| Aidanc80 |
 Aidanc80 Borekit Bruiser
| Robby |
 Robby Dirty Old Man
 Posted: 07:58 - 24 Nov 2010 Post subject: |
A knackered battery is likely, it's the season for it.
Basic charging system test first. Charge the battery up first, so that you are getting 12 volts or more across the terminals with a multimeter with everything turned off. Then start the bike, and you are looking for the same or higher voltage - try with the lights on too. Then rev it up to around 4000rpm and hold it there, you should be getting around 14.5 volts, I would be happy with 13 or more on that bike.
If it's reading more like 60 volts, your reg rec is dead. If the voltage is dropping as your put more load on the engine and electrical system, it isn't charging. If you are getting some response but the numbers are lower than I say, it's the battery.
If the numbers point at battery or charging circuit, get a new battery first. Cheap and easy. If they point at reg/rec, get a new reg/rec and a new battery. Make sure you charge the new battery as instructed before fitting it to the bike, or it won't last. |
| Aidanc80 |
| P.addy |
 P.addy Red Rocket
| Aidanc80 |
 Posted: 11:53 - 24 Nov 2010 Post subject: |
Yeah it makes sense doesnt it...  |
| truslack |
 truslack World Chat Champion
| map |
 map Mr Calendar
| Alexio |
 Alexio World Chat Champion
| Aidanc80 |
 Posted: 09:12 - 25 Nov 2010 Post subject: |
Map it would have been that if had turned the bloody fuel on
So as i had forgot that basic rule it wouldn't start and that was the end of it...
Had the battery on charge with oxford optimizer 600, anyone know if the battery when connected to this charger without it being plugged in would show it as being charged??
As every time i unplug it drops down to three lights as if battery needs charged!
Im thinking new battery and then see what else as bought the bike and hasn't been run much in the last year or so.. |
| kingsknight |
 kingsknight World Chat Champion
| DrDonnyBrago |
| N cee thirty |
 N cee thirty Banned
| Aidanc80 |
 Posted: 17:40 - 25 Nov 2010 Post subject: |
will do guys, cheers |
| Ingah |
 Ingah World Chat Champion
The last post was made 15 years, 230 days ago. Instead of replying here, would creating a new thread be more useful? |
