation  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?
| truslack |
 truslack World Chat Champion
| map |
 map Mr Calendar
| truslack |
 Posted: 19:20 - 21 Nov 2010 Post subject: |
What bike is it? Trial and error should get you pretty damn close within a couple of attempts.
Are you SURE there isn't a mark on the end of the splined shaft?
Like this:
https://w6rec.com/duane/bmw/brake/bmw_front_brake1.jpg ____________________ Current: Suzuki RG 125 Gamma, Honda H100, Triumph Tiger 800XC, Suzuki SV650 (minitwin) |
| map |
 map Mr Calendar
| Raffles |
 Raffles World Chat Champion
| map |
 map Mr Calendar
 Posted: 10:14 - 24 Nov 2010 Post subject: |
Now sorted the problem, well, 98% there
Turns out the brake camshaft wasn't as cleaned and lubricated as I thought (I'd delegated, if a jobs worth doing, etc.).
It had actually stuck at an angle. Thus giving the impression of binding brakes (because they were!) and probably allowed rotation to 90 degrees so sticking the brakes on.
Removed the camshaft, cleaned, lubricated and reassembled.
Now works fine although I need to fine tune the arm placement as the pedal travel is too much before brakes applied. I can confirm that there are no score or punch marks on the cam or the arm to assist replacement.
Thanks for the assistance. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| truslack |
| map |
 map Mr Calendar
 Posted: 11:39 - 24 Nov 2010 Post subject: |
The last post was made 15 years, 59 days ago. Instead of replying here, would creating a new thread be more useful? |
