fitting dual horns
vmax12
PostPosted: 12:14 - 23 Nov 2010    Post subject: fitting dual horns Reply with quote
hi guys, got some new horns that came with a relay but no instructions aint gotta cue....its a four pin one. googled it and no two explanations are the same...... to start with i got two wires that go to the original horn.....brown which is live when ignition is switched on and a pink wire which goes to the horn switch , thanks for any help
PostPosted: 12:39 - 23 Nov 2010    Post subject: Reply with quote
DUAL.
Odie
PostPosted: 12:57 - 23 Nov 2010    Post subject: Reply with quote
Using a 4 pin relay, pin 86 should be the wire from your ignition switch, live when ignition is turned on.
85 should be a ground.
87 should be to your horns and 30 should be a wire from the battery.
Attachments can be made to pins with a flat crimp plug.
You'll want to be connecting all of your horns in parallel, which essentially means each horn gets its own wire to the power source.
So get your wire, and run it from your power supply (relay pin 87) to each horn.
A horn can be grounded by bolting wire to the frame of the body, or by running wire from the negative side of the battery.
Each horn must be grounded.
Be sure any connections are soldered and heat shrunk, or crimped together.
Make sure all bare wire is taped or heat shrunk. (Heat shrink shrinks around the wires and seals them like tape would - get it hot to shrink)
Hope this helps
vmax12
PostPosted: 13:21 - 23 Nov 2010    Post subject: Reply with quote
cheers odie.....so the pink wire from the horn switch go to 87 with two wires out that go to the horn?
Odie
PostPosted: 16:28 - 23 Nov 2010    Post subject: Reply with quote
Yes
The last post was made 15 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 43.95 Kb
