Honda vardero xl 125cc sluggish??
northfacemush
PostPosted: 09:41 - 25 Nov 2010    Post subject: Honda vardero xl 125cc sluggish?? Reply with quote
Hi,I've had my bike 6mths now and alls been fine.....winters set in and now i seem to be having problems.She took a fall in high winds and brake handle bent and tank has a dent but seemed fine..now she wont go above 50mph and it feels like the engine spultters// saw in the mirrors a massive puff of smoke then it ran fine.....parked up and the next day it was like somebody had taken half the engine power away. what could it be???
grateful for any help
cheers
kingsknight
PostPosted: 12:14 - 25 Nov 2010    Post subject: Reply with quote
could be a lot of things. check the air filter hasn't dislodged and cutting the air flow. Also check there isn't a tight bend in your fuel pipe.
falling that i would be at a loss. The smoke your saw was some oil passing your rings as the bike was sitting on it's side!
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
Blue_SV650S
PostPosted: 13:03 - 25 Nov 2010    Post subject: Reply with quote
Is the choke handlebar operated or on the carb? Carrying on from rob yarrr idea, I think you might have a snagged choke cable (if it is operated from the bars).
robocog
PostPosted: 13:34 - 25 Nov 2010    Post subject: Reply with quote
Not sure on the Vara, but if the engine crank case breather pipe leads into the airbox, it could be the air filter is now oil soaked from being sat on its side?
This could lead to a VERY rich mix (and an oily one explaining the smoke?)
Worth a look?
Regards
Rob
Needs a bigger garage...
northfacemush
PostPosted: 17:32 - 25 Nov 2010    Post subject: Many Thanks Reply with quote
Had a peek at the spark plug....looked very black/sooty and seemed to be some fulid coming from that area??i start the choke with it being so cold up here in scotland should it retract in on its own?making it cut out??excuse my lack of lingo but i'm afraid the limit of my knowledge is pressing the starter switch!!! very ashamed folks.All very helpful most grateful....Thanks and keep em coming.
northfacemush
PostPosted: 17:52 - 25 Nov 2010    Post subject: Reply with quote
chokes on the carb!
northfacemush
PostPosted: 17:58 - 25 Nov 2010    Post subject: aye Reply with quote
i did that.....when it wont cut out,ran with it once all day(not sure what damage that would have done?whoops.
could i have put to much oil it when topping up?or could it be the wrong type....dont trust my bike dealer?
Paxovasa
PostPosted: 17:59 - 25 Nov 2010    Post subject: Reply with quote
Choke on full, start bike. Then reduce the choke bit by bit until it will idle without choke.
The bike may be suffering from carb icing , if it is a carbed model. Thumbs Up
northfacemush
PostPosted: 18:01 - 25 Nov 2010    Post subject: ?? Reply with quote
carb icing....go on?
northfacemush
PostPosted: 18:04 - 25 Nov 2010    Post subject: Alas Reply with quote
warranty is long gone....i try the carb cleaning tomorrow mate..thinks it's due a service so maybe leave it to the pros(if i can afford it eh!!
thanks for your help
Paxovasa
PostPosted: 18:07 - 25 Nov 2010    Post subject: Re: ?? Reply with quote
Carb icing, is caused by the cold, the air freezes in the carb and stops the fuel and air from mixing.
Signs of this are engine cutting out when reducing revs (as in coming to a junction) and the bike feel like it is running on less cylinders.
northfacemush
PostPosted: 18:11 - 25 Nov 2010    Post subject: Reply with quote
well its cold enough for sure!!!is it likely i'm doing damage to the engine with it runing as it is....should i leave it maybe and have it checked out?to be safe??
alun111
PostPosted: 18:12 - 25 Nov 2010    Post subject: Reply with quote
did you clean the spark plugs yer? They might be oiled up from the bike being on it's side.
northfacemush
PostPosted: 18:16 - 25 Nov 2010    Post subject: Reply with quote
yep cleaned the spark plugs!!
Paxovasa
PostPosted: 18:21 - 25 Nov 2010    Post subject: Reply with quote
It depends on what the problem is.
Do you reduce the choke after the bike has started? Do you reduce and eventually turn the choke off completely?
robocog
Worth a look?
Regards
Rob
Would also make your plugs black and run like the choke is stuck on (even though you have turned it off)
I still think its worth checking inside the airbox for an oil soaked air filter..
Black sooted up plug = running rich
a wet plug (wetted by oil or fuel) IHMO belongs in the bin
They are cheap enough to bung a fresh one in without breaking the bank
Once wetted they NEVER run quite the same -
(I chased "troubles" on an engine I was running and had converted to electronic ignition and unfortunately for me the plugs were the last thing I got round to changing - which cost me a fortune and weeks of headscratching/swapping bits and rewiring everything that didn't need doing for the sake of £10 of plugs which solved everything instantly- I also chucked the foam sock filters away that covered the carbs - as it was those getting sucked into the carb mouths causing the wetting of the plugs in the first place)
I would also say that carb icing is unlikely as my only other experience of it resulted in the carbs spitting back due to an overly weak mixture rather than over rich mix
Oil level is a 2 second 1 handed job to test for - so do it!
Unscrew the filler plug, wipe the oil off the dipstick pop the dipstick back in (don't screw it in, just let gravity do the work)
Pull it out...now wheres the oil level showing the hi tide mark?
If its whithin the hashed area you know it hasn't been overfilled
(typing this would have taken longer than doing it)
As for wrong type of oil...as long as the stuff you poured in/topped up with's bottle said "oil" on the side its the right stuff for a CG*
(OK so there maybe some oils like penetrating oil which would be less suitable than any other fluid)
Regards
Rob
LeeR
PostPosted: 19:59 - 27 Nov 2010    Post subject: Reply with quote
If it is carb icing you might find 1 - 2% Silkolene Pro - FST added to your fuel tank will prevent it happening, worked for me on my 1cyl 650cc, you can pick it up at most dealer's for around £10/litre
My claim to fame: Austin Vince nicked my pen...
The last post was made 15 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 105.05 Kb
