| upanddown22 |
 upanddown22 Nova Slayer
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 09:10 - 18 Oct 2010 Post subject: |
first off id get a new plug, just because a plug is firing out of the cylinder doesnt mean it is under compression,
next i'd be doing the valve clearances, super easy job on a rocker arm ohc honda engine, you'll need a set of feeler guages, (a couple of quid from halfords)
next i'd check the timing (perhaps in conjunction with the valve clearances) and make sure the tensioner has tensioned the cam chain correctly
try that if its still not running properly then we'll go from there ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| upanddown22 |
| P. |
 P. Red Rocket
 Posted: 13:56 - 18 Oct 2010 Post subject: |
Its electronic timing, I had no worries with that over 21,000 miles.
Have you checked it got good compression?
Stick the choke on, set it to reserve and hold the throttle open and try the starter.
If it fails, try bump starting.
My cityfly took forever to die  |
| upanddown22 |
 Posted: 16:06 - 18 Oct 2010 Post subject: |
| ##Paddy## wrote: | Its electronic timing, I had no worries with that over 21,000 miles.
Haven't checked the compression, is there any easy way without a gauge?
I've had no end of problems with it, quite tempted to get rid. I'm meant to be using it for my Mod 1 on the 8th of Nov  |
| upanddown22 |
| hmmmnz |
 Posted: 11:15 - 22 Nov 2010 Post subject: |
i wasn't talking about ignition timing, i was talking about the timimg of the cam in relation to the crank,
any way, good stuff about the plug,
keep a spare with the bike along with a spanner, incase it happens again  ____________________ the humans are dead
| upanddown22 |
The last post was made 15 years, 42 days ago. Instead of replying here, would creating a new thread be more useful? |
